Old 12-21-2007, 05:15 AM   #23956
Trader Rating: 69 (100%+)
Anyone have any pics of the core battery in their car?i just ordered one with a battery strap curious if any modifications are necessary,thanks
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 12-21-2007, 05:53 AM   #23957
Skiddins's Avatar
I'll take a couple of pics later.
I only elongated the hole with the balance tap to make sure it didn't rub against the bulkhead.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-21-2007, 06:11 AM   #23958
abailey21's Avatar
Trader Rating: 36 (100%+)
The alloy battery posts come with 1mm spacers, add 2mm more for a total of 3mm spacers under the post and servo tape the CF strap to your pack and you should be good.
We also shaved a bit off the end of the case so we could easily clearance the balance plug, I'll try and find some pics today.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-21-2007, 07:21 AM   #23959
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I have had problems with tweaking when using battery braces and lipo's in sedans. I eventually ended up with a permanently tweaked chassis. I have had a lot of success with no tweaking using lexan keys taped to to the bottom of the lipo and battery tape to hold it down.
Old 12-21-2007, 07:26 AM   #23960
abailey21's Avatar
If you use 3mm of spacers as opposed to the 1mm that the strap kit comes with there will be no tweak because your not stressing the chassis at all, the cf strap is completely level.
I run 3mm of spacers under the posts, and Shawn runs 3.5mm we have no problems at all.
K.C.C.O.
Old 12-21-2007, 07:34 AM   #23961
Randy Caster's Avatar
Trader Rating: 46 (100%+)
For those using LiPo, do you guys just run 1 pack and keep recharging, or do you have multiple packs like you would with regular cells?
Old 12-21-2007, 07:39 AM   #23962
abailey21's Avatar
I only use one pack and top is back off after each race.
Scrooge Palmer wont let me have 2
K.C.C.O.
Old 12-21-2007, 07:48 AM   #23963
JayBee's Avatar
Trader Rating: 31 (100%+)
Same with me...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-21-2007, 09:06 AM   #23964
Sounds good thanks.
SpeedZone Batteries
Old 12-21-2007, 09:12 AM   #23965
AdrianM's Avatar
You only need one if you are running one class. If you are a serious racer you need the time to prep and warm your tires and let you motor and speedo cool off. It only takes 20-30 min to top of the pack.
If I were you at a big race I would have a spare just in case.
Adrian Martinez
Old 12-21-2007, 09:40 AM   #23966
yyhayyim's Avatar
Trader Rating: 26 (100%+)
CORE5000 pack- running 13.5 BL will give you about 21 minutes of run-time, which is almost 4 heats on a single pack...
Advice: run a heat, then recharge...by the time you run your 2nd heat, its back to almost full charge again...this way you're always at full charge or close to it every time you run...or you can run 2 heats, and then charge, then run your 3rd and fourth, and then charge, etc...
CORE5000 pack-running 10.5 BL will give you about 17 minutes of run time, which is about 3 heats on a single pack...
Advice: pretty much same as above...
CORE5000 pack- running 3.5 BL will give you about 9 minutes of run time, which is almost two 5 min. heats....
Advice...recharge after every run...after a 5 min run, you'll still have about 40% of the pack left...so just recharge, and by the the time you run your 2nd heat you should be pretty close to full charge again...
Or you can have a spare pack and use both packs...1 per run...
Ahhhhhh....the beauty of LIPO!
yyhayyim is offline   Reply With Quote
Old 12-21-2007, 10:26 AM   #23967
Skiddins's Avatar
Not taped in place but should give you an idea, pack would go even further inboard if I didn't run my power wires under the top deck.
Despite how the pics first appear, the pack does not stick out from the chassis at all, in fact it can line up perfectly with the cell holes.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 12-21-2007, 11:15 AM   #23968
For the people with only 1 pack, why not just shoe-goo it into the car?
Old 12-21-2007, 11:30 AM   #23969
abailey21's Avatar
Cause.....
What fun would that be?
Actually thats a pretty good question, maybe cause shoe-goo is messy?
K.C.C.O.
Old 12-21-2007, 11:41 AM   #23970
Cause.....
I use shoe-goo all the time to glue down electronics or wires, it doesnt dry instantly so just wipe the excess away. If you got it on there good you'd never have to worry about ejecting a pack.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
