Old 12-06-2007, 11:36 AM   #23671
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Customworksking View Post
marco do U feel I/we can get the gearing we need for and rubber with the 114 spur? .....
I've talked to Macro eariler...sometime, he even go to the HIGH 3...by looking at the gear chart...to get to 4.5, we need 114/45...I know Mi3 RDX @ our local track run the low 4 (low...)...that means we need 46-50 pinion..not just those are hard to get (tower is back order 46 adn 47...HPI has a 50)...but I doubt the motor mount will allow us to mount a 50 with 114.
Adam.........bring that 96T back in stock FASTTTTTTTTTTTTTT.....
Old 12-06-2007, 11:42 AM   #23672
Customworksking's Avatar
Trader Rating: 69 (99%+)
thanks ...adam I need the 96 by the novak!
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-06-2007, 11:48 AM   #23673
Trader Rating: 36 (100%+)
114 in 13.5BL will be close and possibly no. The track I run at is about the same size at Trackside...if you are going to Novak.
I can tell you that running about 4.8 or so is not bad there. But I ran 4.2 like some other guys and the 13.5 Mi3 was stupiddy fast. Just depends on a few things if the GTB gets too hot...
If you are smooth, never brake or just have super fans I know you can run 4.2 or so for 5 minutes without thermaling.
Not the best video but here is a vid from Trackside 04Dec. Guys are running mostly 13.5s.
http://www.youtube.com/watch?v=bJ8K23k2DW8
I'll be at Trackside this month to see if my car and gearing works there. I also plan to be at the New Years Day race. If anything I can give you guys a baseline of what I run there to maybe get you ready for Novak.
I'm still on the fence for the actual Novak Race.
Nexus is offline   Reply With Quote
Old 12-06-2007, 11:59 AM   #23674
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
i run 48 pitch now,but you should be able to get in to the 4's with the 114 spur, i can get in the mid 4's with the 85 spur (48 pitch) low 4's and high 3's if i mod the motor mount a little bit
Old 12-06-2007, 12:10 PM   #23675
dawgmeat's Avatar
with the Novak race being full brushless and pretty much all over the country it's pretty much safe to to say that BL is now the primary means of racing
Can we expect a new drive ratio to fit in the current car so we can stop using pinions the size of a silver dollar
dawgmeat is offline   Reply With Quote
Old 12-06-2007, 12:13 PM   #23676
Super Moderator
Marcos.J's Avatar
kevin you can also use this spur ,line it up and drill the mounting holes, if you line it up just right it works great!!
http://www3.towerhobbies.com/cgi-bin...?&I=LXN136&P=7
i have one that i did for mi old mi3 before the 96 spurs came out, if i find it ill send it to you!
Old 12-06-2007, 12:20 PM   #23677
Solara's Avatar
No no no....send to me, I bid $5 more....
Old 12-06-2007, 12:22 PM   #23678
Super Moderator
Marcos.J's Avatar
lol
if you get one it will take you a few minutes to get it to work
Old 12-06-2007, 12:39 PM   #23679
abailey21's Avatar
Trader Rating: 35 (100%+)
Oh hush about the spur gears, rumor has it that they should be in my shipment from the UK, I'll keep everyone posted as soon as I know
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-06-2007, 01:29 PM   #23680
Shawn Palmer's Avatar
96's back in stock
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 12-06-2007, 01:38 PM   #23681
Send a message via AIM to adamliehr
Originally Posted by abailey21 View Post
Most likely the MI3 if there's a class to have them
Okay. I only asked cuz usually they don't have touring oval classes at the nats other than the birds.
Are you guys gonna run it normal or design a oval chassis for it?
adamliehr is offline   Reply With Quote
Old 12-06-2007, 01:46 PM   #23682
abailey21's Avatar
just a normal designI'm sure, we havent thought to much about cause rc thunder hasnt relased all the classes, its the tail end of April, so we have time.
K.C.C.O.
Old 12-06-2007, 01:55 PM   #23683
Okay cool. Let me know if I can help with anything.
Old 12-06-2007, 05:36 PM   #23684
AdrianM's Avatar
Originally Posted by Randy Caster View Post
Just wondering because I rarely have to put anything higher than a 23 tooth pinion on the car, but cant you guys make the gear ratios needed for 19 turn with the 114-118 gears? At the nats and IIC I had no problem getting the ratios I needed with brushes motors..
The design of the car allows 160T total between the spur and pinion. For example a 118/42 will be the max combo with a 118T spur.
or...a 96/64
Adrian Martinez
Old 12-06-2007, 06:53 PM   #23685
Where can I get one of those 64t pinions! I neeeeeeeeeeed one baaaaaaad!!!!
Shawn Palmer
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
