Old 02-27-2008, 04:49 PM   #25276
AdrianM's Avatar
No one weighs cars at my local track and I race again some ultra light Team Magic and Losi sedans so I don't add weight to my Mi3. All I do to balance it is shift my Core 5000 pack so it sits ~3mm past the edge of my chassis. Voila, perfect balance and no added weight!
Adrian Martinez
Old 02-27-2008, 04:51 PM   #25277
thank adrian but i got bigish meet coming up and i will get weighed so i kinda need a solution. but ill do what u say for club meetings
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 02-27-2008, 04:56 PM   #25278
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Well if hes moving it 3 mm past the edge of the chassis it seems like there would be enough room to run some weight pretty close to down the middle. Especially where the belt starts rising to reach the layshaft pully. If its balanced without weight, then you could theoreticaly just add weight to hit minimum . . .right?
Old 02-27-2008, 05:00 PM   #25279
awsome idea sorry re thought bout it
does any one know what size turnbuckle turner i need for mi2/mi3?cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 02-27-2008, 05:25 PM   #25280
AdrianM's Avatar
Industry Standard 4mm.
Adrian Martinez
Old 02-27-2008, 10:35 PM   #25281
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by RocketRacer View Post
thanks for the spring charts Arno, Marcos and HVA!! it eally helped!
no problem
Old 02-27-2008, 10:36 PM   #25282
Super Moderator
Marcos.J's Avatar
I wonder who has that Ultra Light Team Magic
Old 02-28-2008, 06:00 AM   #25283
abailey21's Avatar
Trader Rating: 36 (100%+)
Marcos = Team Magic Carpet Ride
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-28-2008, 06:10 AM   #25284
Super Moderator
Marcos.J's Avatar
i thought that was dani's name??
Old 02-28-2008, 06:12 AM   #25285
abailey21's Avatar
Did Dani buy one???
K.C.C.O.
Old 02-29-2008, 04:33 AM   #25286
yokemad's Avatar
hi dudes
I'm just wondering why some racers cuts teeth from front or rear belts?
also what is the correct part no white frnt belt .does mi2 or ec ones are the same
cheers
yokemad is offline   Reply With Quote
Old 02-29-2008, 07:03 AM   #25287
Regional Moderator
Darkseid's Avatar
Originally Posted by yokemad View Post
hi dudes
For the same reason some companies remove every other tooth from the pulleys. Its done to improve efficiency and reduce the drag associated with running belts. At the same time, it doesn't seem to make the belts any more likely to skip. Doesn't seem neccesary for the Schumacher cars though. The drive trains are already the smoothest on the market.
cheers
U3012-Front Grey belt
U3013-Rear Grey belt
*edit* The belts are the same ones from the Mi2EC.
TLR 22...Tamiya F104...
Old 02-29-2008, 07:37 AM   #25288
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Actually, the front belt for the Mi2 is different. The Mi2 had an extremely long belt that went from the rear pulley to the front pulley.
Jon Kerr is offline   Reply With Quote
Old 02-29-2008, 07:48 AM   #25289
yokemad's Avatar
thanx guys
u3012 is the part number of grey front belt, I've also ordered ea diff grease I hope it is as good as schumacher ones
does anybody tried xray oneway diff halfs on mi3 they r xtremely light....
Old 02-29-2008, 07:54 AM   #25290
Regional Moderator
Darkseid's Avatar
Oh yeah, thats right! I forgot all about that.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
