Old 11-25-2007, 08:57 PM   #23416
MagicMarker's Avatar
Originally Posted by skypilot View Post
i've had those kicking around forever and have no idea where they came from for what they were for, my best guest would be they were for a mugen mtx-2 i used to have.
Cool online search time
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 11-25-2007, 08:59 PM   #23417
skypilot's Avatar
Trader Rating: 14 (100%+)
just went out to the garage and checked on a old yok GT-4, it has the same hubs, i believe the guy i got the yok from told me that he bought the mugen hubs cause they were marked cheaper then the yok hubs, anyway, long story short, i have four more, if you can't find a set, i can send you a couple. they do require a couple of of yokomo axle shims cause they are flat on the inside and there is play.
skypilot is offline   Reply With Quote
Old 11-25-2007, 10:01 PM   #23418
JayBee's Avatar
Trader Rating: 31 (100%+)
heres a little something for jaybee. no spacer needed, 190 on the mark.
and yes the two on the table are for you.
Thanks buddy I'll come pick 'em up tomorrow after work. How'd it go this afternoon when I left? I HAD to go see Bee Movie
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-25-2007, 11:07 PM   #23419
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Good run Chris!
Old 11-26-2007, 05:05 AM   #23420
skypilot's Avatar
i left shortly afterward.
Old 11-26-2007, 06:22 AM   #23421
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by abailey21 View Post
Congrats to Chris, Dave and all of the Shuie drivers for another podium filled weekend
I got you Marcos let me know when your coming in...
I stole 2nd this weekend also **toots own horn**
Who cares if it was sportsman stock!
Starling, get it back to me whenever bud, good job this weekend, and nice to meet you as well!
cool ill call you this morning
Old 11-26-2007, 06:41 AM   #23422
IslandBwoy's Avatar
I'll race foam with you next time
I picked up foams at the LHS that same morning and ended up putting them back because I didnt think anyone would race that class. Youcan count me in next time as well.
IslandBwoy is offline   Reply With Quote
Old 11-26-2007, 08:03 AM   #23423
Send a message via AIM to adamliehr
Nice run Goetz!
Your car looked good all weekend!
adamliehr is offline   Reply With Quote
Old 11-26-2007, 08:09 AM   #23424
I believe XRay has some wide hexes as well. I think I've got a set of four in my parts box... I haven't run them since I had a wheel nut fall off and lost a tire in a race though.
Chris
ckearns is offline   Reply With Quote
Old 11-26-2007, 08:35 AM   #23425
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default 2007 u.s. indoor champs - setup
Originally Posted by Mr. McGoo View Post
Goetz with a Podium finish in stock TC!!!! Great job man!!!
congrats to everyone piloting a schuie to the top at the various local and regional events this weekend.
thanks mcgoo, randy, kling, liehr, etc. i should have put down a top ten 19t run as well, but some bad luck, combined with bad execution kept that just out of reach.
again, some setup tweaks were made from the last one posted (halloween). i think this car was the best one i've had (between vegas, halloween, and cleveland). it was the most balanced. here's a list of the bigger changes:
narrow front hexes (no spacers) - made the car transition quicker
high diffs - made the car lazier, which i found worked well with the narrow front hexes.
higher rear oil - increased turn-in speed and accuracy. probably should have re-tested this a while ago.
encouraging note: this setup was tweaked at the gate over the warm-up period while grip was near that of cleveland. this was the first time i've ever gone to a big race and NOT had to change a thing. not even my dual rate. this came in handy, as i missed the first day of practice (work ), but able to set my car down, and match hot laps on my second round on the track. that was also due, in part, to the very basic layout. still though, that was a nice bonus.
take a look, play around. i think this setup would have been even better on a layout that would have demanded more from a car. as it was, we needed the cars to wrap the 180's, and that was it. twitchy, lazy, it didn't really matter as long as all four tires were on the ground and you could hook the hairpins.
- cg -
File Type: pdf mi3_setup_sheet_CGOETZ-US INDOOR CHAMPS.pdf (390.3 KB, 122 views)
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-26-2007, 01:43 PM   #23426
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Major props Chris. Wish I could have been there to watch. Sounds like you put on quite a show!
On another note Shawn just posted that the Speed Passion ESC, and the new 10.5 and 13.5 just came in for testing. Here's hoping for the best. What a great time to be in the Schumacher Camp!
Old 11-26-2007, 02:16 PM   #23427
Customworksking's Avatar
Trader Rating: 71 (100%+)
Wink car
thanx for the setup seaball! the tech support for the mi3 is next to none!
Customworksking is offline   Reply With Quote
Old 11-26-2007, 04:56 PM   #23428
Skiddins's Avatar
Originally Posted by Jon Kerr View Post
First thing I'd do is take off the sway bars. Also by 2mm and 2.5mm roll centers in the rear, do you mean you have .5mm anti squat in it? If that's the case, take that out too and level out the rear arms.
Yes, it was Anti-Squat, do you think I should run 2.5mm RC?
I also use 1.5 Deg Camber all round and was on Pre-built RP24's and Sorex 28's.
Forgot to mention, I also have the 2.5mm chassis at the moment.
Would the medium flex wishbones help?
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-26-2007, 05:18 PM   #23429
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
IMO, going to the 2mm chassis, med flex or the Mi2 arms and making the changes I mentioned earlier all would help keep the car more stable. And yes, run the 2.5mm roll center to lower it. This should give more rear grip. Anti squat allows the car to transfer more weight forward under braking and less weight to the back under acceleration, giving more steering all around. If you're spinning out, you need to take that out first.
Jon Kerr is offline   Reply With Quote
Old 11-26-2007, 07:40 PM   #23430
Trader Rating: 36 (100%+)
Awesome run Seaball!
revisting...
Just for comparison purposes...
What are people running for rollcenter running rubber tires/carpet? 1.5mm, 2mm, or more?
Nexus is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
