Old 06-17-2002, 12:27 AM   #2341
Default s1 mission
Hey guys, I was supposed to try out the s1 mission this weekend either at Ripon and/or Castle, but LIFE happened to me!! Saturday I was caputured by graduation parties all day, and Sunday turned out to be house hunting day, all day! Dam it And next weekend I'll be in Phoenix, so I won't be able to try it untill early July, and hopefully get enough practice before the Roar Nats, thats if I'll be able to go! Well we will see...
pmccarson is offline   Reply With Quote
Old 06-17-2002, 08:06 AM   #2342
Racer X's Avatar
Pat: I wondered what happened to you Sat. I was waititng to see that S1 car run for myself. If you can afford to go house hunting in the Bay area you should have enough money to go to the Nats (lol). Oh well, I'll keep my eyes open for you in two weeks. BTW, finally got a great setup for Ripon last weekend...now if everyone else would just let me by, I would have won...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 06-17-2002, 08:07 AM   #2343
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Hey all,
I have a SST'99 that I need to buy some rear arms for, none of my LHS carry schumacher parts, is there any sites online besides Schumacher's site that carry parts????
TigeRyan is offline   Reply With Quote
Old 06-17-2002, 08:18 AM   #2344
SpeedtechRC
Look for mission parts, the suspension arms are the same.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-17-2002, 08:22 AM   #2345
TigeRyan's Avatar
Thanks much!
Old 06-17-2002, 02:22 PM   #2346
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Originally posted by RBLove
Ray, My TRC's do not rub at all, but TM's and Jaco have the same off set and do rub. Just need to put them on the truer and take about 1mm off....
I NEED SOME HELP! Ran outside today. Had to run stock and struggled on roll out all day. I did well, but the car was slow. What are you guys out there gearing stock motors with the 20 tooth pulley? Include your tire size, spur, pinion, pulley and motor I needed to be faster. Finished second, but I was SLOW! I have not had this trouble at all on the carpet. The outdoor track was about 110 x 50...
Rob, shoot for around 7.0 with the P2K2 and around 6.2 for P2K. That should put you really close. Adapt accordingly for any other motor- you know where the torque curves are I'm sure....
BigDogRacing is offline   Reply With Quote
Old 06-17-2002, 03:56 PM   #2347
JonB's Avatar
Send a message via AIM to JonB
I want to buy a front upper-left arm on my mission and speedtechrc's site only lists it as "front upper arm" but there is a 1 and 2 upper-arm. Are they reversable?
JonB is offline   Reply With Quote
Old 06-17-2002, 04:25 PM   #2348
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Jon B.....both front upper arms come in the same package. You can not just buy the left or the right you get both in one shot. So what they have listed is for both arms. And no you can not reverse them.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-17-2002, 04:29 PM   #2349
JonB's Avatar
k thanks, i know the old upper arms used to come alone.
Old 06-17-2002, 04:31 PM   #2350
No, they come as a pair- you get both 1 and 2 in the package. Almost all Schumacher suspension parts (as with most other man.) sell the parts as a left/right pair.
As a fellow Mission racer, I would like to suggeest a few parts that you should keep on hand even if you ARE a good driver...
upper arms for both front and rear
lower arms front and rear
hub carriers
package of ballcups (DAMN I love those schuie ballcups!!! )
one extra set of plastic dogbones
one extra front bumper
get the low resistance belts and keep the originals as spares
--- if you like to have extra parts on hand to rebuild a diff, make sure to get an extra set of the tungsten thrust washers. They aren't reversible, so you must replace them if they get gritty...
this is a minimum requirement list (to me at least) that will keep you racing in case of a bad crash- you can always keep more on hand if you can afford it...
Anyone else who has a suggestion, please add to my list.
Hope this helps you Jon....
Old 06-17-2002, 05:10 PM   #2351
JonB's Avatar
cool thanks
Old 06-17-2002, 06:52 PM   #2352
RBLove's Avatar
Trader Rating: 71 (100%+)
Big Dog, I assume you are talking spur/pinion x internal?? That seems extremely low on the gearing. What is your overall roll out with tire size included? 1.05 - 1.20??? Any where in there?
I have not had any problems on the rug, but I have running on a 75 foot straight and an extremely tight infield..... I've been running about a 1.06 - 1.10....
RBLove is offline   Reply With Quote
Old 06-17-2002, 07:34 PM   #2353
Kevin K's Avatar
Rob.....I run on a 120ft by 65ft track outdoors and I run 29 pinion and 89 spur with the 20t pulley I belive the final drive is 5.50 or something close to that. This was with rubber tires so I do not have the tire Dia. to give you to figure out the roll out. I had plenty of punch and killer speed down the straight and came back with 120 sec of runtime and the motor was warm but not any more then it would be inside. So if you have a set of rubber tires like sorex or something measure them and then figure out the roll out and thats what I would try.
Later
Old 06-17-2002, 07:37 PM   #2354
Rob,I'm sorry, I was assuming you were running rubbe tires outdoors. We only use FDR with rubber tires. Since I don't run foam, I don't use rollout. Maybe someone knows the normal dia. for standard rubber tires so we can plug it into the formula- then you can figure the correct pinion.
Oh, and I only run the 20 tooth gear outdoors...
Kevin- ouch- that's a pretty steep FDR. I must assume that's a P2K. I would start a little higher (Rob) and then go down from there. A 5.50 in the Memphis heat on our 100x50 track will most likely result in some pretty blue brushes...
Old 06-17-2002, 08:44 PM   #2355
Kevin K's Avatar
Big Dogg.....I thought the same thing that I would end up with some blue brushes but I just kept adding more gear to the car and it never fell off or got too hot. I know that if I drove the car just flat punched around the track it will burn the brushes in one run so i try not to do that and it works out very well for me. I think is easier to drive an over geared stock motor then an under geared one. With the over geared one you dont need to pull it as much as in the infield as you would and under geared one. I think this leads to the brushes lasting longer and not getting as hot. Think about it like this if you drove a real car around the track in only first gear how hot is the motor going to get. Where as if you drove it around in second and drove to carry more corner speed what motor is going to be hotter and get worked more? I think the one in first gear and on top of it the one in second will be faster. Now this does not work for every track if the track is super tight and has a lot of short shoots then an undergeared motor would be better but on very large tracks that are some what flowing b/c they race gas cars on then the over geared motor would not be a bad way to go.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
