Old 11-06-2007, 02:12 PM   #22906
abailey21's Avatar
Trader Rating: 36 (100%+)
Thanks Wes, I'll be waiting for it.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-06-2007, 03:27 PM   #22907
dawgmeat's Avatar
Hey this is starling did you mail off my package?
dawgmeat is offline   Reply With Quote
Old 11-06-2007, 04:02 PM   #22908
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by IslandBwoy View Post
R any of you at or under weight limit that are NOT running lipo? If so, what electronics/motor combo are you running?
I'm a couple grams underweight. Orion Vortex Brushless, LRP Sphere TC, KO 302F reciever, KO low profile servo, Orion 4200's and a transponder. Expecting my lightweight bulkheads today or tomorrow, those should send me well underweight
Old 11-06-2007, 04:35 PM   #22909
POUNDITRACING's Avatar
BCR Randy?
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 11-06-2007, 05:01 PM   #22910
AdrianM's Avatar
Originally Posted by The Shrew View Post
Correct diffs make a huge difference to how the car handles.
It wasnt till about this time last year i was having problems with my car then running a Xray T2. I was talking to probably there best team driver over here in the UK about it. He looked at my car and said the set up was pretty much the same as his etc the rear diff would be causing the problem. To be honest i didnt even think it would matter to much if the diff had a bit of grit in it. Just to proove the point i had a new built up diff in my box i swapped it over he set the tension of it which was pretty much the same as what i had anyway and then did my next run. I couldnt belive the difference in the car it felt the best it had ever done ever since then the diffs in my cars get rebuilt etc very regular.
Also on this point im interested to hear why some of you have been running your diffs on the Medium - Loose side ? Is this just with foams or with rubber aswell ?
We were talking about carpet racing on foam tires. Thats the only place where we run front diffs.
On rubber tires we run a front spool and a rear diff as loose as you can run it with it not slipping. Loose rear diffs give more on power steering. Stock guys can run it REALLY loose and as you go from 19T to mod you have to run it a little tighter to prevent slip with all the power.
The instructions say go full tight and back it off 1/8-1/4 turn. For Mod I run a little looser than 1/8, 19T about 1/4 loose and for stock almost 3/8 loose.
Adrian Martinez
Old 11-06-2007, 05:37 PM   #22911
Originally Posted by POUNDITRACING View Post
BCR Randy?
Gonna try for the 17th, got some more stuff to test. After that I have a couple 1/8 races I'm gonna attend.
Old 11-06-2007, 06:38 PM   #22912
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I think I'm going to actually make it up for the 17th. FHR Series race was canceled.
Jon Kerr is offline   Reply With Quote
Old 11-06-2007, 06:55 PM   #22913
abailey21's Avatar
Your package was forwarded from CT, and will be delivered by weeks end which prevented me from sending out a 2nd one, but it is inbound.
K.C.C.O.
Old 11-06-2007, 06:59 PM   #22914
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by JayBee View Post
Does anyone know the weight of the carpet chassis?
I repeat......
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-06-2007, 07:09 PM   #22915
I'll believe it when I see it
Old 11-06-2007, 07:13 PM   #22916
abailey21's Avatar
JB I'll have it for you in the morning, I didn't get a chance to get to it today, i'll email you in the morning
I repeat......
K.C.C.O.
Old 11-06-2007, 07:19 PM   #22917
IslandBwoy's Avatar
Originally Posted by Big Features View Post
I'm running a JR8800 servo, KO Hara Twister 2.2 speedo, CO27 stock motor,
Carpet chassis/topdeck/shocktowers, LW bulkheads, titanium screws/ballstuds, Parma Mohawk body, and BSR double pink tires on JACO Prism wheels and my car was 1458g. Thats with a EP4600 and a motor fan/mount.
IslandBwoy is offline   Reply With Quote
Old 11-06-2007, 07:26 PM   #22918
dawgmeat's Avatar
:rolleye s:
well that just sucks
Old 11-06-2007, 07:49 PM   #22919
JayBee's Avatar
Thanks Adam
Old 11-06-2007, 08:26 PM   #22920
abailey21's Avatar
I wasn't the one the filled your order, but i'll put it on me that i dropped the ball on that one, i'll have you taken care of on your next order, just make sure you talk to me.
:rolleye s:
K.C.C.O.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
