Old 01-26-2008, 10:55 PM   #24901
Originally Posted by JayBee View Post
I've also noticed that there's two of those set-ups floatin' around; one uses the MI2EC frt. & rear arms and the other, uses the med/flex ones. What's the feedback on the differences?
As far as I am aware they are the same
Barger is offline   Reply With Quote
Old 01-26-2008, 10:55 PM   #24902
Old 01-26-2008, 10:55 PM   #24903
Old 01-26-2008, 11:01 PM   #24904
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The Mi2 arms are carbon fiber but have less materian than the Mi3 arms, so they flex slightly more. The med flex Mi3 arms use the same amount of material as the stock arms but are made from a softer material. I actually thought they felt a bit inconsistant because of how much they flex and prefer the Mi2 CF arms over them.
Old 01-26-2008, 11:14 PM   #24905
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks Randy...'cause I already had the MI2ec arms on (did the sway bar mod) & was hoping I didn't have to change over
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-26-2008, 11:19 PM   #24906
skypilot's Avatar
Trader Rating: 14 (100%+)
picked up the lipo plates last night from verndog, i was going to post a couple of pictures but my laptop took a dump and the new one i bought is vista and my digital camera program won't load. the bottom plate along with the core lipo does touch the bottom of the bulk heads but can be squezzed into place, however, i'm thinking this is gonna change the handling as it affects the chassis flex. i see about getting them up to jaybee for a picture or figure out a new program for the camera.
skypilot is offline   Reply With Quote
Old 01-26-2008, 11:50 PM   #24907
JayBee's Avatar
Hit me up tamarah brah
Old 01-26-2008, 11:59 PM   #24908
skypilot's Avatar
its amazing what you can find when you read the directions'...
hope these turn out ok.
in the picture with the two pieces, the piece on the right is cut out so you can add weight behind the bar before attaching. with my car i didn't need to add weight, i placed the bar to the inside of the battery, and installed the battery with approx 1/8 inch hang over on outside of chassis and it was balanced right to left. as you can see in the one picture it does hit the bulkheads, anyone think that removing about 1mm or so will have any effect on the flex.
Schumacher Corner-dscf0481.jpg   Schumacher Corner-dscf0477.jpg   Schumacher Corner-dscf0480.jpg
Old 01-27-2008, 05:48 AM   #24909
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
abailey: hi adam, you've got mail need help again with parts. thanks!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 01-27-2008, 05:50 AM   #24910
Trader Rating: 16 (100%+)
Send a message via MSN to Jesse Bean
are all the hard case lipo's that thick?
MP9 TKI4
RB6
ZX6
JBRC Products
Jesse Bean is offline   Reply With Quote
Old 01-27-2008, 07:16 AM   #24911
AdrianM's Avatar
I still havent messed around with the 1 degree hubs on asphalt yet, I have the problem of finding a setup I like and not changing it..
Picture this...the 1* rear hubs would have let you enter the tamiya track sweeper without lifting and keep two wheels on the inside paint without full steering lock...you have to try them.
Adrian Martinez
Old 01-27-2008, 07:18 AM   #24912
abailey21's Avatar
Trader Rating: 36 (100%+)
DOOOOD the pinkness!!!!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-27-2008, 09:23 AM   #24913
Trader Rating: 68 (100%+)
Hey Adam what is the part # for the mi3 1 way?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 01-27-2008, 09:27 AM   #24914
haha, if Rheinard had to lift, anyone had to lift
I'll definately get them on the car, maybe even see how they do at the Snowbirds..
Old 01-27-2008, 09:40 AM   #24915
abailey21's Avatar
U2753 off the top of my head??? i'll double chheck at the office tomorrow
K.C.C.O.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
