Old 12-21-2007, 12:14 PM   #23971
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Randy Caster View Post
I use shoe-goo all the time to glue down electronics or wires, it doesnt dry instantly so just wipe the excess away. If you got it on there good you'd never have to worry about ejecting a pack.
I have lead weights on my pack that's a snug fit down in the battery slots & I just tape my lipo down. My lipo isn't going anywhere. Shoe-goo'n the lipo in the car will be a bit cumbersome when it comes to working on the car...not a good solution.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-21-2007, 02:36 PM   #23972
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
For the people with only 1 pack, why not just shoe-goo it into the car?
*good-natured ribbing*
Its called gearing up Randy! . . .sheesh . . you might wanna try it sometime.
J/K
seriously J/K
You have to remove the battery to change the pinion. Us foam guys gotta wrestle with rollout
Old 12-21-2007, 02:43 PM   #23973
qcrc's Avatar
I just bought myself a Mi3 and I remember a while back that there was a thread about the build. Does anyone have a link for that or is there anything I should know before I start? Is it straight forward like the Mission, Mi2, and the EC? Also what are the hot carpet rubber setups? Thanks
qcrc is offline   Reply With Quote
Old 12-21-2007, 02:50 PM   #23974
abailey21's Avatar
Trader Rating: 36 (100%+)
Let's Build a Schumacher Mi3!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-21-2007, 05:21 PM   #23975
AdrianM's Avatar
I do not run my Core pack in the same place as a 6 cell NiMh pack. I run my Core even with the edge of the chassis. This reduces the weight needed to balance the car left to right by A LOT!
I use double sided Scotch brand tape on the carbon ribs between the cell slots. This tape is just as thin as normal Scotch tape but it has adhesive on both sides. This keeps the packs from shifting in the car. I then run a band of strapping tape around the normal slots to hold the pack in place.
If I need to change gear ratios I remove the strapping tape and pop the pack off the chassis. The scotch tape is good for 3-4 batt removals before you need to replace it. You can peel it off the classis and the pack and remove residue with motor spray.
Adrian Martinez
Old 12-21-2007, 05:25 PM   #23976
Customworksking's Avatar
Trader Rating: 71 (100%+)
go to shouies web site and get Jimmy's iic setup
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-21-2007, 10:01 PM   #23977
artwork's Avatar
Trader Rating: 56 (100%+)
Can anyone point me in the right direction for a Foam tire carpet setup? At least a place to start would be great!
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 12-21-2007, 10:10 PM   #23978
same as I said ^^^^ any iic foam setup is good
Old 12-22-2007, 12:11 AM   #23979
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Chris Goetz' Cleveland setup was said to be awesome on the track
Old 12-22-2007, 12:12 AM   #23980
J/K
seriously J/K
I'm used to 3.5's... geared 23/118 is perfect for me
Old 12-22-2007, 12:22 AM   #23981
JayBee's Avatar
Adrian, how much weight are you actually adding to your lipo to balance the car out? My Core is flush with the chassis but the weights added to it is hanging 'outside' the by as much. Brett Sisley took a look at my car and the car was balanced dead nuts L to R & Frt. to Back. My only discrepancy is the weight on the four corners. Not by much but enough to bother me
Old 12-22-2007, 12:37 AM   #23982
qcrc's Avatar
Smile
Adam, thanks for the link. I sent you an email and I hope that you can help with that just as fast.
Old 12-22-2007, 06:18 AM   #23983
abailey21's Avatar
I cant do anything until Wednesday of next week, but I'll make sure I get you taken care of as soon as I get back to the shop, mail me that one back when you get a chance.
K.C.C.O.
Old 12-22-2007, 07:21 AM   #23984
qcrc's Avatar
That I can do. Thanks
Old 12-22-2007, 09:49 AM   #23985
John_S's Avatar
Hey guys im having a problem with my mi3 in that i cannot get it to track straight. What do you guys use on your servo? The servo saver that comes with the kit, a std servo horn or an aftermarket saver? I have tryed all 3. I ended up with a kimbrough servo saver and that was the best. But the car would track difrent everytime i got it onto the straight for the next lap. I know its not my servo because i got fed up of the mi3 not tracking right and then went back to my mi2 with the same electrics and it was perfect.
John_S is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
