Old 01-17-2008, 05:59 PM   #24511
justin lessard's Avatar
Send a message via AIM to justin lessard
Originally Posted by seaball View Post
you keep your mouth shut.
Inform me when you have recieved that box of tanktops
justin lessard is offline   Reply With Quote
Old 01-17-2008, 06:55 PM   #24512
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by JayBee View Post
...Adam, sorry dude; perfect opportunity!!
the fact you have that picture, or knew where/how to find it.........
skypilot is offline   Reply With Quote
Old 01-17-2008, 06:55 PM   #24513
Smile
Originally Posted by Randy Caster View Post
However if you still want me to try a TRF shock, I can put them on the car and see if I can tell any difference.
Go For it!
If You try it then You will know. If you dont try it, you would assume of the conclusion which would be making an ass out of u and me
I thought it made a big difference to the car, and I liked the difference it made, Try it, and if you dont like it then don't do it again. simple
Kirby Masterman is offline   Reply With Quote
Old 01-17-2008, 07:15 PM   #24514
Exclamation
Just remembered,
when I built My TRF shocks, I used the Schumacher Spring Tensionor (the spinning thing the lowers and raises your ride height) on the TRF shocks and Also remember to replace the schumacher ball cuplet screws with the gold ones that the Tamiya comes with other wise they will pop of
Good luck with testing evrybody.
Old 01-17-2008, 07:24 PM   #24515
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
adam/Randy/everyone: i will be running the mi3 in the upcoming TITC and will try my hand at open modified there. i plan to run 5-cell/3.5BL in that race but i will be using the stock chassis. given this limitation, what would be the best position to have my cells - positioned forward or to the back?
i will be using the following equipment: IB4200/4600 cells, LRP Sphere TC, Spektrum Mirco RX, Futaba 9550 servo and a PT ....
i know i can fine tune with properly positioned lead weights around the car but just need a good starting point that most feel gives the best balance. will defenitly position the rx on the battery side but what would be a good config to look at.
thanks in advnace for any suggestions.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 01-17-2008, 07:24 PM   #24516
JayBee's Avatar
Trader Rating: 31 (100%+)
If you only knew
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-17-2008, 07:32 PM   #24517
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
foward, i have a spare 5 cell chassis if you need one
with the 5 cell chassis put the transponder in front of the battery , receiver in the rear of the battery, i have a picture somewhere i just need to find it.
here is a picture of PW's car
Old 01-17-2008, 07:33 PM   #24518
jonny.dronfield's Avatar
hi,
this is a good question. prior to the DHI CUP we (schuey uk) did a lot of playing with chassis. moving the cells forward, backwards in out etc. the guys finally decided on a 5 cells chassis with the cell positioned same as the 6 cell in the front, but 2mm further out away from the centre (if that makes sense) all our cars looked pretty good with this setup, so off we went to the dhi with our new chassis. to find when we got there that jonas andersson runs the 6 cell chassis with the cells at the rear, his car looked good also. so i think its more personal preferance than if one is faster than the other. i know this doesnt answer your question at all and has confused you even more, lol.....sorry
jonny
Schumacher UK
jonny.dronfield is offline   Reply With Quote
Old 01-17-2008, 07:49 PM   #24519
Johns right,
But simply putting your batteries forward will be easy to set-up, if u want more of a challenge, you could put the cells towards the back.
I might be going to the TITC
I say 'Might' because The entries were closed so I sent a late entry form to the guy organizing with added apologies and he sent and email back saying "OK" lol i hav no idea whether I've been entered or not
If i do end up going I can lend you one of my chassis's,
The biggest thing with 5cell mod is balancing the car, my mate has put his ESC on the side of his batteries with a 6cell chassis, I dont really agree with this because you have just taken weight away from the other side of the car,
I myself have put my transponder and reciver on the side of the batteries and glued my wires to the chassis to try and get a low center of gravity.
Coming back to the TRF shocks on a schumacher,
I forgot to tell you that you have to put a sleeve on the post so that the shock doesnt riggle around.
Old 01-17-2008, 07:49 PM   #24520
MagicMarker's Avatar
Poor Doggie!!!
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 01-17-2008, 08:06 PM   #24521
PW
PW's Avatar
Send a message via AIM to PW
I found that the battery forward gives more on-power steering and less initial. Battery back is the opposite.
I also liked the 6-cell chassis with 5-cell, but ran the 5-cell chassis because my wiring job came out so nice once I put it on
That car in the pic was dialed
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 01-17-2008, 10:02 PM   #24522
ROBORAT's Avatar
Marocs/Johnny/Kirby/PW: this is all great info guys! also aware that at the end it will be a "feel" kind of thing in the end and knowing what one position does over the other is a big help. Cant wait to start testing next weekend with this set up. big thanks!
Kirby: hope you can make it to TITC. would be good to have a fellow shuie guy there to work out set ups with. as it is there's only one guy listed with an mi3 from OZ. thanks for the tip! and see you there if ever ... suggest you email that guy again. I know for a fact that one of the guys listed in the entry list is surely not going to go (Jason dela Cruz) as somthing came up and he will have to beg off. If you want, maybe i can ask my buddy jason to email the guy at TITC to advise him of his pull out and if you want to take the slot. maybe you can email me you addy so he can copy (cc) you in the email. lemme know!
PW: this helps alot! will keep that in mind when i do testing. btw, the pic below ... is that your reedy car? just checking since i have the set up as a baseline. also, AdriaM mentioned you had some new killer mod/asphalt set up ... care to share? an email would be great ([email protected]) ... thanks again for the help!
Old 01-17-2008, 10:11 PM   #24523
I'll let ya know what happens,
Old 01-17-2008, 10:19 PM   #24524
Randy Caster's Avatar
Trader Rating: 46 (100%+)
What length ackerman arm did you use on your Cleveland setup, med or short?
Old 01-17-2008, 10:23 PM   #24525
Randy, you run these on carpet? Does HPI have springs in the 23-35lbs range?
Sorry I was referring to rubber tire, for foam I think most run XRay or AE springs.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
