Old 11-13-2007, 03:17 PM   #23161
Skiddins's Avatar
I'm assuming the Trakpower 4900 Li-po packs will not fit into the Mi3 at all?
Anyone tried lasting a Mod Race using 3600 Lipo, does it?
Thank
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-13-2007, 03:38 PM   #23162
Does the U3262 Ti Layshaft post, also fit as the steering post?
Besercoe is offline   Reply With Quote
Old 11-13-2007, 03:46 PM   #23163
Thank
Skiddins
The Trackpower fits under the bulkheads, but the plug location prevents you from putting the pack all the way in, you need to angle it, so that the rear of the pack is just off the chassis.
Old 11-13-2007, 05:40 PM   #23164
abailey21's Avatar
Trader Rating: 36 (100%+)
I can have an answer for you in the morning but I'm not sure.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-13-2007, 05:53 PM   #23165
hey do the orion 32oo carbon spec lipo fit the mi3? just thought the plug might hit the top deck?
also i run low grip aphsalt so what will i probbably order with the car so far it looking like:
tungsten carbide thrust and diff balls
p dub bumper (ill need it)
quick clips for wheel base
roll bars
then suspension arms (which ones?)
anything else? anything on this car break apart from suspension arms carriers and driveshafts?
also which are stronger the kit turnbckles and hinge pins or the titanium items? im not a good driver so strangth is more important than weight specially with lipo
i own a mi2ec apart from driveshaft there a great car but i havnt tried the new silver ones so ill wait and see
oh does any one have a pdf file of the full mi3 manual? cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 11-13-2007, 07:56 PM   #23166
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
This is the best I could find
http://www.racing-cars.com/usa/searc...e1=prodvalue14
Old 11-14-2007, 12:28 AM   #23167
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
roll bars
Hey josh,
- You don't need the sway bar kit - at Bris tracks it's either the kit bar or nothing
- stock hinge pins and turnbuckles are plenty strong enough
- If you want to experiment with arms, try the mid-flex arms, ut not the extra-flex
- Car ships with quik clips for wheelbase adjustment - so you don't need extras
- Manual can be downloaded here
If you go with an mi3, for Bris area tracks we are having very good success by sticking close to the 'chris ashton tarmac test' setup included in the instruction manual. It's a good place to start.
cheers
scott
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 11-14-2007, 01:24 AM   #23168
The Shrew's Avatar
This probably sounds like a silly post.
Does anyone else have problems with the wheel hexs chewing up wheel rims over time ?
This seems to be more of a problem on the front than the rear. Even after 1 run with new wheels and tyres the fronts seem to be hard to get off the car.
Do people run the washers between the hex and the wheel ? Im thinking this could have something to do with it.
Its starting to do my head in now.
The Shrew is offline   Reply With Quote
Old 11-14-2007, 01:41 AM   #23169
Ian S's Avatar
Yeah lots of us have had this problem, you need part U3221 which is a new hex without the groove in it so theres more contact with the hex in the wheel.
Team Schumacher UK
Ian S is offline   Reply With Quote
Old 11-14-2007, 01:49 AM   #23170
For the tarmac tracks I run on I remove the spacer on the front wheels(leave the rear on)...makes the car a little more nimble and have no problem...I use speedmind premounted sorex 36s ....make sure you are using a rim with a deep hex...some are not deep enough...hence stripping out
Barger is offline   Reply With Quote
Old 11-14-2007, 02:17 AM   #23171
The Shrew's Avatar
Cheers for that.
Its a controll bre built wheel set up im running so got to use them.
Will try the other part number cheers.
Old 11-14-2007, 06:19 AM   #23172
abailey21's Avatar
They are different parts, sorry
K.C.C.O.
Old 11-14-2007, 07:58 AM   #23173
dawgmeat's Avatar
How are my parts coming UPS or USPS???
dawgmeat is offline   Reply With Quote
Old 11-14-2007, 08:08 AM   #23174
abailey21's Avatar
UPS, tracking info says on truck for delivery, I PM'ed you the tracking number
K.C.C.O.
Old 11-14-2007, 08:27 AM   #23175
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Cant you reverse the hex so the groove faces the axle?
yyhayyim is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
