Old 06-06-2002, 11:26 AM   #2251
Default RCCA review
RLEONG- RCCA got their wires crossed that edition, I believe they also reviewed a 12th scale car that issue and the micro servo went in that. I also believe that there where a few other mixed up facts in the reviews, if you look really hard you will probably find the other errors and begin laughing histarically!!!!!
I believe (among others) the mission was listed as a 12th scale direct drive car!!!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-06-2002, 11:31 AM   #2252
Racer X's Avatar
Hey P Mc! It's about time you had something to say. You running at Ripon this weekend? If so, I'll talk with you there...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 06-06-2002, 02:09 PM   #2253
Default Re: RCCA review
thanks for the info.
rleong is offline   Reply With Quote
Old 06-06-2002, 09:49 PM   #2254
ottoman's Avatar
R/C Tech Charter Subscriber
RBLove
What upper deck are you running with the foam setup you posted?
ottoman is offline   Reply With Quote
Old 06-06-2002, 11:24 PM   #2255
hey Pat, thought I'd join you on here. Paul told me you bought a S1 car. Always been kinda curious how that might work. But then I'd have to put down the dremel. Your running mod with that car right?
andrew
deoff is offline   Reply With Quote
Old 06-07-2002, 12:52 AM   #2256
Hey Andrew, whats up! Ya, I'll give it a try this Saturday in mod at Sheldons track. Its a small asphalt track that they have in the back of their shop, their traction is usually kinda low, so it should be a good test. I talked to Dominic and Jeff today, they are down south for the Norrca Nats at Hot Rod hobbies, Dom was saying theres not too many people their and he was pretty happy with how his car was handling, he said he's almost as fast as Hara! I think he's exaggerating a bit, but I guess stranger things have happened! Take it easy, talk to ya later!
pmccarson is offline   Reply With Quote
Old 06-07-2002, 07:13 AM   #2257
Send a message via ICQ to JesseT
I would suppose the S1 Mission is slower only on carpet compared to the Graphite version. Getting the carpet upper deck for the S1 car would probably help on this.
BR/ JesseT
JesseT is offline   Reply With Quote
Old 06-07-2002, 07:55 AM   #2258
SpeedTech's Avatar
Hi Guys,
We got a few of the Titanium racing complete screw kit for the Schumacher mission in stock. They are available online now.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 06-07-2002, 04:37 PM   #2259
rcfiend's Avatar
Trader Rating: 29 (100%+)
Those of you who are using 64 pitch spur gears, what spur gears are you using for stock and mod. Also what gearing are you using. I race at So Cal Raceway, in Fountain Valley, Ca.
rcfiend is online now   Reply With Quote
Old 06-07-2002, 07:14 PM   #2260
AdrianM's Avatar
rcfiend-We run RW 64P spur gears in the 120-124 range in both stock and mod. SoCal should already have these or will have them very shortly.
Adrian Martinez
Old 06-07-2002, 07:24 PM   #2261
RBLove's Avatar
Trader Rating: 72 (100%+)
OTTOMAN, Carpet top deck (thick). Forgot to put rear droop down to. 3mm front and 2 mm rear. I am testing a number of things tomorrow I will post results....
Rob
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 06-08-2002, 08:43 AM   #2262
rcfiend's Avatar
Originally posted by AdrianM rcfiend-We run RW 64P spur gears in the 120-124 range in both stock and mod. SoCal should already have these or will have them very shortly.
Adrian do you know if So Cal will have any of the stiffer upper deck?
Old 06-08-2002, 03:10 PM   #2263
ottoman's Avatar
I ran asphalt for the first time today and I need some help on tire/ inserts. The track temp was about 115F (started at about 90F) and all I had was some sorex 28's with echo red inserts. It wasnt the hot setup! I would have asked the fast guys what they ran but unfortunatly I was the fast guy...TQ and A main winner. I chased a very loose car all day and the hotter the track got the looser it was. What tire and insert would work best in the 90 to 120F range?
Old 06-08-2002, 06:28 PM   #2264
Hey ottoman, next time try the sorex 36's with either a hpi red or green insert. I have had better luck with these than with the sorex 32's. The 32's have a much more narrow temperature range than the 36's. Good luck.
Old 06-08-2002, 06:41 PM   #2265
Default S1 mission
Hey guys, I tried the S1 chassis mission today at Sheldons Hobbies. Track had good traction during the morning and it got progressivly worse throughout the day. I was forced to run stock, no mod guys showed up, but the car was very stable and had plenty steering. Ended up TQ in the A and won. I also noticed NO glitching (every once in a while I would glitch a little with my graphite car). The car built has much more noticable flex, hopefully I'll be able to run mod at ripon next week and see what happens!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
