Old 06-10-2002, 09:23 PM   #2281
ottoman's Avatar
R/C Tech Charter Subscriber
Kevin K
Thanks for the tips..... we are running in Sheboygan... might run down to Madison in a few weeks.... picked up some Sorex 36 and a set of takeoff 27's to try
ottoman is offline   Reply With Quote
Old 06-10-2002, 11:17 PM   #2282
Hey Pat, have you noticed how much diffrent the weight is from the S1 from the graphite? I was wondering if the top decks were a significant difference. Have you tried putting the S1 top deck on your graphite car to see if there is a change in flex? Been bouncing around the idea to order one and find out. I was hoping that it would be stronger but provide as much flex as the ones we ran at the reedy race.
thanks
andrew
deoff is offline   Reply With Quote
Old 06-11-2002, 11:05 AM   #2283
AdrianM's Avatar
Use the stock front hinge pin mount on top of the front (U1989) raised blocks. It has better clearance and is stronger than any graphite brace you could make.
Adrian Martinez
Old 06-11-2002, 11:33 AM   #2284
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Ottoman, we are racing this weekend. There also is a water slide at the park where we race so bring your suit. Also, if you come this weekend you might want to get a shelter of some sort as they rented out the shelter area we normally use. Hope to see you there.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-11-2002, 05:19 PM   #2285
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Impactplayer......I dont have pic's of the brace that I made but what Adrian said is an even better idea then the cutting of a pice of graphite to make a brace. I have pics of the mod and what it looks like on the car if you want me to post them I can, so if you or anyone else needs to see it again let me know.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-11-2002, 07:48 PM   #2286
King-G's Avatar
Send a message via ICQ to King-G
Just a thought on the rollcentre mod guys..
would it be possible to use either of the rear hinge pin blocks as the rear end mount, and the standard front mount with a carbon brace underneath to bring it up higher...
the rear blocks could be raised in the same manner by using a carbon plate underneath each block...
does anyone know how much the hingepins are raised over standard using the fireblade parts?
King-G is offline   Reply With Quote
Old 06-11-2002, 09:25 PM   #2287
SpeedTech's Avatar
Hi Guys,
We still got a couple more of the complete titanium screw kits in stock for the Misson!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 06-12-2002, 12:12 AM   #2288
I would love to see pics of your roll center mod. Thanks
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-12-2002, 07:07 AM   #2289
cornerspeed's Avatar
The roll center mod for the front actually makes it the same as the rear. So using the rear blocks for the front will raise the pins without spacing them up.
cornerspeed is offline   Reply With Quote
Old 06-12-2002, 09:54 AM   #2290
rayhuang's Avatar
Default It's here!!!
My Mission is here!!
Rob Love-I am going to set the car up exactly as your set-up above, except I am adding the roll-center Mod and trying 8.5 degrees of caster.
I am also going to try the Losi shaft/Assoc. piston set-up. Any specific shock length to shoot for?? I am running 2.25" foams.
See ya soon on the carpet!!!
Ray
Old 06-12-2002, 10:05 AM   #2291
63-67mm seems to be the norm, being your on carpet the lower end of the spectrum would probably be better. You may find you need to take 3mm off of the front ballcups to achieve lower ride heights .
Old 06-12-2002, 10:33 AM   #2292
rayhuang's Avatar
Talking Shocks again!!
IMPACT-thanks!!! Too bad I sold my totally tricked out XXXS to compare back to back to this one. Well-I still have my totally modified TC3 to compare to!!!
So set shock length in and or around 63mm. No problem-I know what to do from here. I also have another set of threaded shocks I can build. Any recommendations on a set-up with the stock adjustable pistons?? Something a tad softer maybe then the Losi/Assoc. set-up? Maybe build two stiffer and two softer than the Losi/Assoc. set-up?? any idea where to set the pistons?
Thanks guys!! I have to apologize-I am an information junkie when i get a new car to test with!!!
Old 06-12-2002, 11:33 AM   #2293
Trader Rating: 71 (100%+)
Ray, My fellow foam carpet racer Try #2 with the vari piston and 70 weight all around. Paul used that at the Snowbirds and I tried it and it worked great. Everything has worked thus far. Just trying to make it better and better. The roll center mod is "AWESOME"....
You're gonna love it. It is fast in stock and of course in mod. Lots of steering, but stuck like a duck. It's awesome.....
RBLove is offline   Reply With Quote
Old 06-12-2002, 11:41 AM   #2294
rayhuang's Avatar
Talking QUACK!!!
Not to throw a wrench in the mix, but I wish I had the time to test with the shocks on my Serpent Vector. They are the easiest to bleed, easiest to build, easiest to adjust shocks! Maybe if we ever get a permanent track in Cleveland....
Thanks Rob, You know I am gonna start rebuilding it tonight!!!
Old 06-12-2002, 12:32 PM   #2295
Ray, I am not sure of the shock body size of the Serpent. The standard Shchuie shocks are fine. I just tried the mod that Kevin K recommended and it works. If you are not happy with the mod on the shocks or the stock I guess you could give it a try, but I am sure you will like on of the other two.....
Get that thing rebuilt and bring it down next week for some bashing...................
FLEEEEEEEEEEETWOOOOOOOOOOOOOOOOOD
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
