Old 01-02-2008, 10:18 AM   #24196
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
That would be awesome, Jon. I really appreciate it.
doug
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 01-02-2008, 11:53 AM   #24197
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Front Overdrive
Any one know if using front over drive w/ spool will wear your front tires faster?
yyhayyim is offline   Reply With Quote
Old 01-02-2008, 12:56 PM   #24198
Super Moderator
Marcos.J's Avatar
Trader Rating: 161 (100%+)
i think PW mention a while ago that it over heated the front tires.
Old 01-02-2008, 12:58 PM   #24199
Super Moderator
Marcos.J's Avatar
here it is
Originally Posted by PW View Post
I tested the overdrive pulley last weekend on a big nitro track. The track was super hot and over heating tires was a major issue. The overdrive pulley made the tires over heat much faster and it was harder to drive once they did over heat. It also made the car steer multiple times in high speed corners. I personally didn't like it in the heat and on a big track.
Old 01-02-2008, 04:04 PM   #24200
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I have been running overdrive on every track I've raced at so far ever since my first race with the Mi3 (Reedy Race) and I think everyone there that saw my first test run with the overdrive pulley would say the improvement for me was night and day, went from a couple 12.9's to a bunch of 12.7's and a 12.6.
For my driving style, overdrive is a must have, but my setups are generally pretty different from everyone elses. We havent had a whole lot of super high temps out here in CA since I've been running the Mi3, so I really havent tested on super hot tracks (160F +) but I'm sure the front tires would definately overheat in those conditions.
With my Reedy Race setup, the tires wear fairly evenly. If the car is double steering, we found that it had a lot to do with the rear shock pack. Going to 2x1.2 pistons and heavier oil solved the problem quickly, although I have been going lighter and lighter with no problems.
Old 01-02-2008, 04:20 PM   #24201
AdrianM's Avatar
Keep in mind that Randy likes STEERING and he is a wheel. Many of us would have severe problems hanging on to his car for 5 min but he is super fast with it.
If you want to try overdrive make sure you are running Randy's setup in its entirity...no fudging this or that or it wont work at all. Overdrive is not something you can just throw into your current setup and expect to work.
Adrian Martinez
Old 01-02-2008, 04:41 PM   #24202
STLNLST's Avatar
Trader Rating: 19 (100%+)
is that the same Randy that locked his keys in the car at the host hotel at the Reedy race a couple of years ago......LOL
STLNLST is offline   Reply With Quote
Old 01-02-2008, 04:45 PM   #24203
Trader Rating: 68 (100%+)
Shawn P. you got pm
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 01-02-2008, 04:50 PM   #24204
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I remember that. What you forgot to mention was the car was still running.
Jon Kerr is offline   Reply With Quote
Old 01-02-2008, 08:28 PM   #24205
Trader Rating: 36 (100%+)
Originally Posted by JayBee View Post
So in your opinion, go up on one or the other?
I think when running the GT ESC you should do minor or one change at a time. From what I understand now the timing will increase RPM so going up in pinion at the same time will make it harder to judge the adjustment.
On a side note....any news from Adam/Shawn on the 90T Spur?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-02-2008, 08:58 PM   #24206
skypilot's Avatar
Trader Rating: 14 (100%+)
www.liverc.com jb and ritchie on in about 5 mintues, SIR track, speedpassion 10.5 and gt esc's jb on foam, ritchie on rubber
skypilot is offline   Reply With Quote
Old 01-02-2008, 09:00 PM   #24207
And the gas light had been on for 10-20 miles... perfect. lol
Old 01-02-2008, 09:03 PM   #24208
Actually because the RROC setup was on a big track it isn't too terribly aggressive. I haven't posted any of my current setups because honestly whenever people try my setups they hate them, lol.
I was the guy at the IIC running 1mm of anti-dive, overdrive on a 1-way, and saucing the entire front tire and sidewall while everyone else was saucing the inner 1/2 of the tire, lol. Doesnt work for most.
Old 01-02-2008, 09:11 PM   #24209
Good qual for the Schuies, JayBee and Ritchie 1-2, good job guys!
Old 01-02-2008, 11:32 PM   #24210
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks Randy The Main finished up in the same fashion; Ritchie's rubber car is FAST!!! I think Adam gave him the 'cheater' SP10.5
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
