Old 10-19-2007, 05:24 PM   #22396
Skiddins's Avatar
Just in case anyone was thinking of getting them, the following shows the original front Mi3 shock mount on top of one of the lowered items.
Both have 4 mounting holes but the lowered shock tower has them much further apart.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-19-2007, 05:26 PM   #22397
Skiddins's Avatar
Originally Posted by yokemad View Post
Hi guys
is there a huge difference between 27t and 19T motors/racing...
I'm not sure If I can handle 19T super stock racing...
Any advice welcome...
thanx in advanced...
Give it a try, the first time you can't believe how much faster it seems.
Driving style is usually the same, no brakes, roll through corners etc.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-19-2007, 06:07 PM   #22398
Trader Rating: 37 (100%+)
Met Shawn and Robin today at iHobby Expo here in Chicago.
They had a LW bulkhead car with them and a bunch of Speed Passion stuff as well. The LW car looked pretty trick in black. The Speed Passion motors/esc should be awesome to run.
I think their big hit will be the East Coast half painted and unpainted bodies. Those were very nice. The Evo9x IMO is a sharp styled body and I plan to run it for rubber tires when it comes stateside...
If you want to go ridiculously fast...Fusion28!!
Nexus is offline   Reply With Quote
Old 10-19-2007, 06:26 PM   #22399
Customworksking's Avatar
Trader Rating: 73 (100%+)
Hi guys
u r correct set it up for 19 and stock will be as good!
Customworksking is offline   Reply With Quote
Old 10-20-2007, 04:31 AM   #22400
yokemad's Avatar
why should I buy lower shock towers??
What effect does it makes to car More grip,better cornering???
Many Thanx...
yokemad is offline   Reply With Quote
Old 10-20-2007, 05:57 AM   #22401
AdrianM's Avatar
Many Thanx...
Its mainly for foam tire carpet racing. Since foam tires are run way smaller (~56mm vs. 63mm for rubber) the suspension has to extend more to get 4-5mm ride height. The shocks are lowered so they are in the proper part of thier up and down travel stroke with the more extended suspension.
Another benefit of the lower towers is that you can run your body a lot lower. There are no body height rules on carpet with foam tires so you can slam it down as low as you can.
Adrian Martinez
Old 10-20-2007, 07:55 AM   #22402
Skiddins's Avatar
Many Thanx...
I have been told that having the lower shock towers means the shock piston starts part way through the oil, instead of traveling right from the end, this allows smoother/more linear shock movement.
AdrianM is also right about foam racing, hence some of the holes allow you lean the shocks over a lot more.
I have two cars now, one with and one without and you can feel and see the difference.
The shocks with the lowered also seem to return to their start position with a more linear motion, move your suspension arms up by hand then let go and you notice that they slow down just before reaching their full extension (with the standard towers).
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-20-2007, 01:08 PM   #22403
yokemad's Avatar
Thanx
Damian and Adrian
hope you'll let us know your thoughts after some race meetings...
Old 10-20-2007, 01:29 PM   #22404
Regional Moderator
Darkseid's Avatar
Yeah, this is key. Because I noticed with the standard height shock towers, a body like the Mohawk sits right on top of the towers just to get it at the proper height.
Say, whats the part number for the lower towers? Front and Rear.
TLR 22...Tamiya F104...
Old 10-20-2007, 04:20 PM   #22405
Skiddins's Avatar
U3152
U3153
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-20-2007, 06:43 PM   #22406
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
HEY SEABALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
you got a PM
Thanks,
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 10-20-2007, 07:17 PM   #22407
Question for the parts guru's...
I blew up an outer axle during todays racing and McGoo hooked me up with a spare to get me back in business.
I was looking for the PN to get a spare (Anything I break once I plan on breaking again...) but there's no breakout of the CVD assembly on the parts explosion. An old message in this thread shows U3234, but the Schuey site isn't finding it. Unfortunately, I managed to throw out the bag tag as well.
It looks like it's the only bit of the CVD assembly that isn't available individually.
U3233 Bone; Alloy CV Driveshaft 1pc
U3026 Pivot; Pin & Screw; Alloy CV D/Shaft
Anyone have any ideas?
Thanks,
Chris
ckearns is offline   Reply With Quote
Old 10-20-2007, 07:32 PM   #22408
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
WOW this post is HUGE started in 2001.
Crazy
BLKNOTCH is offline   Reply With Quote
Old 10-20-2007, 07:34 PM   #22409
Default u
415 steel
Old 10-20-2007, 08:08 PM   #22410
Wink 415 steel #s
the parts u need to run steel bones in your 1way:
46mm L/W bone #51092
415 axle #53499
kit 1way joint #53590
L/W 1 way joint #53704
Traxxas teflon washers 6x8x0.5mm #1985
2 shock 0 rings
the 2 1way joints i have listed will both work but the kit 1 is longer pending what u want to do as u will see the fit vers the L/w "light weight"
ok I have not tried it with a spool or diff but if i were to do it u will need to sand the pin on the bone to fit the blade on Ez to do I will post pics 2mar to show the steps....
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
