Old 12-10-2007, 09:53 AM   #23761
Trader Rating: 15 (100%+)
Default weekend
Not a bad weekend at the northwest carpet champs this weekend. Tqed expert stock and won the main on saturday and tqed and won 10.5 also.
Sunday was a little worse with my driving being off but the car was dialed .I ended up second in stock and third in 10.5 but got the overall in stock and second in 10.5.Car was near perfect all weekend. side note i ran the lowered towers with hpi springs all the way around and had no problems.
AARON YOUNG is offline   Reply With Quote
Old 12-10-2007, 10:38 AM   #23762
Customworksking's Avatar
Trader Rating: 71 (100%+)
was there other mi3's in your heats with stock towers that I could of checked lap times? I feel U need the lower towers to run the parma mohawk
on rubber..thanks for the update and good job as well!
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-10-2007, 10:50 AM   #23763
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Good job Aaron.
Jon Kerr is offline   Reply With Quote
Old 12-10-2007, 10:50 AM   #23764
No out of 70 entries i had the only schumacher there .I ran the regular shock tower the first two rounds and then changed it to lower the front of the body a little to get it down on the carpet. Another good thing if you run the lower tower with the stock bottoms it limits the up travel almost perfect which is something i had not fixed on the car.Only thing is you would have to run rps cause the diameter is just small enough for adjustment without changing shock bottoms.
Old 12-10-2007, 10:56 AM   #23765
Skiddins's Avatar
Originally Posted by Kevin K View Post
You can use the rear carpet tower with rubber tires no problem but with the front you wont be able to get the car low enough unless you have short springs.
The way around this is to remove 2mm from the shock ball end, if the shocks are built to the normal length, more of the thread on the shock rod will show, but there will be a larger gap for the spring to fit in, can get my car really low now if required.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-10-2007, 11:09 AM   #23766
Trader Rating: 36 (100%+)
Great job!
Nexus is offline   Reply With Quote
Old 12-10-2007, 11:53 AM   #23767
Shawn Palmer's Avatar
Speed passion for sale product is expected sometime between late this week and next week.
I'll be getting the part #'s into the system this week, so look for them up on the website Fri/Mon or give us a call/email starting Fri for ordering.
Coming in:
SP GT ESC (W/Programming box - NICE!)
SP Feigao ESC (W/Programming box - NICE!)
SP 2.5t motor
SP 3.5t motor
SP 4.5t motor
SP 5.5t Motor
SP 6.5t Motor
SP 10.5t motor
SP 13.5t Motor
ALL SP Tuning rotors
SP motor accessories - sensor cables, sensor units, motor connectors, etc.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 12-10-2007, 12:31 PM   #23768
dawgmeat's Avatar
Anybody using o-rings or foamies in the shock bladders?
dawgmeat is offline   Reply With Quote
Old 12-10-2007, 01:23 PM   #23769
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
foams here
Old 12-10-2007, 01:43 PM   #23770
baf1's Avatar
Default any one have,
an Mi2,Mi3 one way,or diff for sale..
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 12-10-2007, 03:32 PM   #23771
Super Moderator
Marcos.J's Avatar
has anyone tried a diff in the front in asphalt(with the mi3) ? or will the car push alot coming out of the corner?
Old 12-10-2007, 04:10 PM   #23772
Jon Kerr's Avatar
I haven't tried it but to be honest, I wouldn't bother. Just like you said, it'll push middle to exit, just like they do in any other car on asphalt.
Old 12-10-2007, 04:11 PM   #23773
Super Moderator
Marcos.J's Avatar
thats what i figure
Old 12-10-2007, 04:33 PM   #23774
Cool spur
I got a 90 spur to fit wth ezzzzzz 90/37 4.37 fdr 38 is 4.26 39 is 4.15 I will start at 4.37 and see.....
Old 12-10-2007, 04:42 PM   #23775
Big Features's Avatar
I've been using a 116T spur and 45T pinion in my Mi2EC. Very snappy with plenty of speed.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
