Old 01-26-2008, 05:06 AM   #24886
MadBrushRacing's Avatar
Default low grip ashpalt track on rubbers
Hi
I will be runing tomorrow on a low grip ashpalt track tomorrow on cs22's.
Should I add or remove spacers on the inner camber link to adjust the height and also on the role center adjustment for the wish bones to gain grip?
also should I use softer springs and shock oil? I have 40w oil f&r and xray white fromnt springs and xray blue green rears.
All help and comments welcome.
Tony
MadBrushRacing is offline   Reply With Quote
Old 01-26-2008, 06:59 AM   #24887
AdrianM's Avatar
Originally Posted by MadBrushRacing View Post
Hi
also should I use softer springs and shock oil? I have 40w oil f&r and xray white front springs and xray blue green rears.
Tony
You are too stiff even for high grip asphalt with your current setup. Drop the oil to 30wt all around and run some 14lb spring all around. Leave the roll centers alone for now and work with more accessible setting like ,oil spring and shock angle.
Adrian Martinez
Old 01-26-2008, 08:06 AM   #24888
Skiddins's Avatar
Hi
Tony
Hi Tony,
I think I currently have 35W front and 30 rear oil (for the cold weather).
Weather is still looking good for tomorrow.
Skidddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-26-2008, 09:12 AM   #24889
thanks for the help.
In low grip do I want the car to roll more? Does raising the inner camber link mounts do this?
What effect does having the diff low/high?
Tony
Skidins - what sort of gearing for a checkpoint 19t for tomorrow?
Old 01-26-2008, 09:22 AM   #24890
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Tony
low grip yes you want more roll.making the camber links more parallel will give you a little more roll, also making the links longer. Longer link will give you grip in corners and in the middle part of the corner.
Old 01-26-2008, 11:31 AM   #24891
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Tony
Lowering the front diff will make the car more aggressive going into the corners, raising it will smooth it out. Raising the rear diff should give you more forward traction, while lowering it should give more side to side bite from my experiences. Because of how much traction the Mi3 has, I almost always run the front diff low, and the rear diff high.
Old 01-26-2008, 11:52 AM   #24892
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Adam I had a couple of 'PINK' paint jobs come in and DOOOD, you're gonna friggin' flip-out!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-26-2008, 04:11 PM   #24893
Skiddins's Avatar
Tony
I gear a blue can Atlas at 5.17.
Never used a checkpoint I'm afraid.
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 01-26-2008, 04:56 PM   #24894
JayBee's Avatar
Originally Posted by Marcos.J View Post
thats a great set up but i think this one is a little better
On PW's 'Bigtrack' set-up, are the stock rear hubs used or the 1-degree ones?
Old 01-26-2008, 06:21 PM   #24895
abailey21's Avatar
Trader Rating: 36 (100%+)
Stock
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-26-2008, 06:23 PM   #24896
Super Moderator
Marcos.J's Avatar
they are the stock ones but i used the 1 degree hubs and the car felt better through the turns
Old 01-26-2008, 07:20 PM   #24897
AdrianM's Avatar
I also like pw's big track kissimee setup with the 1deg rear hubs.....they give more rear rotation mid and exit but with no corner entry loosness. With the hubs I have just over 2.5* toe in per side
Adrian Martinez
Old 01-26-2008, 07:36 PM   #24898
I still havent messed around with the 1 degree hubs on asphalt yet, I have the problem of finding a setup I like and not changing it..
Old 01-26-2008, 08:54 PM   #24899
Big Features's Avatar
I have them on my foam car, DIALED!!
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 01-26-2008, 09:26 PM   #24900
JayBee's Avatar
I've also noticed that there's two of those set-ups floatin' around; one uses the MI2EC frt. & rear arms and the other, uses the med/flex ones. What's the feedback on the differences?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
