Old 12-02-2007, 07:29 AM   #23551
abailey21's Avatar
Trader Rating: 35 (100%+)
I'm going to ask a really dumb question...
You did back the setscrew out of the opposite out-drive didn't you?
Originally Posted by Customworksking View Post
I can't get my diff tight rebuilt it by the book checked everything 3X bearings ,washers c clips no matter what it will not get tight?
can someone help me on this I rebuilt 3 and only 1 will not go back right
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-02-2007, 08:25 AM   #23552
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
check the bearings that going inside. each diff will have one 5x9x3 and one 5x9x2.5. if you rebuilt both diffs at the same time, theres a chance you put the 3mm wide bearings together in one diff, and the 2.5's in the other. in this case, the diff with the wider bearings will squash the bearings together before applying much compression on the rings. double check. i believe the 2.5mm wide bearings are without shields.
also, in the same vein, make sure each diff has only one bearing spacer between them.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-02-2007, 09:43 AM   #23553
Solara's Avatar
Trader Rating: 16 (100%+)
Guys.........any idea where to get the U3169 Ti pivot pin 55mm x4 from? On the manuel it listed as option...I know Mi2EC has that option (purple shaft) but what happened on Mi3? Does ppl cut the Mi2EC and insert that without the 2.5mm screws at both end..? Please advise... thanks.
Old 12-02-2007, 12:10 PM   #23554
the mi3 pin set is not out yet as there is a supply issue with the TI
cheers Jimmy
jimmy..maddison is offline   Reply With Quote
Old 12-02-2007, 04:58 PM   #23555
Customworksking's Avatar
Trader Rating: 69 (99%+)
Thumbs up got it
I got it today i feel like a ass but I had the big diff half in the deep side of the diff fliped it and all good ..on a side note I ran today @ my local trk today and picked up a lap each heat! change 1 thing at a time !!! I also ran my 10.5 foam car holy crap way fast...lookout novak
Customworksking is offline   Reply With Quote
Old 12-02-2007, 06:15 PM   #23556
Randy Caster's Avatar
Trader Rating: 45 (100%+)
I got to run on a super low grip asphalt track today and the car worked awesome. So far I've run on low, medium and high grip asphalt with the same setup and the car rocks. The only change I tried today was lowering the rear diff and it made the little difference that was all the car needed.
Old 12-02-2007, 06:35 PM   #23557
rickchannon's Avatar
looking for outdoor setup medium traction medium size track 13.5 or 10.5 BL thankz rick
rickchannon is offline   Reply With Quote
Old 12-02-2007, 06:50 PM   #23558
did u try schui uas ?
Old 12-02-2007, 07:24 PM   #23559
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
i've ran this set up with the 13.5 , 10.5 and a 3.5 and it works very well!!
http://www.racing-cars.com/usa/image...w_reedy_07.pdf
Old 12-02-2007, 08:06 PM   #23560
Trader Rating: 36 (100%+)
Originally Posted by woozer71 View Post
I know it might be somewhere in this thread, but could I ask where you can purchase the Core 5000 lipo from?
Matt
Direct from Schumacher:
racing-cars.com
Nexus Racing
http://nexusracing.net/product_info....oducts_id=1353
Both awesome service.
Solara I was thinking more 10.5 - 5cell. No way I would run 5cell 13.5 around here. You would get smoked. Rich and I both have good setups that a different from each other. Just copy one of those.
I'm running a setup pretty close to the one posted for Jonas_Viskafors and it works well with 13.5 and the Core Lipo. Honestly if anyone is going to Novak and their car is a tad loose I wouldn't worry too much. That will probably work well as traction goes up.
Nexus is offline   Reply With Quote
Old 12-02-2007, 08:14 PM   #23561
thankz for the quick response will try those setups this weekend
Old 12-02-2007, 08:26 PM   #23562
Super Moderator
Marcos.J's Avatar
Originally Posted by Solara View Post
Macro....you read my mine. Nexus and I are thinking about testing 5 cells 13.5. I really think if that can last 5 minutes, the car (feeling) will handling a little bit BETTER then 6 cells. On my Mi2EC, I always find the extra power of the 13.5 a waste....can't really used that extra power on tight carpet track. May be with the 5 cells, I can MAX out the car....
That spectrum mini receiver must be REALLY small....can barely see that on your 1st pic.
yes its hard to see here is how i had it wired for the lrp
Old 12-02-2007, 10:21 PM   #23563
Default thrust bearing
do u guy's know if corally thrust bearing is the same size as the mi3 I.. checked xray will work but not the flat washers ...
Old 12-03-2007, 03:21 AM   #23564
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
If you wanna try somthing other than the schui thrust I might suggest this Losi thust bearing.
http://www.rcslot.com/pc-radio-contr.../LOSA3098.html
I have one in both of the diffs in my foam carpet car and they have held up for the last three months. Diff still feels brand new. My LHS doesn't carry Schui parts and I was in a crunch for a new thrust a while ago. An xray owner suggested it to me. I do have to say there aint many if any thrusts better than the carbide schumacher thrust U1954. SMooooooo0th!
Dont use the washers that some with the Losi thrust though. Just use the original Schumacher washers.
Odd you say the Xray thrust doesn't work. Theres a driver at our track that I know is using the uuber expensive Xray thrust in his Mi3.
the xray, corally, and Mi3 thrusts are all the same size, or at least are interchangeable in my experience. The washers may not be however.
Old 12-03-2007, 05:23 AM   #23565
Skiddins's Avatar
What is the difference between mounting the steering links to the hole on the steering knuckle that is further foward instead of the kit position?
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
