Old 01-29-2008, 07:21 AM   #24961
Trader Rating: 37 (100%+)
Just wanted to say good luck to all the schui guys at the birds. Wish I could be there, bad timing though. I'll be there next year. Hope everyone has a good time and that Schumacher brings home some hardware.
Bertetto is offline   Reply With Quote
Old 01-29-2008, 10:07 AM   #24962
baf1's Avatar
Default YO WES .....
TRACTION COMES UP.. SPRING LBS GO DOWN...
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 01-29-2008, 01:35 PM   #24963
Skiddins's Avatar
Originally Posted by JayBee View Post
Hey guys what do the U3221 wheel hexes look like?
From the outside, same as the usual items, they have a slot cut into the back for the pin and obviously no groove for the O-ring.
They only problem is they can sometimes get stuck in the wheels and it is easy for the pins to fall out (though not while the wheels are attached.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-29-2008, 02:00 PM   #24964
JayBee's Avatar
Trader Rating: 31 (100%+)
Skiddins
Thanks....I have those, but I don't think they pose an advantage over the stock ones.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-29-2008, 11:45 PM   #24965
They are way better, if you run modified and spool or oneway. With the stock ones and 1mm wheel spacer the contact patch between the wheel & hex is very narrow, only the outer half of the hex makes contact (~1mm width), the inner side actually sits outside the wheel (due to the spacer) and the o-ring groove is wasted space. The result is that when you slightly brush a wall or other immovable object, the hex will cut itself through the wheel quite easily and you'll have a 3WD car. With the U3221 the contact patch is a lot wider (due to no o-ring groove) and this problem doesn't exist.
I only run those on the front axle, never had a problem with the original rears, because the diff will give up instead of the wheel.
olev is offline   Reply With Quote
Old 01-30-2008, 04:02 AM   #24966
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
it keeps the rims from rounding off I only run them in the front
Old 01-30-2008, 03:09 PM   #24967
Snowbirds Round 1.
Goetz in the game...
Position Name # Laps Time Fast Lap-Time
1 Brad Johnson 28 5:03.04 4-10.4
2 Chris Goetz 28 5:03.56 5-10.5
3 Jason Schreffler 28 5:08.30 20-10.6
4 Jeff Cuffs 28 5:10.48 3-10.7
5 Justin Lessard 27 5:00.13 8-10.6
6 TJ Bradley 27 5:01.96 17-10.8
7 Stephen Boice 27 5:03.13 4-10.9
8 Bill Sydor 27 5:03.89 8-10.9
9 Mike Haynes 27 5:05.27 2-10.9
10 Mark Strasnick 27 5:07.10 9-10.6
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-30-2008, 03:13 PM   #24968
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by Nexus View Post
Snowbirds Round 1.
Thats not bad for practice...keep it up Seabass
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 01-30-2008, 03:22 PM   #24969
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
your talking about the practice pimp seaball
but for real
Good Luck Seaball you put in the time, best of luck
wallstreet is offline   Reply With Quote
Old 01-30-2008, 05:13 PM   #24970
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Kick ass sea bass...
Has anyone run both the speed passion Brushless esc and the LRP TC, Just checking the pulse on that deal..
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-30-2008, 05:23 PM   #24971
abailey21's Avatar
Trader Rating: 36 (100%+)
I have run both
Beep beep beep beep <--pulse
You like that, don't you
I almost have your screw kit ready!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-30-2008, 05:54 PM   #24972
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've run both. They both feel very similar on the track. But the adjustability of the Speed Passion is a great thing.
Jon Kerr is offline   Reply With Quote
Old 01-30-2008, 06:15 PM   #24973
JayBee's Avatar
Thanks guys for the wheel hex tips. I guess that's why last summer I had a few 'rounded-out' RP30-36's.
Btw...does anyone see a potential issue with running the lowered shock towers on rubber/carpet?
Old 01-30-2008, 06:59 PM   #24974
rx7ttlm's Avatar
Originally Posted by abailey21 View Post
I have run both
Where are mah screwz!! Are ya makin them yourself? lol try not to let fabulous push you around to much..
Old 01-30-2008, 07:22 PM   #24975
abailey21's Avatar
To be honest i've been bombed lately and I keep putting it off.....on one point unacceptable, but on a different point.. well yeah I'll email you tomorrow
Or call me, but make it late afternoon
K.C.C.O.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
