Old 11-16-2007, 07:41 AM   #23221
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Hey Chris... off the top of your head how much lower are the carpet shock towers? Gonna try them on asphalt if I can make ride height..
Old 11-16-2007, 07:47 AM   #23222
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i don't know what they are compared to the stock mi3 towers. the rear will be fine. the front, though, will need the ae perches, some cutting of the ball end AND maybe some short springs (no longer than ours, and maybe even shorter - yokomo) it's going to be close, but i bet you can pull it off.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-16-2007, 07:52 AM   #23223
UK.hardcore's Avatar
Originally Posted by yokemad View Post
What kind of oil You guys using for lubing oneway???
Thanx
I use the same oil as for regular bearing lubricating.
There is also Serpent one-way oil but i never tried that.
I've never ruined a one-way yet, so it must be good oil i use.
Just go to your local car shop and get some full-synth engine oil, thats what i did, awesome stuff for bearing and bushings.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 11-16-2007, 08:58 AM   #23224
Big Features's Avatar
I use LOSI thick grease to slow the action down a bit. Works good for rubber/carpet
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 11-16-2007, 09:51 AM   #23225
DON'T use normal bearing/bushing oil for oneways! Normal oils are "high pressure" oils, they lubricate too well, the oneways WILL slip and burn down. Maybe not with stock motors, but pretty much guaranteed with mod.
Use one-way bearing oil, Serpent one is good and it will last a long time (my bottle is over 5 years old, although during last few years the only one-way I've used has been in the gearbox of my Mugen. One-way oil is a low-pressure oil, it creates a weaker film on the rollers, so that they will cut through the oil film and will not slip.
The difference is the same as normal grease vs. diff grease (diff grease being low pressure).
olev is offline   Reply With Quote
Old 11-16-2007, 10:55 AM   #23226
yokemad's Avatar
I've dropped some 3in1 make oil It is quite thick... a bit confused what to do now...
I'm doing 27T stock so it should be ok...Is it ???
yokemad is offline   Reply With Quote
Old 11-16-2007, 04:36 PM   #23227
dawgmeat's Avatar
OK just finished up rebuilding my diff with non-locking diff-rings, pro thrust bearing and tungsten Carbide diff balls, sanded each diff ring for about 8-10 minutes per rings 1 side only and pretty much followed the instruction that Adrian posted a page pack........THIS DIFF IS STRIAGHT BUTTER or smooth as freashly wax P****
dawgmeat is offline   Reply With Quote
Old 11-16-2007, 09:20 PM   #23228
Good luck to all my Schumacher Homies heading to the champs!
I'll see you all at the 'birds, still up in the air as to what class's I'll run
Mike Kling
Old 11-16-2007, 10:20 PM   #23229
dawgmeat's Avatar
Would love to go to the birds in 2008 but I'll be deploying in early Feb. and beside I threw all my eggs in 1 basket with brushless and lipoI never going back to brush
Old 11-17-2007, 12:33 AM   #23230
What Brushless system did you decide on?
Barger is offline   Reply With Quote
Old 11-17-2007, 03:58 AM   #23231
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by andrewdoherty View Post
jay-
we ran a 10.5 class sat and we were mostly around 5.2-5.6. For reference we run on a large piece of carpet and were running 13-14 second laps. I might start at a 5.9 and temp and gear up accordingly. This was all with an LRP sphere comp, orion 4800, the novak 10.5/4300's with sintered rotors. I wasn't running a fan at all and temps indoors were low
80's. I was running a 32/96 with 57 mm tires and my motor didn't get over 130.
Tonite ran a rollout of about 36mm (36/96 w/55.5mm tires) and the car was ballistic!! Hit a fast lap of 12.9 and I know the car has a 12.5-.7 in it. Motor came off at 140-degrees. Once I figured out the front shock length to get the droop-n-ride height I wanted, the car is $$money$$.
I luv my MI3
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-17-2007, 05:01 AM   #23232
dawgmeat's Avatar
LRP tc spec/ orion 10.5
Old 11-17-2007, 05:43 AM   #23233
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Cool because I just bought all the same stuff to redo my diff.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 11-17-2007, 08:24 AM   #23234
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
copy car see yah friday night!! (dont get too drunk) they should be a few girls at my bar that night so it should be fun
Old 11-17-2007, 11:40 AM   #23235
dawgmeat's Avatar
Soo much for not being drunk
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
