Old 02-15-2008, 10:01 PM   #25156
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
wow - this is why i love rctech - thanks so much guys
wstuart is offline   Reply With Quote
Old 02-16-2008, 11:35 AM   #25157
skypilot's Avatar
Trader Rating: 14 (100%+)
adam,,
so did the eagle land yet or what??
skypilot is offline   Reply With Quote
Old 02-16-2008, 05:35 PM   #25158
Big Features's Avatar
Hope he's not nervous about the honeymoon
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 02-16-2008, 09:11 PM   #25159
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Marcos.J View Post
more caster =more stability at high speeds
less caster=increases steering,car turns tighter and faster
From the Master, Todd Hodge:
"...Less caster will give the car a more responsive feel and less steering into the turn, however, it will yield more corner exit steering. More caster will give the car more steering into the turn and make the car easier to drive..."
-http://losi.com/Articles/Article.aspx?ArticleID=1562
yyhayyim is offline   Reply With Quote
Old 02-16-2008, 10:27 PM   #25160
AdrianM's Avatar
Todd is incorrect with regards to 4wd touring cars. Under certain conditions he would be correct for 2wd off road cars. The dynamics of 2wd cars vs. 4wd sedans are different.
On a 4wd sedan less caster gives more corner entry steering and less corner exit steering.
More caster gives less corner entry steering and more corner exit steering.
With the Mi Series sedans 4* works best 99% of the time for rubber tire racing on asphalt and carpet.
With foam tires on carpet 6* is the norm. The sedans have so much turn in on foams that the increase in caster has no negative effect on corner entry but certainly increases mid corner and exit steering and corner speed.
Adrian Martinez
Old 02-17-2008, 12:51 AM   #25161
What about foams on bitumein ?
Barger is offline   Reply With Quote
Old 02-17-2008, 04:43 AM   #25162
Thumbs up
Setup for a very bumpy tarmac track using rubbers..
Here is a Set-up that I have finished after testing out 6cell mod,
The set-up also works with 5cell modified.
I would use the stiff top deck for this setup.
http://www.uploading.com/files/H9UI1...setup.pdf.html
Scroll to bottom of the page and wait 10secs then click download.
Kirby Masterman is offline   Reply With Quote
Old 02-17-2008, 08:10 AM   #25163
I agree with Adrian on this one. Losi cars work 180 degrees different set-up wise then other cars. I cant tell you how many Losi drivers I've talk to that had trouble with thier cars initally because of the new learning curve.
Mike Kling
Old 02-17-2008, 08:39 AM   #25164
POUNDITRACING's Avatar
I would also have to agree with Adrian.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 02-17-2008, 06:10 PM   #25165
AdrianM's Avatar
I just won a club race at Adrenalin in Tampa in 13.5 Expert Sedan. I TQ'd by a lap and lapped up to 2nd place...twice in the main
I would have qualified 3rd in 10.5 with my 13.5 TQ run
I will post a setup tomorrow evening. Its PW's Kissimmee setup with a few small changes.
Adrian Martinez
Old 02-17-2008, 06:18 PM   #25166
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
your car was dialed today!! good run !!
Old 02-17-2008, 07:39 PM   #25167
yokemad's Avatar
Do you think is that a good idea to use that on mi3 to secure Lipo against movements?
Do I have to use Battery strap with this?
thanx in advanced
yokemad is offline   Reply With Quote
Old 02-17-2008, 09:37 PM   #25168
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That's the old battery ladder from the original Mi2. I think it'll raise the battery up too high and you won't be able to fit it under the bulkhead. Just take some lead sheet (there's a guy on here, glassdoctor, who sells different thickness lead sheets) and cut it to fill in the cell slots on the chassis. Position the battery where you need it to be and either shoe goo or super glue the lead bars onto the bottom of the battery. Then just use strapping tape to hold it down. You should be fine.
Jon Kerr is offline   Reply With Quote
Old 02-18-2008, 02:11 AM   #25169
Send a message via ICQ to Jan Larsen
Has anyone had troubles pushing the purple diff height adjusting thingys into the bulkhead slots? I've given up on one of mine after trying to pry it into the slot after a diff rebuilt. I'm gonna order a new one and see if that helps.
Jan Larsen is offline   Reply With Quote
Old 02-18-2008, 02:51 AM   #25170
Ian S's Avatar
It will do this if you have one in the high diff position and one in the low position....
Team Schumacher UK
Ian S is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
