Old 02-26-2008, 10:52 AM   #25261
HVAC25000's Avatar
Trader Rating: 19 (100%+)
It's not a chart, but it has all the Schui springs listed.
http://www.racing-cars.com/usa/searc...&templateid=12
hth
HVAC25000 is offline   Reply With Quote
Old 02-26-2008, 11:39 AM   #25262
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by RocketRacer View Post
i am looking for a spring rate chart for the schumacher on road touring car springs. does anyone have a chart or know where i can download a copy??
here is a link for another spring chart http://www.rcingreece.com/index.asp?...ing_comparison
Old 02-26-2008, 12:16 PM   #25263
Try this page, there is a TC spring chart
Arn0 is offline   Reply With Quote
Old 02-26-2008, 12:21 PM   #25264
Originally Posted by AdrianM View Post
You are also under geared even for 6 cells. If you are running a Komodo on 6 cells you need a 25T pinion. An Orion or Check Point 19T needs a 27 to 28T pinion for 6 cells.
Add 3-5 teeth to each gear for running on these motors on 5 cells.
Motor could not be a problem it`s brand new some Lrp thing, but what the F.D.R should be because it seems i cannot put larger pinion than that i already have. I could mess with other gears because in my country we have no Model or hobby shops and this is Europe.
Logika is offline   Reply With Quote
Old 02-26-2008, 12:52 PM   #25265
Super Moderator
Marcos.J's Avatar
yes its 1 post over yours
Old 02-26-2008, 02:14 PM   #25266
MadBrushRacing's Avatar
Default Carpet setup
Hi
Attached is my last carpet setup. It was very easy to drive but I need it to be able to change direction abit quicker.
What would you all recommend?
Also, what benifit is the middle hole on the steering knuckle?
Tony
MadBrushRacing is offline   Reply With Quote
Old 02-26-2008, 02:43 PM   #25267
Hi Skiddins
How did you get on at the weekend?
Tony
Old 02-26-2008, 02:53 PM   #25268
Skiddins's Avatar
Originally Posted by MadBrushRacing View Post
Hi Skiddins
Tony
23rd overall
It was very competitive. Q 3rd in the C-Final, got two 3rd's and a 2nd in the finals despite being put back to 10th on the first lap of two of the finals.
Car felt great, new Komodo motor was fast but it it was very competitive, guy who TQ'd Mod the day you were there only managed the B-Final on Sunday!
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-26-2008, 08:06 PM   #25269
Originally Posted by abailey21 View Post
The only difference between the purple and silver bones by themselves is the color only!
If you order the bare bones "U3233" you'll receive purple. If you order complete CVD's you'll receive the silver ones.
i thought the silver ones had a different pin hence they were stronger or has schumacher making all drive shafts like that now?
also my old mi2ec has 2 degrees rear toe in on left side and 3 degrees on the right hand side (hudy set up station) any ideas?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 02-26-2008, 09:05 PM   #25270
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
First check to make sure you don't have a bent hinge pin. If that's not the issue, make sure that when you tighten each of the pivot blocks down, that they don't shift and turn at an angle. This can throw the toe angle off and cause binding at the same time. If both of those are fine and it's still off, I'd replace the rear hub and suspension arm on the side that is off. 2 degree is stock for that car with the alloy pivot blocks and the 2mm Euro chassis.
Jon Kerr is offline   Reply With Quote
Old 02-26-2008, 11:59 PM   #25271
Hi
Tony,
to change direction quicker you basically need the car to roll less, so that the transformation from one extreme to another would be quicker. This in turn means either harder springs or higher roll centre. I don't know what the HPI silvers are like, but IIRC they are extremely soft? The only HPIs I've used is pink front/blue rear, or Schumacher blue/blue, blue/white or white/white combo. You could also change the shock oils, now you have 10wt difference frt/rear, you could try 5wt difference or same oils frt/rear. Stand the rear shocks up more.Try using 1.2 rear swaybar and 1.4 up front. There's some things I would try, in more or less that order...
olev is offline   Reply With Quote
Old 02-27-2008, 06:10 AM   #25272
abailey21's Avatar
Trader Rating: 36 (100%+)
There is a different pin, but they made the silver bones to distinguish the old and new versions of CVD's. The bones never changed
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-27-2008, 08:27 AM   #25273
CA
Change the rear hub to an Mi3 one. We have a few problems with the Mi2 ones.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
Old 02-27-2008, 11:50 AM   #25274
RocketRacer's Avatar
thanks for the spring charts Arno, Marcos and HVA!! it eally helped!
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 02-27-2008, 04:28 PM   #25275
ok now im utterly confused
ok i keep shearing the pins of at the end that goes into the out drive. will the new drive shafts prevent this and or stop it?
also i got bored and started thinking cause ive been adding a heap of weight to my car (damn lipo) how can i measure balance left to right is simple use a string line hang the car balance but how to measure front to back and how to tell if one corner has to much weight? reason i ask is i have been running my weight on top of the battery but since im all lipo now im running it on the chassis so i out as much weight forwards and as far right (battery side) as possible this was to A)balance left to right B) to get more steering but how do i know if i have over loaded the front right tire now?
is this what they call cross sectional weight distribution?
cheers guys
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
