Old 02-29-2008, 12:39 PM   #25291
heavy's Avatar
Trader Rating: 20 (100%+)
Originally Posted by aus jd 2703 View Post
thank adrian but i got bigish meet coming up and i will get weighed so i kinda need a solution. but ill do what u say for club meetings
Josh - you are actually going to race ??????
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 02-29-2008, 01:49 PM   #25292
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Darkseid View Post
Oh yeah, thats right! I forgot all about that.
Lucky you. I think that was the thing I hated most about that car. That belt used to stretch a lot and shred. And anyone who worked on that car knows how much of a PITA changing that belt was. You pretty much had to disassemble the whole car. That's a big reason why the Mi3 was such a treat when we got it. We went from the most difficult car to work on, to the easiest.
Jon Kerr is offline   Reply With Quote
Old 02-29-2008, 08:45 PM   #25293
AdrianM's Avatar
Originally Posted by yokemad View Post
hi dudes
I'm just wondering why some racers cuts teeth from front or rear belts?
also what is the correct part no white frnt belt .does mi2 or ec ones are the same
cheers
Clipping the teeth off belts and pullies is somthing we love to see the other teams do. It sounds like it would work but it nets no efficiency improvement.
Here's why...
Lets say that a belt makes contract with 18 pulley teeth at the same time as it wraps around the pulley. For the sake of easy math let say the belt is applying 18 in/oz or torque on the pulley as the car accelerates. So lets assume each of the 18 teeth in contract with the pulley is bearing a 1 in/oz load.
If you cut away every other tooth now you have 9 teeth in contact applying the same load so each tooth now is bearing a 2 in/oz load. This doubling of the load increases the possibility of skipping and since the relative pressure on each tooth is doubled so is the friction as the tooth engages and releases the tooth on each pulley. So...over all there is no gain in efficiency.
Schumacher puts a lot of engineering into belt and pulley tooth profiles and it shows. I have not seen any belt sedan out of the box as free as a properly assembled Mi2EC or Mi3.
Keep your bearings smooth and clean and thats all you have to worry about.
Adrian Martinez
Old 02-29-2008, 10:34 PM   #25294
JayBee's Avatar
Trader Rating: 31 (100%+)
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-01-2008, 08:30 AM   #25295
Regional Moderator
Darkseid's Avatar
I said I forgot about it, I didn't say I missed out on the "fun" of dealing with the belts. My favorite part was how if you put the pulley fence for the center pulley on wrong, it would shred the rear belt...again....and again....and again...
Ahh....good times...good times...
TLR 22...Tamiya F104...
Old 03-01-2008, 08:35 AM   #25296
Regional Moderator
Darkseid's Avatar
Here's why...
Just wondering does the same apply for pulleys with every other tooth removed. I ask because when I ran my TA05, Tamiya release a pulley that cut the number of teeth on each diff pulley in half. This showed a marked improvement in how free the drive train was compared with the stardard pulleys.
Still wasn't out of the box Schumacher free, but there was clearly a difference.
Old 03-01-2008, 03:23 PM   #25297
AdrianM's Avatar
It would work if were were coasting our cars around the track with no pinions on our motors. Once you put torque into the system there is no advantage and an increase in the possibility of skipping the belts.
A lot of companies make stuff because top racers ask them to do it. Racers do come up with good stuff the engineers do not think of sometimes...this just isn't one of those cases.
Adrian Martinez
Old 03-01-2008, 08:50 PM   #25298
Regional Moderator
Darkseid's Avatar
Hmmm....
Good to know. I was going to ask Schumacher about making some of those pulleys. Now...I guess not.
Old 03-01-2008, 09:38 PM   #25299
Jon Kerr's Avatar
Or the, "Do I have time to change my diff? I've only got 5 heats until I'm up. Better not risk it..."
Old 03-02-2008, 01:00 PM   #25300
JayBee's Avatar
Thumbs up
Hey Adam, here's some more Pink/ Purple/ Plum/ Magenta for ya
Old 03-02-2008, 05:41 PM   #25301
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
i dont see any E4 stickers
Old 03-02-2008, 05:42 PM   #25302
abailey21's Avatar
Trader Rating: 36 (100%+)
Cute JB......
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-02-2008, 05:50 PM   #25303
Regional Moderator
Darkseid's Avatar
Old 03-02-2008, 05:51 PM   #25304
JayBee's Avatar
Old 03-02-2008, 07:58 PM   #25305
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Welcome to the team Jerome!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
