Old 02-22-2008, 12:07 PM   #25216
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Hey guys. I've got a GTB in my Mi-3. Where's a good place to mount the cap? Only place I can find is behind the motor, but I have no idea how to secure it with anything that won't melt.
Chris
HVAC25000 is offline   Reply With Quote
Old 02-22-2008, 11:40 PM   #25217
zip tie it to the motor wires
Barger is offline   Reply With Quote
Old 02-23-2008, 06:20 AM   #25218
abailey21's Avatar
Trader Rating: 36 (100%+)
I ran mine under the top deck and secured it to the rear right bulkhead
I wasn't running LiPo then though so I think you'd have some clearance issues if using LiPo
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-23-2008, 09:47 AM   #25219
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Chris
Run the wires along the chassis and next to the motor mount. Then out behind the motor. Shoe Goo (or as Adam calls it Show Goo ) the wires and the cap to the chassis.
Jon Kerr is offline   Reply With Quote
Old 02-23-2008, 11:22 AM   #25220
HVAC25000's Avatar
Thanks guys. One of those has got to work.
Old 02-23-2008, 08:18 PM   #25221
pepr's Avatar
Trader Rating: 1 (67%+)
lookin to get a mi2ec but i see people talking about a mi2 are these the same caes.
pepr is offline   Reply With Quote
Old 02-23-2008, 08:26 PM   #25222
Jon Kerr's Avatar
The Mi2EC is basically an evolution of the Mi2. The EC came out in early 2006 after Teemu won the 2005 Euoros with a modified Mi2. The EC is pretty much a copy of the car Teemu ran. There's some suspension geometry changes, the drive train is different, and the biggest change was the shocks. The EC shocks were far better than the Mi2 shocks. In fact, none of us ran the Mi2 shocks. We all ran TRF shocks before the EC came out.
Old 02-24-2008, 04:24 AM   #25223
abailey21's Avatar
The EC shocks were so good Kerr still runs them on his dirtbike!!!!!
K.C.C.O.
Old 02-24-2008, 07:44 AM   #25224
Big Features's Avatar
Had great time at the Winter Carpet Nats in Gathersburg, MD yesterday. Unofficially called the "Mike Kring going away race" it was lots of fun.
Team Shumacher did well with Tim Getchell putting his Mi3 in the Rubber "A" main, with privateer Steve Walter and I running the schuie frieght train in the "B". I ended up "BQ" and lead the race from start to finish. After watching the carnage in the "A", I'm kinda glad I was in the "B"
Wes Lion made the show in foam, but dont know where he ended up.
Big thanks to Mike Herald Jr for the advise and shock tips
I'm off to Hawaii now, but rest assured I'll represemt well over there. I'll try and make Vegas, but no promises
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 02-24-2008, 08:51 AM   #25225
yokemad's Avatar
well done mate....
could you please share that shock tips with us
yokemad is offline   Reply With Quote
Old 02-24-2008, 09:46 AM   #25226
jheimb4897's Avatar
I still run TRF shocks on my EC... Best ones in the business if you ask me.
I can walk backwards fast as you can, I can walk backwards fast as you can. I'm the backwards man, I'm the backwards man.
jheimb4897 is offline   Reply With Quote
Old 02-24-2008, 10:08 AM   #25227
AdrianM's Avatar
The Mi3 shocks build/bleed easier and the shock bodies have a harder longer lasting coating than the TRF shocks. In every other respect, bore piston diameter/ thickness, hole diameter, seal package, etc. the are identical to the TRF shock so all in all the Mi3 shock are better.
Adrian Martinez
Old 02-24-2008, 10:28 AM   #25228
yokemad's Avatar
I've bought some trf shocks for my mi3, building them was very hard if u compare them with mi3 shocks it looks like I wasted some of my dollars but it's before racing with them I hope they'll proof themselves on track...
give me some tips about how to set rebound...they had 100% rebound than I've pushed the piston half way in put the bladder on top clean the extra oil and they have 50% rebound which i want but not sure if i did it wright or not :\
Old 02-24-2008, 10:39 AM   #25229
AdrianM's Avatar
I would make the TRF shack 62mm long end to end, pop a 2mm quick clip on the shaft, push the piston in,place the bladder on top then the eyelet then the cap. Screw it down.
Remove the quick clip and check the rebound. I like to see ~3mm rebound.
Chances are you will get 3 perfect shocks and one with too much rebound. Just keep rebuilding until you get it right.
The reason the Mi3 shocks come out right every time is the small bleed hole in the side of the cap. It lines up with the joint between the bladder and the shock body and lets the shock bleed perfectly every time.
Adrian Martinez
Old 02-24-2008, 12:12 PM   #25230
It was a good race day. Tim had a good run for his 1st time running rubber tire on carpet. We all worked good together with setup help. Sorry to see Kling go from the area. Good luck in the islands. My car was good, but the driver was over driving it.
Thanks to Mike Herald Jr for the fine tuning of my setup.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
