Old 10-23-2007, 12:13 PM   #22501
Mr. McGoo's Avatar
Originally Posted by Customworksking View Post
On Goetz iic setup sheet He say's add .75mm to wheel hex to get 190mm well it's no way near 190 I have my car setup like his the only way I c to get 190 is to add to the screw block spacers...unless the parma wheels r wider? any input will help!
what tires are you using?
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 10-23-2007, 01:02 PM   #22502
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default jaco
jaco's... r parma's offset?
Customworksking is offline   Reply With Quote
Old 10-23-2007, 01:07 PM   #22503
Smile pic
pic the other wheel is on 190
Old 10-23-2007, 01:08 PM   #22504
Default oooooooooops
pic oooooooooops
Old 10-23-2007, 01:14 PM   #22505
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
the offset of the 53's is the about equal to current jacos.
i'm staring at his setup now and i think it's correct. the .75mm fr (front) hex spacer will combine with the 1.5mm of screw block spacers to yield maybe 189mm in the front. you can fit about 2.75mm/side of width spacers (either at the hex or the bulkhead) in the front before the car spills over 190 with foams. he's just short of that, at 2.25/side.
the rear of the car doesn't use any screw block spacers (except at the inverted front set to get correct toe), but his sheet instructs us to use enough axle shims to get to 189. i estimate this to be around 2mm/side at the rear hexes.
hope this helps.
note* if you need more steering with this particular setup, i would suggest dropping the front oil in small steps, doing only one shock at a time for the purposes of comparison.
- kazuyoshi sumori -
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-23-2007, 01:36 PM   #22506
Thumbs up car car
hope this helps.
i get what your mean the frt is 189....i was not sure about the rear thanx
Old 10-23-2007, 01:53 PM   #22507
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I haven't looked at seas set up but I know McGoo was running 2mm of rear hex spacers. Maybe they were sharing info? . . .
Old 10-23-2007, 01:58 PM   #22508
MadBrushRacing's Avatar
Hi Guys
if you run stock is there a need to run the inner pulley fences on the diffs and layshaft?
Is there an easy way to get the outer fences off?
Tony
MadBrushRacing is offline   Reply With Quote
Old 10-23-2007, 02:43 PM   #22509
I think most are running the thick fence, but not the thin one. I set the diff pully on the purple diff bearing hodler and use my fingers pushing down to snap it off. Its on there pretty well but it comes off.
Does anyone have a briight idea for balancing an Mi3 side to side? I am 100g over weight with my lipo and a bunch of lead ion the battery side. I have no idea if I am even balanced. I suppose I could try and drill a couple holes for the Hudy balancers, but I don't think I'd be able to get them in the exact right location. I am hoping I don't have to find four scales . . .
Old 10-23-2007, 05:01 PM   #22510
AdrianM's Avatar
Scoot the Lipo out so it is flush with the edge of the chassis. This will reduce the lead you will need to balance the car.
Adrian Martinez
Old 10-23-2007, 05:42 PM   #22511
The negative lead on the battery prohibits any more movement out towards the side of the car. Unless someone has found a way to get the neg lead under the bulkhead? I have to admit I haven't really tried to get it under there with a 90* solder joint or anything . . .
Old 10-23-2007, 06:17 PM   #22512
AdrianM's Avatar
Ah..I see your sig...The Core Lipo allows you to do what I suggested.
Adrian Martinez
Old 10-23-2007, 07:26 PM   #22513
lol . . .good ol adrian always pluggin away! It ouwld be nice if there were a couple different terminal options on the orion batteries. Good idea though. Still looking for a way to balance the car regardless of the power source . . .
Old 10-23-2007, 07:35 PM   #22514
KyLayfield's Avatar
Trader Rating: 86 (99%+)
hope this helps.
Konichiwa Mr. Sumori, a PM awaits you. Thank you, sir. -Ky (or Kai )
KyLayfield is offline   Reply With Quote
Old 10-23-2007, 07:52 PM   #22515
Big Features's Avatar
Bakka Giajing!!
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
