Old 01-01-2008, 04:40 PM   #24166
Send a message via ICQ to Jan Larsen
The rear arms on a Schumacher has always been weak, thats no news. Just stock up on them and you're ok (they aren't that expensive).
Myself; I've only broken 1 front arm after t-boning a poor guy and his TA04 on a 50mph straight.
But the rears go very easily. The slightest pressure to the back on the car (crash or similar) and the rears snap. And they usually take the hing pin with them (they bent).
CVD's snapping are not new either. Anyone who uses large steering throws are more susceptible to breaking theirs. Use less steering throw and lube the CVD's with chain oil. I haven't broken one on mine yet.
Jan Larsen is offline   Reply With Quote
Old 01-01-2008, 04:43 PM   #24167
Regional Moderator
Darkseid's Avatar
Originally Posted by dawgmeat View Post
would be nice to have some balancing holes in the GOTDAMM chassis
I made my own in my chassis. I've done it on all my cars since one of my nitro cars came with balancing holes and pegs. I saw how useful the ballancing holes were, so I decided that if a car didn't come with them already, I would put them on.
All I did was measure the width of the front and rear of the chassis and then put the hole right on the center line of the chassis. Heck, it doesn't even have to be a full hole. Just a reasonably deep circular divot that the balancing pegs can rest in properly. I usually start the 'holes' with a sharp X-acto knife, then finish them nicely with a small drill bit.
Any time a car doesn't come with the balancing holes, I make adding them part of the usual pre-build chassis prep.
If you do it prior to building though, just make sure you remember which side of the chassis is down! I wont go into how I learned this lesson
TLR 22...Tamiya F104...
Old 01-01-2008, 04:54 PM   #24168
dawgmeat's Avatar
I must be lucky because I've bent Hinge pins before I ever broke a rear A-arm, oh well gotto break something
dawgmeat is online now   Reply With Quote
Old 01-01-2008, 05:45 PM   #24169
Big Features's Avatar
I havent had any issues with rear arms at all. I'm still runnig the kit's rear arms a year later
Mike Kling
Team Associated • REEDY Powered
JConcepts • TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 01-01-2008, 05:46 PM   #24170
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Weak rear arms are news to me, I've only broken 1 since I've been driving the Mi3, and I run the Mi2 arms with less material on them.. it was a hard hit that broke it.
Old 01-01-2008, 05:52 PM   #24171
Anything will break if the hit is hard enough. The rear arms on Schumacher toures have been known to break if you hit something solid backwards, at an angle. Has happened to me a few times on the two cars I have. And tons of times on a mates of mine, but he also crash a lot...
Old 01-01-2008, 06:12 PM   #24172
Get rid of that reverse speed control, these cars are meant to go forward
Old 01-01-2008, 06:14 PM   #24173
Just look for the side with the countersinks in the chassis.
I do the same thing on all of my cars, definately comes in handy for tweaking the car since I havent had the best luck with the tweak stations in the past.
Old 01-01-2008, 06:17 PM   #24174
Originally Posted by Thomas P View Post
Any ideas why my friends front left CVD always snapp off´s? Every single race the cvd will snapp. No crashes,just driving. There must be some other materials for this?any other that will fit and hold? He is in need of this, if there is no solution for this, he might change brand.
That is definately weird, I've never seen an axle break out my way. What are you using to lubricate the CVD's?
Old 01-01-2008, 06:18 PM   #24175
dawgmeat's Avatar
At least your breaking A-arms and not bending front CVD'scome to think of it I've bent about 5 front cvd's and broke 1 front a-arms
Old 01-01-2008, 06:25 PM   #24176
abailey21's Avatar
Trader Rating: 35 (100%+)
Thats because you hit everything in sight, too include innocent bystanders ankles
I keed I keed...talk to you this week sometime
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 01-01-2008, 06:59 PM   #24177
AdrianM's Avatar
Rear arms breaking...thats weird. The rear arm sales were never very high in the US for Mi-Series sedans. We would crack, but not break, front arms pretty frequently. The Mi3 front arms fixed most of this and it never happens with the Medium or Ultra flex front arms.
Adrian Martinez
Old 01-01-2008, 07:20 PM   #24178
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Adam,
Do u have any p-dub car stands in stock? They are listed on the web site but doesn't say if u have any in stock. If not when will u have some?
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 01-01-2008, 07:42 PM   #24179
Trader Rating: 36 (100%+)
Novak Warmup.
Nice to meet Customworkings and MagicMarker today. Derrick Englund was in attendance today as well. I know Magic and Derrick made the A today in 13.5 Rubber. They looked very good.
Kevin Kane, Rich Murphy and a few others will be up there after today...Good luck to everyone.
Thanks to Shawn for answering your phone today for the Speed Passion help Since I was not running Novak I tested a bunch of setting w/ timing and punch. Now I just need to figure out the setting that will last 5 minutes :P
Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-01-2008, 07:49 PM   #24180
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Originally Posted by Nexus View Post
Novak Warmup.
Yeah, what the heck were you doing to your poor car today?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
