Old 01-15-2008, 08:10 AM   #24451
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm afraid of what Chris would have a PhD. in... jumping jacks maybe?
Old 01-15-2008, 12:40 PM   #24452
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Can you take the heatsink off the GT speedo. Is that like the LRP where it just has double sided tape holding it on there.? I want to get the heatink off but I don't want to scratch the casing or start prying unless I know for sure.
Sigearhead is offline   Reply With Quote
Old 01-15-2008, 04:13 PM   #24453
Skiddins's Avatar
Anyone know how much Jimmy's DHI setup differed from the Vegas one, apart from 5 cells?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-15-2008, 06:55 PM   #24454
abailey21's Avatar
Trader Rating: 36 (100%+)
New top deck??
Maybe Jimmy willl post it on here, or have Chris add it to the website??
Skiddins
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-15-2008, 08:23 PM   #24455
Micro-Man's Avatar
HI to all you schuie team mates....just wanted to introduce myself to the team as a new member. I have been out of 1/10 touring for about three years now but have run my Mi2 at different events along the way. I have been running Micros on a national level for that period...Now back in with the Mi3 and starting back by running at the Birds race so I can achieve as much knowledge as I can with all of you guy being together at the same time. I will be running in both 27t and outlaw classes. Would you guy please give me some feed back on some questions about set up for the Snowbirds. Five or Six cell chassis, top deck, standard or lower shock towers, diff or one-way, and anything else you care to add....just a few days to practice and dust off the cobwebs so any advice will be appreciated.....Looking forward to see all of you at the Birds....
Thank you,
Wesley Dennis
A.K.A. "Micro-Man"
Many Thanks to all my great sponsors:
CASTLE CREATIONS / MAXAMPS.COM / GQ AMERICA / PARMA / THETOYZ.COM / EXOTEK / TEAM SCREAM / BROWN ENGINEERING / BIG SQUID RC / SK MOTION / HB TEAM DRIVER
"MICRO RACING FOR LIFE".....SUPPORT YOUR LOCAL TRACKS AND HOBBY SHOPS
Micro-Man is offline   Reply With Quote
Old 01-15-2008, 10:00 PM   #24456
artwork's Avatar
Trader Rating: 61 (100%+)
I seem to be tearing through my plastic servo gears with my MI3...does anyone know of a good servo saver that fits well in the car with a JR servo?
The kit servo saver looks less then high performance...
Thanks,
Art
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 01-15-2008, 10:25 PM   #24457
Thank you,
Wesley Dennis
A.K.A. "Micro-Man"
Assuming 27 turn is on rubber tires you should be pretty good with everything out of the kit. If you need more traction Mi2 arms will help. More steering use a front 1-way. Jimmy Maddison's IIC setup would be a good starting point. Either of those classes you'll want 6 cells.
Old 01-15-2008, 10:26 PM   #24458
Thanks,
Art
Kimbrough makes the best servo savers from what I understand, but might want to upgrade to a metal gear servo when you can.
Old 01-16-2008, 01:27 AM   #24459
CA
Jimmy's and my own set up will be added to the Schumacher website today.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
Old 01-16-2008, 04:41 AM   #24460
Skiddins's Avatar
Woo hoo, though Schumachers Tech section appears to be down at the moment.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 01-16-2008, 05:54 AM   #24461
Regional Moderator
Darkseid's Avatar
Thanks,
Art
Heres what you need. Kimbrough Servo Saver Mid-size w/o holes
I recommend the one without holes because you can then put the hole where ever you want it instead of being stuck with the pre-drilled holes. In the case of the Mi3, you may want to make the hole slightly higher than the highest hole outline the servo has. This will get you a little closer to the original servo arm height.
But like Randy said, you definitely want a aluminum gear servo. Doesn't have to be fancy, just something good. JR makes a $39.99 metal gear servo thats good enough that I use it for the steering in my nitro. So thats a solid option for you.
Hope this helps.
TLR 22...Tamiya F104...
Old 01-16-2008, 06:06 AM   #24462
Thank you,
Wesley Dennis
A.K.A. "Micro-Man"
hey man,
I use the 5cell chassis plate because its wider then the 6cell chassis plate
I recommend the top decks for these conditions:
Stiff top deck - high grip tracks or bumpy tracks
Standard top deck - good starting point works well with anywhere
Flexi top deck - Low grip tracks
Lower shock towers are only good for carpet racing and are no good at tarmac.
Replace the Schumacher Shocks with TRF shocks,
Get rid of the schuey springs and dive straight into the HPI springs.
Welcome to the team
Kirby Masterman is offline   Reply With Quote
Old 01-16-2008, 06:17 AM   #24463
abailey21's Avatar
Thanks Chris
Saved me the email
And welcome to the team Wes!
K.C.C.O.
Old 01-16-2008, 06:19 AM   #24464
abailey21's Avatar
What model JR is that if you don't mind sharing your secrets?
Hope this helps.
K.C.C.O.
Old 01-16-2008, 07:07 AM   #24465
Originally Posted by Kirby Masterman View Post
hey man,
Welcome to the team
Both classes he is running at the snowbirds allow 6 cells, so the 5 cell chassis wouldn't be good.
Just wondering because I've never had a problem with the Mi3 shocks, why would they need to be swapped out for the TRF shocks?
The HPI springs are pretty good on carpet, but because they have so many coils they make the car feel a bit lazy, if your car is twitchy they are definately an easy fix but Tamiya springs feel somewhere right in the middle of the Schumacher springs and HPI springs so I generally start with those.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
