Old 02-01-2008, 03:56 PM   #24991
yokemad's Avatar
Thanx Damian did you see demonrc Lipo pack 5000 only 50pounds and they sells ansmann lipo charger for 35 pounds with all free delivery seems a good deal...
I couldn't find any decent priced decent charger and not sure about balancing stuff 200gr lighter than nimh only this reason worth to try
yokemad is offline   Reply With Quote
Old 02-01-2008, 06:16 PM   #24992
Customworksking's Avatar
Trader Rating: 73 (100%+)
Cool
Originally Posted by Marcos.J View Post
it keeps the rims from rounding off I only run them in the front
Marco R u running @ the birds I looked in every class
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-02-2008, 05:35 AM   #24993
Skiddins's Avatar
A few people at WLRC use the Demon battery packs, i use Core.
The Demon packs seem OK but it's a bit early on to tell how good all these Lipo packs are compared to eachother.
I looked at that charger as well, ended up getting a 'Century UK' one in the end.
We have to add lead as well to make sure all the cars weigh the same in Pro Stock.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-02-2008, 05:42 AM   #24994
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
not this year
Old 02-02-2008, 07:17 AM   #24995
not this year
WTF.......it's in your backyard....I will b down next year
Old 02-02-2008, 07:31 AM   #24996
Regional Moderator
Darkseid's Avatar
For those of you who have been running the spool along with the updated universals for a while, how are they holding up?
This will my first weekend on mine, and I just want to know how brave I can be going into the corners! I'm only running 17.5 BL, so the car wont be going too fast anyway.
TLR 22...Tamiya F104...
Old 02-02-2008, 08:37 AM   #24997
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You'll be just fine. I just put a new set of silver CVD's in my car for the first time since they came out. And mainly 4.5 and 3.5 mod.
Jon Kerr is offline   Reply With Quote
Old 02-02-2008, 09:04 AM   #24998
Regional Moderator
Darkseid's Avatar
Cool. Thanks.
Old 02-03-2008, 11:25 AM   #24999
yokemad's Avatar
does trakpower 4900 lipo fits to mi3? they are now 25c what are the advantages of extra 5c over 20c lipo packs ?
what lipo balancer you guys recommend me
sorry for too many questions
Old 02-03-2008, 11:37 AM   #25000
Tomie's Avatar
Trader Rating: 38 (100%+)
my car likes fly 1-2ft from the air and tumble a few times but never had problem w/the spool or universal and I'm running 13.5
OC Circuit: http://socal.rcracing.com
speedtechrc.com
Tomie is offline   Reply With Quote
Old 02-03-2008, 12:33 PM   #25001
Tomie's Avatar
Most packs' capacities are given in milliamp hours (mAh). You must convert this amp hour (ah) by dividing by 1,000 and then multiplying by the discharge C rating (if its 15C multiply it by 1.5 if its 20C then x 2 and so on)to get the battery discharge rate. For example, a 20C 4900mAh Li-poly can discharge at 9.8Ah, or 98amps. If its 25C the discharge rate is 12.25Ah or 122.5amps. More Amps = more consistent run and overall power. Pls. do check on Mr. Shawn Palmer he will give you a more detailed explanation.
Just dont forget everything goes down to quality of the packs and not just by numbers written on the labels. Ive seen Core lipos perform toe to toe w/other lipos and I'm impress.
speedtechrc.com
Old 02-03-2008, 01:14 PM   #25002
yokemad's Avatar
many thank Tomie Trackpower looks solid overall with 25c....they sell a balancer also...
hope it fits to mi3 :>
Old 02-03-2008, 01:36 PM   #25003
Tomie's Avatar
np and I'm actually using the trackpower balancer myself
speedtechrc.com
Old 02-03-2008, 06:50 PM   #25004
mini-dub's Avatar
Trader Rating: 16 (100%+)
Does anyone have a picture of a Core 5000 pack mounted in their car? I'm just wondering how it fits, where you're putting weight, ect.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 02-03-2008, 07:18 PM   #25005
skypilot's Avatar
Trader Rating: 14 (100%+)
on page 831i posted pictures of a weight system being made by one of the guys at SIR. before that I used to just run 10 blocks of weight down the inside outside of the battery. SIR has some "thin" ones that give you a little more clearance on the belt and pinion gear.
post on the SIR site when you will be down next and i will bring the tray down
skypilot is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
