Old 12-08-2007, 06:30 AM   #23716
abailey21's Avatar
Trader Rating: 36 (100%+)
I was thinking of using the SPGT and the 2.5 around a 5.0 FDR and see what kind of speeds I can get
By the way the Marcos, the SPGT is a pretty nice speedo, we ran a sensor based motor with and without the sensor wire. You could literally feel the difference but you could run it either way...I was impressed
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-08-2007, 06:37 AM   #23717
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
great!! when can i pick one up??
Old 12-08-2007, 08:23 AM   #23718
abailey21's Avatar
I told you two weeks dude, but I can promise you I'll have mine first, then take a pic and email it to you to make you jealous
K.C.C.O.
Old 12-08-2007, 09:55 AM   #23719
skypilot's Avatar
Trader Rating: 14 (100%+)
hey guys, i'm at a away race this weekend and the track has a old box of shouie parts for missions and sst's anything you want me to look for?
or anything i should be looking for.
skypilot is offline   Reply With Quote
Old 12-08-2007, 11:37 AM   #23720
AdrianM's Avatar
All that will do is burn your motor up fast. There is only so much gear any motor can take. Usually the track you run on limits this because the motor still has to have the gearing to accellerate out of tight corners. If you go past that all you get is heat and no more speed. A 2.5 on 6 cells should be geared around a 10.00 to start out. Then you can gear up from there checking lap times and motor heat to get to the limit.
FYI, most 6 cell guys run a 4.5 and thats pretty insane. The 5 cells guys run 3.5's and go faster then the 6 cell guys.
Adrian Martinez
Old 12-08-2007, 12:31 PM   #23721
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I think you may have missed the sarcasm in that Adrian.
Jon Kerr is offline   Reply With Quote
Old 12-08-2007, 12:32 PM   #23722
Customworksking's Avatar
Trader Rating: 73 (100%+)
Cool 4.20
last year we ran the 13.5 in the 160 to 180 range @ my local track I run it 140 to 150..This is true U can over gear the motor and get nothing but heat same lap times and more motor heat ..rubber tire it's like 114/39 I will see what 4.20 range doe's soon as I dont have my 96 spurs yet..I will post what I find..
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-08-2007, 12:47 PM   #23723
Trader Rating: 37 (100%+)
It is fast! :P
Ran that ratio and lap times dropped. I didn't temp but I know a good number of people running that around here. I'm pretty sure Trackside and The Track are bigger then Allens or where you run...not positive. I just gear up till it cannot fit :P j/k
Nexus is offline   Reply With Quote
Old 12-08-2007, 01:06 PM   #23724
Originally Posted by Nexus View Post
It is fast! :P
yes Allens is much smaller than S and N's what gearing to do run? thanx
Old 12-08-2007, 01:36 PM   #23725
abailey21's Avatar
Ah yes the sleek humorous undertones.....or is it underwear?
Either way I was being a bit overzealous with the FDR claims.
K.C.C.O.
Old 12-08-2007, 02:40 PM   #23726
Super Moderator
Marcos.J's Avatar
2 weeks then!!
Old 12-08-2007, 02:41 PM   #23727
Super Moderator
Marcos.J's Avatar
5.0 ??thats it??
Old 12-08-2007, 03:33 PM   #23728
abailey21's Avatar
I'm leaving the 1:1 to Shawn
K.C.C.O.
Old 12-08-2007, 05:48 PM   #23729
dawgmeat's Avatar
Anybody have a set-up for LoWWWWWW grip outdoor
dawgmeat is offline   Reply With Quote
Old 12-08-2007, 06:09 PM   #23730
Jon Kerr's Avatar
Just had to deal with that last weekend. My quick answer, not yet. Last track I ran on was so low grip that no change I made to the suspension could be felt. We were pretty much drifting on the track. I'd get 1/4 the way down the straight at 1/2 throttle and the tires would light up.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
