Old 11-11-2007, 02:25 PM   #23071
abailey21's Avatar
Trader Rating: 36 (100%+)
So I just got home from the Raddison where the Snowbirds are this year, and its 100% better than the old hotel.
Plus I'm a number 72 on the sleep number bed!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-11-2007, 02:43 PM   #23072
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
finally got to run the MI3 on the 10.5 class (8 minutes)and it was great! finished 3rd ,ended up with a 4.78 FDR(with 1mm advanced timing) and it was a missile
Old 11-11-2007, 04:19 PM   #23073
Skiddins's Avatar
Out of interest, what sort of gearing would you have run on the same circuit with a 13.5?
Just trying to compare as my local club has allowed 10.5
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-11-2007, 04:41 PM   #23074
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Did you run lipo or nimh packs for the 8 minute races?
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
wyd is online now   Reply With Quote
Old 11-11-2007, 04:49 PM   #23075
Super Moderator
Marcos.J's Avatar
Skiddins
i told one guy that was running the 13.5 novak motor to run it around a 3.96FDR and he was MOVING
Old 11-11-2007, 04:50 PM   #23076
Super Moderator
Marcos.J's Avatar
i ran LIPO (core R/C 5000) and had about 2600 mah left in the battery after the run couple of guys were running 4200's and had no problems with runtime
Old 11-11-2007, 04:55 PM   #23077
wyd
Tech Legend
wyd's Avatar
Awesome. 3.96 final drive. No wonder he was moving. I do take it that the track is kinda open.
Old 11-11-2007, 04:56 PM   #23078
Super Moderator
Marcos.J's Avatar
a little but it had a little tight infield
Old 11-11-2007, 05:17 PM   #23079
Customworksking's Avatar
Trader Rating: 73 (100%+)
Thumbs up 415 cvd /mi3 how it looks
ok the 1way all u need is a rubber shock o ring orange or any coloer and 2 shims and the axle+4 or 5mm wheel hex...the Diff/Foam car u need a 2mm bit drill the blade slip some heat shrink tubing over the bone heat it cut to fit put the blade on do the same as the 1way to the axel and all good less than 20bucks!
Schumacher Corner-dscf0785rubb.jpg   Schumacher Corner-dscf0787foam2.jpg   Schumacher Corner-dscf0789foam.jpg
Customworksking is offline   Reply With Quote
Old 11-11-2007, 05:39 PM   #23080
Super Moderator
Marcos.J's Avatar
looks good , or you can get the updated silver cvd's from schumacher
sent you pm
Old 11-11-2007, 05:55 PM   #23081
sent you pm
r they steel?
Old 11-11-2007, 06:01 PM   #23082
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Mr. McGoo View Post
I do almost what Adrian posted but a little different. I too clean everything out at least twice - and just make sure you keep your hands clean. Any fibers or dirt will make your diff crap out.
I little trick I have found to work is use the cap of the motor spray. I then spray some motor spray in there and then put the fiff balls in there. I let them sit as I am cleaning everything else. I then just pour them out on a clean paper towel and then spray them again.
I actually like lubing up the diff pulley instead of dipping the diff balls as Adrian does. I just use an exacto or a small flathead screw driver and just place some schumacher diff lube in the holes of the pulley. I then just place the diff balls in the holes.
As Adrian stated, make sure you use 600 grit sandpaper and sand those things down till they are nice and butter smooth and even.
I have had great success with building my diffs this way.....
While were on this topic I thought I'd mention that if you have not tried the Schumacher circlip pliers tey are FREAKIN AWESOME! No more modding makeup scissors, or using body clips or anything. They jsut plain work perfect. One of those "why didn't I get these 3 years ago??!" kinda purchases for me!
Old 11-11-2007, 06:01 PM   #23083
r they steel?
No, they're a silver alloy.
Old 11-11-2007, 06:19 PM   #23084
Solara's Avatar
Trader Rating: 16 (100%+)
r they steel?
And they are A LOT better....used it on my Mi3 and even the Mi2EC Foam now...won't go back to the purple one no more.
Old 11-11-2007, 06:35 PM   #23085
POUNDITRACING's Avatar
I just had to replace my axels after 6 race days. I had 2 almost broken cvd pins, 1 cracked axle, and 3 compleatly warn out bones. I got the silver one in the kit. Any suggestions on making them last longer?
I also have a prolbem with one of my droop screws in the rear of the car. I run 5mm of droop and the arm is stripped. The arm only holds about 1 1/4 threads. Is there a fix other than longer droop screws?
On a good note: I won my first main this weekend. It was the B but the A is full factory rides other than Allan Hewitt (who won the main). The car feels great and I'm getting faster every race. I love the way the car feel on the track but I seem to always be needing a little more stearing.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
