Old 07-11-2002, 06:14 PM   #2491
King-G's Avatar
Send a message via ICQ to King-G
I too can vouch for my schumacher SMH...they are holding up very well, and voltage has increased a little, after traying them.
the new Ultras from schumacher are now in stock at metro.
King-G is offline   Reply With Quote
Old 07-14-2002, 02:48 AM   #2492
BagofSkill's Avatar
If anyone is interested, I fixed the problem with my one way diff by welding (carefully!) the plate back onto the centre axle. I couldn't wait for a replacement. Anyway it worked fine, and I'll never have to worry about that problem again!
Chris Papadopoulos
Team Schumacher Australia
Metro Hobbies
BagofSkill is offline   Reply With Quote
Old 07-14-2002, 09:02 AM   #2493
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
By running rear arms up front, what exactly does it do, for the car?
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 07-14-2002, 09:55 AM   #2494
This allows you to get caster adjustments of less than 6 deg.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 07-14-2002, 06:29 PM   #2495
AdrianM's Avatar
BagofSkill-All of the one ways that habe been avaialbe for the last 2 months have a one piece center section. You Aussie distributor should have one piece center sections for owners of old diffs to retrofit into their front pulleys.
Adrian Martinez
Old 07-14-2002, 09:25 PM   #2496
Taz_S's Avatar
AdrianM: what is the part number for the hop up battery hold down for the A2 and Cat3000.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 07-15-2002, 09:29 AM   #2497
RandyB's Avatar
Adrian M,
I just got a mission.
I have been running the TC3 for 3 yrs in stock class. I was a little nervous to change a new chasis but I am determind to give it a go. I race at Lazer speedway in Adrian Michigan. We run only rubber tires I have all sorex tires made. What I need is a little set up information to start with. the track is long 185' X 60' long sweeping straight that can be taken straight if you set the corner up correctly. next few turns are switch backs into a chicane with an another section that can be a straight if the correct line is given the back into some swtich backs.
any way like i said currently running TC3 with peak hell fire motors reedy 3000hv worlds cells and sorex tires I was thinking of trying to set the car up close to how the tc3 is with assc. springs and all. I just dont know if the Mission will react well or how it will react at all. I guess some testing will be in order I would just like a base line set up and I will inquire from there.
thanks
the car looks cool lets see if i can get it to look as good on the track.
thanks
Randy Butera
RandyB is offline   Reply With Quote
Old 07-15-2002, 10:14 AM   #2498
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
RAndy,
Are you running on carpet or asphalt? Either way, there are some excellent setups on this thread. I would advise you to go back and read as much as you can to learn about the Mission. The two setups you should pay attention to are the carpet one from Rob Love and the Asphalt one from Larry Pryor.
Good luck,
BigDogRacing is offline   Reply With Quote
Old 07-15-2002, 10:46 AM   #2499
RandyB's Avatar
outdoor asphalt I will do some checking on the site but I wanted to find out what schumacher usa had & any body else comments or suggestions. any insight is helpful.
Old 07-15-2002, 11:15 AM   #2500
Trader Rating: 71 (100%+)
Randy, I can get you dialed in on the rug with foams. These guys can get you set on rubber tires....
Take care,
Rob
RBLove is offline   Reply With Quote
Old 07-15-2002, 11:40 AM   #2501
Send a message via AIM to LarryPryor
RandyB
If you will shoot me an emailI can send you the setup I have been running on my Mission.
larry.pryor@s1.com
LarryPryor is offline   Reply With Quote
Old 07-15-2002, 12:07 PM   #2502
Randy- Forgive me for not communicating myself clearly- Adrian and Paul (they ARE Shumacher USA) will most assuredly point you towards Larry and Rob's setups. They are pretty much the starting points for the appropriate surfaces all over the US. These setups come from hours and hours of testing by sponsored Schumacher drivers. Again, if you would go back and read this thread, you would have known that. You wll find a ton of information on this thread- and a lot of it comes from Adrian and Paul.
Happy racing!!
Old 07-15-2002, 12:18 PM   #2503
rcfiend's Avatar
Trader Rating: 26 (100%+)
I recently applied the front roll center modification to my mission, I like the steering or should I say consistent steering. What I don't like about this mod is that my car flips over easily. Before applying the mod I could come close to the corner dots or I could roll over the outer edges of the dots without my car getting to out of shape, but now if my car even looks to close at the dot if flips over. Any suggestions?
rcfiend is offline   Reply With Quote
Old 07-15-2002, 02:19 PM   #2504
Send a message via ICQ to MattW
In general terms i would say that is caused by a combination of too stiffly sprung and or too much pack.
MattW is offline   Reply With Quote
Old 07-15-2002, 08:34 PM   #2505
Pit-racer's Avatar
What is this front roll center modification?
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
