Old 06-17-2002, 10:31 PM   #2356
actually look at it this way, if you overgear the motor you may never see full speed. If the motor doesn't have enough torque to pull the gear then you limit how fast the car will actually go down the straight.
Last week the track I raced on had a free flowing layout, but the end of the last s turn right before the straight was kinda tricky, so if you didn't set up for it just right you had to brake to be able to keep off of the outside wall at the entrance to the straight away. Well I didn't notice, because the car carried so much corner speed thru the infeild, but my car was sluggish on acceleration after the 2 min. mark. At this corner was the only place other cars could pull on me. Had I dropped 1 tooth the car would have accelerated faster off this corner when I "lost" my line. I noticed this after I watched the tape my sister made of the race. However i dropped one tooth on my Losi and my brother rocketed off this turn and made my Mission look slow. This slight bobble made the losi about 2 mph faster by the end of the staight. Both cars running 1.8 internal gear ratio, with the Losi running an overdrive gear in the front which would actually make the losi car slower down the 120 foot staright. The moral of the story..... sometimes dropping a tooth can make you faster, even on long straights.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-18-2002, 05:50 AM   #2357
RBLove's Avatar
Trader Rating: 72 (100%+)
Big Dog, I figured out the rollout last night and with rubber tires (Take Ooff CS27) it came to about a 1.10. Gives me a starting point, but I usually gear higher than that on the rug.
Kevin K, What are you running outside in stock? Spur-pinion-pulley!
Thanks for the insight fellas!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 06-18-2002, 05:51 AM   #2358
RBLove's Avatar
Disregard Kevin. I see above
Old 06-18-2002, 10:08 AM   #2359
RBLove's Avatar
Kevin K, Got any good parking lot set ups using Take Off CS27 premounts? I am going to give it a shot this weekend. We normally run foams out there, but the track is extremely hard on them.....
Thanks bro!
Old 06-18-2002, 10:18 AM   #2360
rayhuang's Avatar
Lightbulb Rubber tires
Rob,
I have quite a few rubber tires you can try. SHould I send them to you? I have two pairs of TO CS32 and 2-pairs of 138G's with Medium inserts and one pair with firm inserts. Just let me know and I'll get them out tomorrow. You'll have them by Saturday for sure!!! I am not running them for a few weeks or more!!
Ray
Old 06-18-2002, 10:31 AM   #2361
RBLove's Avatar
You've got it all You better not because that track is EXTREMELY hard on tires. I doubt they even last an entire day. I appreciate it though. I am anxious to try the one-way......... I'll give you full report Sunday evening!!!
Old 06-18-2002, 10:53 AM   #2362
How much does a mission pro cost and who has it cheaper
sportracer is offline   Reply With Quote
Old 06-18-2002, 11:11 AM   #2363
RBLove's Avatar
www.speedtechrc.com sells them $259.95 I believe. The retail price is $279.95...
Old 06-18-2002, 02:49 PM   #2364
Regional Moderator
Darkseid's Avatar
Quick question guys. Do any of you guys actually use the Grey Ultra flex belts for stock racing? If so, how do you like them? How big is the effect on drive train free-ness. And what other effects does it have on the car.
TLR 22...Tamiya F104...
Old 06-18-2002, 03:20 PM   #2365
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Rob.....Hit me up on my E-mail and I will send you the setup that Im running right now. I had a bug here at work and it ate all our address books so I dont have your E-mail addy or anyone elses for that matter anymore.
Darkseid....the gray belts are more flexable but I dont think that they make the drive train anymore free. They do wear out faster then the stock ones. Something I do is soak the black belts in WD40 or put a light oil on them to soften them up some. So in reguard to your question I dont think that you will see any real differance between the two belts IMHO.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-18-2002, 03:37 PM   #2366
Regional Moderator
Darkseid's Avatar
Kevin K: thanks for the honest answer.
Old 06-18-2002, 03:46 PM   #2367
Kevin K's Avatar
Impactplayer......I know that you are saying about the gearing and its true if you dont have the motor to pull the big gear then gearing down will help. But at the same time if the motor cant pull that big gear then try another motor or setup on the motor b/c you will be left behind when the guy with the motor that can pull the gear races you. The whole thing with stock motors is that you are limited to the speed and if the motor is slow it doesnt matter what gearing you use its still SLOW.
Darkseid.....No prob I have tried them both and that is what I have seen.
Old 06-18-2002, 04:38 PM   #2368
King-G's Avatar
Send a message via ICQ to King-G
on the topic of grey belts, I have found the front belt whorth while, as it doesnt suffer with much wear, I have had my front belt on my car for around 3 months..running a 12x2 outdoors.
we tested the rear belt using a 12 turn, and it lasted for around 4 race days before it began skipping..., I wouldnt recommend it unless it was for a big meet (over 1-2 days, as they start to stretch after a couple of days, and eventually start to skip.
for stock....if you have the cash, and are looking for something to buy, go for it...! I think it is more beneficial on the rear of the car where possible (stock), as the grey belts are more plyable, as Kevin said earlier....they will round the layshaft pulley with less resistance
Kevin, I like the idea of soaking the black belts in wd40..I might have to try that one..
King-G is offline   Reply With Quote
Old 06-19-2002, 07:26 AM   #2369
Regional Moderator
Darkseid's Avatar
Thanks King-G.
I remember having to soak my old MR4TC belts in wd40 in order to free them up a little. I didn't really think about trying it with the Mission belts until Kevin mentioned it.
Old 06-19-2002, 07:36 AM   #2370
Send a message via AIM to LarryPryor
RBLove
If you will send me your email address I will send you a setup sheet that I have been running around the Dallas area. I have had pretty good results with it so it should give you a good starting point. TQ'ed and won the Mississippi State race with pretty much this setup also. I also like the CS22 with the CSMH insert you might give them a try if the 27's don't work out for you.
[email protected]
LarryPryor is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
