Old 10-23-2007, 08:08 PM   #22516
Trader Rating: 15 (100%+)
Default wiring
This is how i did my lipos
Schumacher Corner-dscf0525.jpg   Schumacher Corner-dscf0526.jpg   Schumacher Corner-dscf0527.jpg   Schumacher Corner-dscf0528.jpg
AARON YOUNG is offline   Reply With Quote
Old 10-23-2007, 08:12 PM   #22517
Default weight
Heres how balanced the car.weight in the last two battery slots 9.1 grams per slot.70.5 grams on the back outer edge of the battery.and 34.5 grams around the servo.
Old 10-23-2007, 08:20 PM   #22518
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by KyLayfield View Post
Konichiwa Mr. Sumori, a PM awaits you. Thank you, sir. -Ky (or Kai )
Hmmma MI3 in your future.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 10-23-2007, 08:36 PM   #22519
KyLayfield's Avatar
Trader Rating: 86 (99%+)
I must admit, I do like the design and the support...
KyLayfield is offline   Reply With Quote
Old 10-23-2007, 08:43 PM   #22520
wyd
Tech Legend
wyd's Avatar
The support is awesome thats for sure.
Old 10-23-2007, 09:32 PM   #22521
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I can't stop staring at what look to be holes in your Novak motor . . .!!!
I don't know the weight or dimentsions of the cire lipo, but I would imagine those figures wouldn't work for the 4800 I am using. Thanks for the help anyway though. Having a lighter motor or esc would be a great help!!
Old 10-23-2007, 09:33 PM   #22522
AdrianM's Avatar
Originally Posted by andrewdoherty View Post
lol . . .good ol adrian always pluggin away! It ouwld be nice if there were a couple different terminal options on the orion batteries. Good idea though. Still looking for a way to balance the car regardless of the power source . . .
Yeah but now I do it for free
Hey Shawn... [cough][cough] I need a core Lipo [cough][cough]
Adrian Martinez
Old 10-23-2007, 10:05 PM   #22523
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Adam hold one of those Core lipos for me....maybe 2
Adrian you still running yours? How's it holding up? Also why the hell doesn't the ceramic diff hold up as good/long as a tungsten carbide one?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-23-2007, 10:29 PM   #22524
theisgroup's Avatar
We thought it would be an advantage if we could develop a fast setup for them right out of the box instead of telling them "the setup to run involves another 1-200$ in CF add ons". It would be nice to tell them "you can go fast without buying anything extra other than springs, a set of foams, and a body" Just thought I'd verbalize some of the thinking going on down here in Tejas.
Thoughts??
ok, Mcgoo's iic setup with these changes. I stood the rear shocks up 2 hole and reduce the inner camber link shim by 1mm. the stock center track rod mounted 1 hole from full back. also running 5 degree block, but I think the 6s will work a little better. also running 7 for rear droop. was able to maintain 12.1s with a few 12.0, once the peak was gone on the batts, was doing 12.2-12.3. no traction roll from new parma 53 (~60mm) to <54mm. car was most consistent with 57.5mm-58mm. traction is med, but not as good as a race day.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-23-2007, 10:48 PM   #22525
Awesome Yang. Thanks. Ill be giving you a call tomorrow to make sure i got all the details right. You wouldn't happen to have a second set of light blue and light red xray springs, would you???
As for the ceraminc balls not lasting .. .
I had the same issue, and being the geek I am brought my diff balls to work and took a look at them under the stereoscope. I had two diffs worth of balls and half of them had chips in them. Some almost looked like the moon. I reminded me of when you get those humongous jawbreakers and you chip a layer off. The rest of the ceramic looks glass smooth, but the chips were obvious. I don't have any used carbide balls to look at yet as theyre still in my diff working well.
and while were on the topic . . .If you are feeling thrifty the Losi thrust bearing with the plastic black retainer is a steal for 5 bucks. I have had mine in the car for almost 2 months and haven't rebuilt it yet running foams on carpet. Still butter smooth!
Old 10-24-2007, 03:43 AM   #22526
sosidge's Avatar
Are these the white ceramics or the black ones?
I have heard that the white ceramics have proven to be too hard and brittle, and that the newer black ones that some companies now use are a shade softer and more resilient.
Old 10-24-2007, 04:25 AM   #22527
the ones I was looking at were dark.
Old 10-24-2007, 05:11 AM   #22528
abailey21's Avatar
Trader Rating: 36 (100%+)
give me 72 hours on the Core LiPo's, I have enough for everyone I just need a few days to get them ready to ship
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-24-2007, 05:13 AM   #22529
abailey21's Avatar
Hey Adrian.. [cough][cough] I need a DB12R [cough][cough]
K.C.C.O.
Old 10-24-2007, 05:39 AM   #22530
I 2nd that
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
