Old 10-22-2007, 09:36 PM   #22471
AdrianM's Avatar
Google rules!
Here is a spring chart with pretty much everything on it.
http://www.petitrc.com/reglages/Univ...pringChart.pdf
Adrian Martinez
Old 10-22-2007, 09:39 PM   #22472
theisgroup's Avatar
Originally Posted by AdrianM View Post
Do you know the spring rates for the Xray Lt.Red and Lt.Blue springs?
Many color blind Xray racers are SCREWED
lt red 35lb and lt blue 20lb
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-22-2007, 09:47 PM   #22473
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by protc3 View Post
Typical delusional adrian. Takes 2 years worth of beatings and somehow remembers winning.
priceless
STLNLST is offline   Reply With Quote
Old 10-22-2007, 09:47 PM   #22474
Mr. McGoo's Avatar
nice job on the google search, i did a search for them when i posted my setup, but i couldn't find the exact #'s.....don't forget that the xray springs run a couple pounds lighter than what they state - so if you don't have the xray's, go for 33/18
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 10-22-2007, 09:49 PM   #22475
dawgmeat's Avatar
Have mcgoo any I c ya lurkin' any rear hubs from team tamale in the works
dawgmeat is offline   Reply With Quote
Old 10-22-2007, 09:51 PM   #22476
Mr. McGoo's Avatar
Originally Posted by theisgroup View Post
thanks, i will take you up on that. I put the "freebe" saver we got at the IIC in mine. and tim lost his. Funny no one in town stocks them (Mike's, T&T) I have some 6 blocks are well, I will try that tomorrow and see.
oh yeah, one other thing. the center track rod mount is one forward from the full back position. this also reduces the throw of the steering rack. I believe everyone with the orion 4800 lipo has this problem. I could not get enough clearance with the mount in the most rear postion.it would just hit the battery
i actually have my stock track rod in the full back position, i have my 4800 crooked just enough where i had to shave off just a tad on the corner of the lipo pack to make it work....
Old 10-22-2007, 09:54 PM   #22477
Mr. McGoo's Avatar
he was lurking here just a second ago....lol....
i have him working on a few ninja stealth CG secrets right now. he is way busy doing some stuff for Xray, but he has let me know he will be making some more stuff for us schuie guys soon enough. I am actually running his 2 degree Xray rear hubs right now that he cut down for me to work on the schuie - they are SA-WEET!!!
Old 10-22-2007, 09:57 PM   #22478
theisgroup's Avatar
Originally Posted by Mr. McGoo View Post
i actually have my stock track rod in the full back position, i have my 4800 crooked just enought where i had to shave off just a tad on the corner of the lipo pack to make it work....
dang, it's a loaner, so probably could not do that. think I can make the entire money race with just one 4800 pack?
yang lai
Old 10-22-2007, 10:02 PM   #22479
Mr. McGoo's Avatar
you are crazy! 5 races on a 4800 - in your dreams....just charge it up after every race.....it doesn't take too long. and just take a dremel to chris's battery - i know he won't mind (too much)
Old 10-22-2007, 10:05 PM   #22480
dawgmeat's Avatar
are using the 2 degrees with rubber/spool???, I was wanted to use use them for the gain in off power steering
Old 10-22-2007, 10:05 PM   #22481
theisgroup's Avatar
you nut, not on one charge. this is my first lipo situation. was not sure I could just run and charge and run and charge ...
if you don't tell, I won't. maybe he won't notice.
yang lai
Old 10-22-2007, 10:07 PM   #22482
theisgroup's Avatar
carpet foam.
Team Tamale will probably have 1, 1.5 and 2 degree. since the xray parts fit. he will just cut the pivot pins hole to fit the schui
yang lai
Old 10-22-2007, 10:11 PM   #22483
Mr. McGoo's Avatar
carpet foam.
i'm with stupid.....
Old 10-22-2007, 10:54 PM   #22484
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
McGoo.you got a PM thanks man
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 10-22-2007, 10:55 PM   #22485
andrewdoherty's Avatar
man, why didn't y'all invite me to the party!
Yang, thanks for the info. Ill be up there Weds, so any info as to what works with the kit topdeck and chassis will be greatly appreciated.
The 2* hubs are being used on foams/carpet.
I am pretty sure I saw the giveaway saver in marcs room. I remember because before time "lost" his to me (THANKS TIM!!) I was thinking of asking marc if he needed it.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
