Old 10-22-2007, 10:59 AM   #22426
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I assume its at the rear, right? If so I have found with foam tires that I have to run a 1 mm spacer between the wheel and the hex to keep them from from rubbing.
Speaking of spacers . . .
Seanuts I heard you and McGoo have the lowdown on some pretty trick wheel spacers that come in .5 and 1 mm thicknesses. Any chance you'd share your source? McGoo couldn't remember the name.
Old 10-22-2007, 11:16 AM   #22427
skypilot's Avatar
Trader Rating: 14 (100%+)
tamiya makes those wheel spacers in alum. your choice of red or blue. enough in a pack to do all four wheels in .5 or 1mm.
skypilot is offline   Reply With Quote
Old 10-22-2007, 11:20 AM   #22428
cool. Thanks!
Old 10-22-2007, 11:23 AM   #22429
Schumacher has the spacers, there made by Riemon.
RY02516S 16pc Alloy Spacers - 1/12th Susp - Sedan Wheel
Monte Hess is offline   Reply With Quote
Old 10-22-2007, 11:26 AM   #22430
I ran my Mi3 for the first time this past Saturday. I can definitely see the potential of this car. I need to spend more time with it though. The car felt very stable even though I think I had a tweak. The car tracked straight on the straight but in the turns, it was great to the left but a little slow to the right.
I want to thank Alan Hewitt for his help Saturday. Those adjustments really helped settle the car down. Looking forward to the next race day so I can do more testing
DOTMAN is offline   Reply With Quote
Old 10-22-2007, 11:28 AM   #22431
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
the ones i gave mcgoo were made by a small shop in slovakia called xray. the pack of them that you are referring to, though, is made by riemon (sp). might want to switch the i and e, or even replace one with an a.
the tamiya set is good, and some of the hpi wheel hex kits come with spacers. check tower/horizon for those...
- rob peters -
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-22-2007, 11:48 AM   #22432
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by dawgmeat View Post
Couple of questions for the Fam
1. what's the benefir of sweeping thr front a-arms
2. steering swept atf vs swept fwd "ackerman"
more armswept = more aggressive cornering, less armswept= more stability
Old 10-22-2007, 11:50 AM   #22433
the spacers may have a tendancy to change the width of the wheelbase, which may cause the car to handle differently. the easiest fix i found was with the handy dremel tool,,see where it is rubbing, and grind away at the arm until it doesnt rub any more, (it only takes a little), and it doesnt seem to weaken the arm...
gdcopbdcop is offline   Reply With Quote
Old 10-22-2007, 11:51 AM   #22434
Super Moderator
Marcos.J's Avatar
look at the attachment
Old 10-22-2007, 12:20 PM   #22435
Mr. McGoo's Avatar
yuppers, those are super trick!
http://www.racing-cars.com/usa/searc...rtname2=partno
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 10-22-2007, 01:13 PM   #22436
AdrianM's Avatar
I will be running Foam Stock at a Thanksgiving Carpet Race....whats the hot setup for an Mi3 nowadays?
It will be Med/High Traction and we will run Paragon.
Adrian Martinez
Old 10-22-2007, 01:21 PM   #22437
theisgroup's Avatar
mcgoo's vegas setup is the hot ticket.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-22-2007, 02:19 PM   #22438
abailey21's Avatar
Trader Rating: 35 (100%+)
You guys can thank Yang for taking up the last set of the Riemon spacers
I'll let you know if we get more in but were being told that we probably not be carrying the Riemon products in the future, but please let me know if guys want them because if the demand is high enough we can get another order.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-22-2007, 02:27 PM   #22439
theisgroup's Avatar
thanks for taking those out of mcgoo's care package and send them to me adam.
yang lai
Old 10-22-2007, 02:31 PM   #22440
STLNLST's Avatar
Trader Rating: 17 (100%+)
I'll pretend that I didn't just hear you ask for set up help.... how are things bro?
STLNLST is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
