Old 02-25-2008, 08:23 AM   #25246
abailey21's Avatar
Trader Rating: 35 (100%+)
U3020, its the same as the old part number but the parts have been updated
Originally Posted by yokemad View Post
true try new silver dogbones they are really solid....
I'll try to let u know the part numbers a.s.a.p
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-25-2008, 11:38 AM   #25247
Trader Rating: 22 (100%+)
Originally Posted by Big Features View Post
Had great time at the Winter Carpet Nats in Gathersburg, MD yesterday. Unofficially called the "Mike Kring going away race" it was lots of fun.
Team Shumacher did well with Tim Getchell putting his Mi3 in the Rubber "A" main, with privateer Steve Walter and I running the schuie frieght train in the "B". I ended up "BQ" and lead the race from start to finish. After watching the carnage in the "A", I'm kinda glad I was in the "B"
Wes Lion made the show in foam, but dont know where he ended up.
Big thanks to Mike Herald Jr for the advise and shock tips
I'm off to Hawaii now, but rest assured I'll represemt well over there. I'll try and make Vegas, but no promises
As Static Kling said we had a great time at Mimis. This was the first time I have ever run rubber tires on carpet on it was great. Mike thanks again for the set up. After rebuilding my car that moring and putting that setup on, I never touched anything else on the car. Have to also thank Steve Walter for suppling my left front end. Bummer when you show up to the track and your missing a whole side of the car . You make make racing enjoyable and that is what is all about.
Mike, wish you the best, I am sure you will be in hawii making new racing buddies, thats what you do. You are one of the best guys to hang around for some laughs thats for sure. Take care and I will see you around.
fastasu2 is offline   Reply With Quote
Old 02-25-2008, 12:16 PM   #25248
yokemad's Avatar
the parts u need to run steel bones in your 1way:
46mm L/W bone #51092
415 axle #53499
kit 1way joint #53590
L/W 1 way joint #53704
yokemad is offline   Reply With Quote
Old 02-25-2008, 01:02 PM   #25249
Big Features's Avatar
Thanks Tim, It was great seeing you on the Track again! Congrats again on your "A" main run.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 02-25-2008, 01:14 PM   #25250
Adam, You've got PM
Mike Kling
Old 02-25-2008, 01:19 PM   #25251
abailey21's Avatar
I know
K.C.C.O.
Old 02-25-2008, 03:25 PM   #25252
Could someone help? I am running Schumacher axis2 and I can`t figure out one thing. I`m racing in local club on carpet, rubber, 19t motor on 5 cells, but i`ts awfully slow on a strech. Could someone suggest what should i do to fix this maybe different gear ratio. Currently i`ts 23 pinion and 86 spur. Electornics seem to bet perfect because this plastic hell Tamiya TT-01 is running better with this set if electronics.
Logika is offline   Reply With Quote
Old 02-25-2008, 03:32 PM   #25253
justin lessard's Avatar
Send a message via AIM to justin lessard
the motor might need to be cut and new brushes put in, the speed control might not be properly set.
justin lessard is offline   Reply With Quote
Old 02-25-2008, 04:51 PM   #25254
AdrianM's Avatar
You are also under geared even for 6 cells. If you are running a Komodo on 6 cells you need a 25T pinion. An Orion or Check Point 19T needs a 27 to 28T pinion for 6 cells.
Add 3-5 teeth to each gear for running on these motors on 5 cells.
Adrian Martinez
Old 02-25-2008, 06:34 PM   #25255
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
So whats the hot set up for asphalt racing? I'll be making my asphalt "day butt" this weekend at a race in Missippi and I don't have a clue what I am getting myself into (I have been running foams for the last 3 years) Ive been told the hot tire there is the RP30 and I'll be running mod and 13.5. Thanks y'all!
Links are always good!
Old 02-26-2008, 03:49 AM   #25256
mitchsterbrau's Avatar
thanks adam and yokemad!
will give em a try.
mitchsterbrau is offline   Reply With Quote
Old 02-26-2008, 04:33 AM   #25257
hey are these the new silver bones or old purple ones?
u3233 drive shaft bones ??
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 02-26-2008, 07:16 AM   #25258
abailey21's Avatar
The only difference between the purple and silver bones by themselves is the color only!
If you order the bare bones "U3233" you'll receive purple. If you order complete CVD's you'll receive the silver ones.
cheers
K.C.C.O.
Old 02-26-2008, 08:18 AM   #25259
slammin's Avatar
Trader Rating: 83 (100%+)
Send a message via Yahoo to slammin
Hey Andrew try this setup this is what Rick and myself are using with a couple of changes, schumacher white spring all the way around.And if you need some more traction add 1mm inboard on the rear toe.
http://www.racing-cars.com/usa/image...w_reedy_07.pdf
RC Addicts AR
Serpent srx4
Serpent srx8
slammin is offline   Reply With Quote
Old 02-26-2008, 11:28 AM   #25260
RocketRacer's Avatar
i am looking for a spring rate chart for the schumacher on road touring car springs. does anyone have a chart or know where i can download a copy??
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
