Schumacher Corner
anyone got a pic of the pdub bumpers? what makes them so good that everyone wants them? lol... i thought the point was to not his stuff?
My PHI weighs 1357g with a lightweight, S9451, GTX, Spektrum Micro, and CO27.
I dont know if anyone saw the new Ko Brushless, but it looks small! KO Brushless
Like it has been said before; unless you can run perfect lines for 5 or 6 minutes then don't worry about weight right now. Think of it this way; a little extra weight goes a long way when you rub fenders
Schumacher is addressing their weight issue for the Mi3 and you will either see a running change at some point in the kits or a new '08 edition.
Regional Moderator
P-Dubs are just a better bumper. Not just for the Mi3, but for any sedan. They are harder than the stock bumper, and usually wider as well. They also tend to affoard you a nice 'bounce' off the boards when you catch a corner, which lets you move on without having to wait for the 350lb, chain smoking, turn marshall who's also on the cell phone at the time.
Another benefit is that the Mi3 P-Dub fits very will with some of the most popular bodies on the market. I have found all of these to be a perfect fit with the curve of the P-Dub:
-G6
-Mazda Speed 6
-DNA 1 and 2
-Mohawk
I agree with Paul.
IMO I think most people are making a bigger deal about the weight then anything. At the club level and trophy races I really don't think you will see it. Maybe....big maybe...at National races you might gain a little if you drove perfectly over the 5 minutes.
I run my car with a Novak GTB, 13.5, KO RX and have never felt the car was slower because of weight.
I agree with Paul.
Anyways as PW has stated, Schumacher R&D is already working on this issue, and a solution will be forthcoming which will for sure make all of us very, very happy in this regard...the car is great, but with a LW edition, it will be perfect...
Yohan
Sent you a pm with the tracking number enclosed!
Just a quick and probably a silly question, but which roll bars is stiffest the black, silver or gold?
Cheers
Paul
Cheers
Paul
Black =Stiff=1.6 mm
Gold=Medium=1.4 mm
Silver=Thin=1.2 mm
Gold=Medium=1.4 mm
Silver=Thin=1.2 mm
Hi buddy R U still using That Trf415 Steel dogbones?
could you please Send me What I need to use Them...
Two Broken Plastic Blades at a Night, They piss me off, enough, I want no-blade Steel Drive shafts
I use One-way not a spool What do you think causes that?One-way or too much Steering Lock??
Thanx in advanced
Actually I had always thought that brushless was a lot heavier overall, but it ends up being about the same weight as a brushed system after you consider the lighter motor. Some of those weight #'s look really odd. Especially the difference in Mi3 weights. And IF that's true about the Phi, that's pretty amazing considering it's a 6 cell pack
Don't know how accurate those #'s are.
IMHO, Lap times are the only sure way to know if you're faster or slower, as well as ESC and motor temps...in real racing weight is very important...its a key performance issue in F1 and other pro level 1:1 racing...it is very relevant for rc racing also...its physics, and running at 50g more weight than your competitor for example, has to influence your car's performance and handling...most of the time it means a bit less acceleration/punch, higher esc /motor temp which effects their performance and efficiency, which affects battery runntime, etc, as well as other factors...just because one runs at club level doesnt mean we should care about these things...its also part of set-up and performance.
we are not talking about small margins, it is a full 10% more. Try throwing another 70-80kg in an F1 car and see what effect it has. Even for one of the back runners for those saying it only affects the front runners
Did anyone answer the question about wether there are light weight king pins? I got lost
There is nothing wrong with wanting all this stuff...it just dosen't do most guys any good.
Cars that just flat out work well out of the box and keep working well with little tuning is what makes most racers happy.
FYI, At a state race a couple years ago I pre-tech my car and it came up 3 oz too light. I thought that was wrong but I had no time so I strapped 3oz of lead to my Mission and raced. I had my best qualifying that round with a car that actually weighed 56.5oz. I am not saying it helped...I am saying that for my fairly normal skill level it didn't hurt...lol!
