Old 01-11-2008, 02:42 PM   #24361
Regional Moderator
Darkseid's Avatar
I can understand why people would want smaller spurs just so they wouldn't have to use giant pinions, but I don't see why the current 96t would stop anyone from being able to make as low a gearing as they would ever need.
I'm running 17.5BL rubber right now, and that requires a final drive of around 4.00 and a rollout in the area of 48-50mm just to be in the conservative range. So with the 96t spur, that means something in the range of 42t-44t pinion.
Yeah, its annoying to have to run those large pinions, but even with something as large as those, the wonderfully designed Mi3 motor mount still has plenty of room for larger ones, and even lower final ratios.
I just can't see a ratio that someone would need to hit that they wouldn't be able to get to with the 96t spur and the Mi3's motor mount.
With that said....wheres our 90t-92t-94t spurs at???
TLR 22...Tamiya F104...
Old 01-11-2008, 02:48 PM   #24362
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Well, first, you would have to be able to actually GET a Schumacher 96t spur.
Then, I think it would be something most people would be interested in to avoid buying pinions 40-50t for no real reason. Larger pinions, more rotating mass, belt/pinion interference, and just the general pain of having to use uncommon pinions and spurs would all be nice reasons to have a different internal pulley ratio. I'm sure there are more reasons that I'm not thinking of, but those mentioned are worth the trouble in my opinion.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 01-11-2008, 02:48 PM   #24363
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
looks like McGoo (bald guy) is adjusting Marker (hairy guy)
Old 01-11-2008, 03:05 PM   #24364
Regional Moderator
Darkseid's Avatar
Ohh....okay. I didn't realize that the 96t spurs had become hard to come by.
I don't know if you've noticed, but since the launch of 13.5 motors and especially now the 17.5, its the pinions below 40-50t that have become the "uncommon" size. I haven't used anything below 38 since I started running brushless, and I prefer to gear in the conservative range. And thats with me using a tiny 90t spur on my TA05 back in the day. I mean seriously, have you guys seen some of the pinions that the JRX-S Type R and Cyclone guys have to run!!! Those things are nearly spur gears!
Heck, I considered us Mi3 users lucky to only have to be in the low to mid 40t range.
Old 01-11-2008, 06:01 PM   #24365
Randy Caster's Avatar
Trader Rating: 45 (100%+)
I didnt see the need for such a small spur gear either until I put a 10.5 motor in my car and realized it was crammed right against the ESC.
It isnt that the 96 spurs are hard to come by, its that they arent yet out. They should become available early Feb and should be easy to get at that point.
Old 01-11-2008, 06:03 PM   #24366
Originally Posted by seaball View Post
~ proper preparation prevents piss poor performance ~
i propose that jaybee (sweet jerome, as he likes to be called) goes over every team driver's car before each big event. new mounting, new wiring, and whatever balancing he deems necessary. it should be mandatory that all team cars look like (or near) those that jaybee has shown us. simply awesome, sir.
then, the cars will be shipped to randy caster (aka - randall 'the vandal' caster) , where he will properly shim and align them.
meanwhile, mcgoo's painting up shells for each of us (since jaybee's already busy stripping wires) ...
finally, the finished package will meet their owners at the race track, ready for battle.
so, what do think about this adam? can you mandate this? we'd be alot better off, let me tell you. instant demotion/suspension for anyone caught with a rat's nest or air in their shocks? what do you think?
You forgot the step where everyone sends their aluminum to Chris Goetz for a fresh coat of black anodizing.
Old 01-11-2008, 06:09 PM   #24367
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That's the step I'm most interested in.
Jon Kerr is offline   Reply With Quote
Old 01-11-2008, 06:48 PM   #24368
Send a message via AIM to Kave
You are a very smart man! Lets take a majority vote!
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | McFactory | Lake Superior RC Car Club | www.lsrcc.com
Kave is online now   Reply With Quote
Old 01-11-2008, 06:49 PM   #24369
Still coming to BCR tomorrow? I need to check out that SP ESC in person..
Old 01-11-2008, 06:52 PM   #24370
I think they are already out Randy. I have about 4 spares in my box and one in each of my cars . . .
Maybe thye went through thier stock faster than expected and will be getting more, in early Feb???
Old 01-11-2008, 07:12 PM   #24371
Trader Rating: 15 (100%+)
Default layout
Heres what i came up with for layout on wiring.
AARON YOUNG is offline   Reply With Quote
Old 01-11-2008, 07:48 PM   #24372
JayBee's Avatar
Trader Rating: 31 (100%+)
How's the front to rear balance though
How do you like these #'s Randy
Originally Posted by JayBee View Post
Hey guys, do you fret over balancing your cars? I do
I use the four scale method and balancing the car yesterday, here's the numbers-
Left side
LF- 350g/ LR- 333g = 683grams
Right side
RF- 341g/ RR- 345g = 686grams
Cross weights (L-R)
LF- 350g/ RR- 345g = 695grams
Cross weights (R-L)
RF- 341g/ LR- 333g =674grams
Front to Rear %'s
LF (350g) + RF (341g) = 691grams - 50.5%
LR (333g) + RR (345g) = 678grams - 49.5%
Overall, I'm happy how it turned out but I'm not satisfied with the Cross weights. I got some more work to do.
Any suggestions?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-11-2008, 07:50 PM   #24373
JayBee's Avatar
Originally Posted by Skiddins View Post
Is it me, or is the plastic part above the bumper that says Schumacher, bent in your photo?
Skiddins
Jealous!! That's the new hotness brah
Old 01-11-2008, 08:07 PM   #24374
JayBee's Avatar
..That's the funniest/best post I've seen in awhile!!!...
I owe you one for using my real name w/'SWEET' in front of it...no sweeteners nor additives added here brah *as I'm waggin' my hand atcha*
Old 01-11-2008, 08:18 PM   #24375
Jon Kerr's Avatar
Yeah I'll be there with FD and Ray Ray.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
