Old 10-24-2007, 05:42 AM   #22531
AdrianM's Avatar
Originally Posted by abailey21 View Post
Hey Adrian.. [cough][cough] I need a DB12R [cough][cough]
Don't ask me...i'm not "The Man" at BMI...lol!
Adrian Martinez
Old 10-24-2007, 06:12 AM   #22532
theisgroup's Avatar
Originally Posted by andrewdoherty View Post
You wouldn't happen to have a second set of light blue and light red xray springs, would you???
orry, only had on set and the second half is on chris's car right now. I had another set of springs, but tim has them now. you may check with him. the xray will not be using the same springs this weekend.
also thanks to Rocco for all the setup help last night. he probably won't see this, but oh well.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-24-2007, 07:22 AM   #22533
abailey21's Avatar
Trader Rating: 36 (100%+)
oh you ARE the man, and thanks for looking up that info on your anodize guy. Tell Jason to sell his Corvette and buy a truck, so he can fit his DB12R box in it and drive it over lol
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-24-2007, 07:38 AM   #22534
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Yes but if you want faster service he needs to keep the Vette and just get a trailer to pull behind it.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
wyd is online now   Reply With Quote
Old 10-24-2007, 07:54 AM   #22535
Mr. McGoo's Avatar
Originally Posted by theisgroup View Post
ok, Mcgoo's iic setup with these changes. I stood the rear shocks up 2 hole and reduce the inner camber link shim by 1mm. the stock center track rod mounted 1 hole from full back. also running 5 degree block, but I think the 6s will work a little better. also running 7 for rear droop. was able to maintain 12.1s with a few 12.0, once the peak was gone on the batts, was doing 12.2-12.3. no traction roll from new parma 53 (~60mm) to <54mm. car was most consistent with 57.5mm-58mm. traction is med, but not as good as a race day.
sweet man - good job! must be nice to "work" while at the track....
what did you find that those adjustments did for you? or better yet, what was the car doing, and why did you change? just curious.....
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 10-24-2007, 07:57 AM   #22536
theisgroup's Avatar
i work at the track more then I "work" at work
the car was sluggish in the corner after the sweeper. so it just help the car to rotate better. I think the stock chassis flexs quite a bit under stress and was not allowing the suspension to work. so standing the shocks up livened it up. the camber link change was just the first change. I did not move it back to see if standing the shock up was the real "fix"
I can tell you this. with the stock chassis 13.5 foams, the stock chassis is just not as responsive. i had to plan the corner further ahead then with my carpet car. and it seam to not hold the sweeper as tight. but that is probably a good thing for newbies. also the chicane on the right is a little harder to maneuver. I actually had to make it almost 2 turns(left, then right) instead of a "wiggle"
yang lai
Old 10-24-2007, 08:45 AM   #22537
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
did you change the horizontal or the vertical link 1 mm? Which top deck?
Those were the two areas of the track I had the hardest time with. It was just so slow to respond. Way to go Yang.
Old 10-24-2007, 09:01 AM   #22538
theisgroup's Avatar
the stiff top deck(not the carpet) and it was the vertical. so the balls stud is 1mm higher on the inner camber link.
yang lai
Old 10-24-2007, 09:04 AM   #22539
Send a message via AIM to adamliehr
How many Schuie guys are gonna be in Cleveland this weekend?
I know Chris and I will be there. I won't be able to run though, I gotta work Saturday. Looking forward to putting "faces with names."
Also, are you guys all running the standard kit servo mounts? Does anyone make light aluminum ones that would fit the mi3?
adamliehr is offline   Reply With Quote
Old 10-24-2007, 09:59 AM   #22540
abailey21's Avatar
Ah yes very good point
K.C.C.O.
Old 10-24-2007, 10:02 AM   #22541
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The kit mounts are all you need, I havent heard of anyone breaking them or having any problems at all.
Old 10-24-2007, 10:06 AM   #22542
Okay, I figured I'd check. I've seen aluminum ones on other cars, and wasn't sure if the ones in the kit were going to hold up. I hadn't had any problems yet, just trying to keep an eye out.
Old 10-24-2007, 12:07 PM   #22543
IslandBwoy's Avatar
Just put an eye on your EPA. The worst thing you can do to the servo mounts is run your servo at full travel. Keep the car stationary and make sure that the mounts do not tweak when you turn full left or full right. Even if the mounts dont move, you will hear some servo chatter as well, if it exerting to much force in either direction.
Other than that, the stock mounts will work fine.
IslandBwoy is offline   Reply With Quote
Old 10-24-2007, 12:24 PM   #22544
redlion's Avatar
I agree with that.
Wes
redlion is offline   Reply With Quote
Old 10-24-2007, 01:37 PM   #22545
Big Features's Avatar
I've only heard from two people heading to the halloween classic. If you are a Team Driver or privateer, shoot me a PM so a can make sure I get enough pit space for everyone. Thanks
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
