Old 02-06-2008, 04:45 PM   #25051
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Thanks for the kind words from everyone and good luck to the Team at the Carpet Nats unfortunetly I wont be able to make it but the asphault nats I will.
Hollywood
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 02-06-2008, 04:47 PM   #25052
abailey21's Avatar
Trader Rating: 36 (100%+)
Ah yes..next year my good man... next year
Originally Posted by Randy Caster View Post
The only reason anyone's cars looked fast at that race is because you chose to sit this one out and let someone else have a fighting chance Adam.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 02-06-2008, 05:02 PM   #25053
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm sure the entries will plummit since everyone will know they just don't have a shot at winning anymore.
Old 02-06-2008, 05:34 PM   #25054
Regional Moderator
Darkseid's Avatar
Originally Posted by MadBrushRacing View Post
Hi Darkseid
Could you post your carpet/rubber set up or email it to me @ madbrushracing@googlemail.com?
Many thanks
Tony
Finally got it done. Took me a little longer since my normal method of saving a setup sheet wasn't happening for me. Anyways, here it is. Its saved as a jpg.
Notes about the sheet and my set up:
-The droop....I hate trying to write down droop because everyone tends to measure it differently. And it tends to translate badly unless thoroughly clarified. The Mi3 sheet makes it a bit easier, but just to be sure, I'll also list it in another popular form "droop over ride height". In those terms, I'm running 3mm front/6 mm rear.
-The "weight" listed along side the Orion 3200 is just to balance the car and bring it to proper rubber tire weight requirements.
-This setup steers hard, while keeping the rear end in line. But if you prefer to throw the rear out a little more, before changing anything setup wise, just take out the front 1mm spacer between the hex and wheel. This narrows the front and gives a little more aggressive steering.
-I'm using all the standard suspension components. No medium arms or alloy hubs or anything like that.
-Oh, and I did use a servo saver...forgot to fill that in.
Thats about it.
TLR 22...Tamiya F104...
Old 02-06-2008, 06:59 PM   #25055
Tomie's Avatar
Trader Rating: 38 (100%+)
Hi guys,
I need some advise. my car is making a clicking sound when I turn. It doesnt make the car slow or I dont even feel anything wrong when Im driving it, Its just making some noise that everyone from the track heard it. lol
Thanks!
OC Circuit: http://socal.rcracing.com
speedtechrc.com
Tomie is offline   Reply With Quote
Old 02-06-2008, 07:05 PM   #25056
Regional Moderator
Darkseid's Avatar
Originally Posted by Tomie View Post
Hi guys,
Thanks!
If you are running the spool, make sure you have the 2mm washers glued to the inside of the steering knuckle. Other wise, your steering will move to far and the universals will start to bind.
Old 02-06-2008, 08:34 PM   #25057
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Tomie- I'm not going to be at BCR This weekend, but if the spacers I showed you didn't do it and you don't figure it out by next Saturday, I'll take a close look next time I'm up there.
Jon Kerr is offline   Reply With Quote
Old 02-06-2008, 08:55 PM   #25058
skypilot's Avatar
Trader Rating: 14 (100%+)
adam, got your stuff, will send it out this week sometime, i'm gonna send it to the return address on the packages i get from you, (but i'll use your name not shawns )
skypilot is offline   Reply With Quote
Old 02-06-2008, 09:46 PM   #25059
Tomie's Avatar
I did put the spacers like Jon told me. It works in a few mins and the noise started again. lol I even polish the cvd's to make it smoother.
ok Jon ill see you next-next week. Thanks!
speedtechrc.com
Old 02-07-2008, 04:25 AM   #25060
Big Features's Avatar
Make sure the blades are not wore out. As the wheel rotates, you blades/bone will "slide" around in the out drive. You might also have a bent dog bone.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 02-07-2008, 05:00 AM   #25061
qcrc's Avatar
Also check to make sure that the pin in the cvd is not loose and the yoke pivots are not screwed in too far. The pin can rub on them if it is sticking out of the bone too far.
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 02-07-2008, 05:45 AM   #25062
MagicMarker's Avatar
Hi guys,
Thanks!
Did you replace anything on the car? Like tires, shock ball cups, arms (front or rear) that may be free when the car is on the bench but as the leans into the corner the sound come around do to something rubbing. Also look at your body, are the tires rubbing against it or are there cracks that may cause the body to work differently in the corners and touch the tires or surface you are running on.
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 02-07-2008, 08:26 AM   #25063
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default snowbirds foam setup
Originally Posted by seaball View Post
i, again, had a new setup on the car that proved to be as quick as those in the past (setup sheet coming).
notes on this one:
- 2 hole front pistons, and heavier rear dampening. this car turned quite well off power, and despite increased dampening from the pistons and oil, had tons of steering. for some reason, the smaller holed piston, the more aggressive the steering is, given the same dampening (on the bench).
- low diffs. cleveland was high, these were low. the car is sharper with low diffs, which i found helpful in the double chicane (switchback) area. you can wrench the wheel more as the car stays flatter.
- 6* (plastic) blocks. the 5* tamales that i love just turned in too hard with this shock setup. both, the additional castor, and the flex of the plastic allowed for a more mild turn-in (transition).
- 33# xray springs. further helped the car slow down on the way in, but steered in the middle.
- longer front link softened the turn-in (reaction) as well.
all in all, it worked great. it was probably the most aggressive of my setups, if only marginally. this setup (lighter rear oil) was quite good at home (the gate) before i left.
again, have at it.
File Type: pdf mi3_setup_sheet_CGOETZ-2008SNOWBIRDS.pdf (382.9 KB, 101 views)
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 02-07-2008, 11:13 AM   #25064
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Seaball there are a few guys with MI 3 cars up here and they would like you to post your dialed setup for Trans Am class .... also what is your body of choice for that class?
wallstreet is offline   Reply With Quote
Old 02-07-2008, 11:32 AM   #25065
POUNDITRACING's Avatar
Hi guys,
Thanks!
Hay, I'm no Jon Kerrrrrrrrrrr but I'll be their on Sat. if you need some help. I have a couple ideas that might fix it. Come and see me.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
