Old 12-22-2007, 10:34 AM   #23986
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Just don't run a servo saver. I haven't had a servo saver on it from day one. Most savers that mount on the servo and aren't integrated into the steering system will do just what you're describing. They're just too soft.
Jon Kerr is offline   Reply With Quote
Old 12-22-2007, 11:03 AM   #23987
John_S's Avatar
ok thanks john
John_S is offline   Reply With Quote
Old 12-22-2007, 03:13 PM   #23988
Randy Caster's Avatar
Trader Rating: 46 (100%+)
No BCR today Jon?
Old 12-22-2007, 03:36 PM   #23989
Maybell's Avatar
Originally Posted by Randy Caster View Post
No BCR today Jon?
14,000 posts!!!!!!!!!!!!!!!
DORK!j/k
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 12-22-2007, 03:44 PM   #23990
dawgmeat's Avatar
Originally Posted by AdrianM View Post
I do not run my Core pack in the same place as a 6 cell NiMh pack. I run my Core even with the edge of the chassis. This reduces the weight needed to balance the car left to right by A LOT!
I use double sided Scotch brand tape on the carbon ribs between the cell slots. This tape is just as thin as normal Scotch tape but it has adhesive on both sides. This keeps the packs from shifting in the car. I then run a band of strapping tape around the normal slots to hold the pack in place.
If I need to change gear ratios I remove the strapping tape and pop the pack off the chassis. The scotch tape is good for 3-4 batt removals before you need to replace it. You can peel it off the classis and the pack and remove residue with motor spray.
how much wieght do you use by using this method
dawgmeat is offline   Reply With Quote
Old 12-22-2007, 07:01 PM   #23991
Big Features's Avatar
Originally Posted by John_S View Post
Hey guys im having a problem with my mi3 in that i cannot get it to track straight. What do you guys use on your servo? The servo saver that comes with the kit, a std servo horn or an aftermarket saver? I have tryed all 3. I ended up with a kimbrough servo saver and that was the best. But the car would track difrent everytime i got it onto the straight for the next lap. I know its not my servo because i got fed up of the mi3 not tracking right and then went back to my mi2 with the same electrics and it was perfect.
I run the big OFNA one. It is alittle over-size, but it is strong and works great!
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 12-22-2007, 07:42 PM   #23992
AdrianM's Avatar
I run a monster servo (Airtronics 94360) and just the rigid arm.
If you car is not tracking straight check the following.
1. Are both of your steering hubs pivoting freely in the c-hubs?
2. Is there bind in any of your suspension arms? Everything should be free with no resistance at all.
2. Is your car tweaked properly on a balance beam type tweak station?
3. Is your droop equal left to right?
4. Are all your brearing and drive shafts free?
Adrian Martinez
Old 12-22-2007, 07:57 PM   #23993
I dont really see the need for servo savers if you have a good racing servo. I havent stripped a servo gear since I was running a Traxxas Rustler up and down the street nearly 11 years ago.. never had a good servo strip a tooth in a TC.
Old 12-22-2007, 07:59 PM   #23994
I tried that, but I ended up breaking the ears off the servo and breaking the case.
Mike Kling
Old 12-22-2007, 08:39 PM   #23995
JayBee's Avatar
Trader Rating: 31 (100%+)
...nevermind
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-23-2007, 06:57 AM   #23996
Skiddins's Avatar
Originally Posted by steve eaves View Post
Anyone have any pics of the core battery in their car?i just ordered one with a battery strap curious if any modifications are necessary,thanks
I only elongated the hole with the balance tap to make sure it didn't rub against the bulkhead.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-23-2007, 08:14 AM   #23997
Trader Rating: 69 (100%+)
Thanks for pics and ideas,should have mine next week.
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 12-23-2007, 09:56 AM   #23998
Man I feel bad for your servos lol
Old 12-23-2007, 10:26 AM   #23999
Jon Kerr's Avatar
No BCR today Jon?
No. I wanted to but I was too damn tired to drive that far in the morning. Poker at my house Friday night ended up being an all nighter. Didn't end up in bed until 4:30AM. Dogs woke me up at 9 and I couldn't get back to sleap. I went to Revelation last night w/ Donny.
Old 12-23-2007, 12:28 PM   #24000
How hammered did Patrick get? lol
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
