Old 10-19-2007, 08:38 AM   #22381
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default lubes
just some notes on lubes.
- be careful of using thick stuff in the front cvd's. the clearance between the o.d. of the bone and the i.d. of the knuckle is tight. if the grease slings out it will fill this gap and really drag down the system. i've had it happen, and now i only use oil on that joint for this reason. i'm sure i just had too much of it on, but i still prefer to be able to freshen up the lube w/o disassembly. a micro-oiler works quite well here.
- the bones/axles are going to wear. they are both aluminum, and aluminum is terrible with respect to abrasion resistance, regardless if they are used with so-called super-lubes. we have one of the nicest axle/bones on the market. just have to replace them more. with diffs, you should still get 3-4 months of weekly racing on them before they are shot.
- diff lubes. on foams, we often run a thicker lube in the front to slow the diffing. i've used both losi brown and green slime with good luck. both of which lubricates way better than silicone and those diffs will almost never crap out because of this. you have to run high tension on them to keep them from slipping, but that falls inline with the goal of dampening out the diff action, so it shouldn't be an issue. again, probably only on foams would this be desireable.
s'all i got.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-19-2007, 09:01 AM   #22382
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by abailey21 View Post
What grease do you guys prefer rebuilding your diff with, the stock silicon diff lube or the black moly grease?
I use AE silicon diff lube (NOT stealth diff lube) and AE black grease on the thrust. The diff lube isn't as thick as the Schuie stuff, and I generally like my rear diff to be as loose feeling as possible without slipping.
Old 10-19-2007, 09:07 AM   #22383
Regional Moderator
Darkseid's Avatar
I use the stock diff lube. I like it better than anything else I've used before.
And I use Associated black grease for the thrust assembly.
TLR 22...Tamiya F104...
Old 10-19-2007, 09:13 AM   #22384
Suspended
McSmooth's Avatar
Thumbs up
You will be hard-pressed to find a more experienced authority on lubing your bone than Mr. Seaball.
Nice work, sir.
- Archibald Stillweather -
McSmooth is offline   Reply With Quote
Old 10-19-2007, 11:59 AM   #22385
Customworksking's Avatar
Trader Rating: 73 (100%+)
Originally Posted by mutley001 View Post
Need some help guys
Been running Custom's IIC setup and its been working great on a large flowing track, but for a small tight track at our local club its just too hard to drive fast on this type of circuit (were talking about sub 10 second laps)
Any suggestions about what changes to make first?
All help gratefully recieved
Paul
what is the car doing ?
Customworksking is offline   Reply With Quote
Old 10-19-2007, 12:18 PM   #22386
mutley001's Avatar
It's really quick on the odd lap but just not consistent. Has good turn in and on power steering but feels just unstable, that's the thing you see, if it was loose of pushing I'd know what to do but, I'm really a bit stuck!
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 10-19-2007, 12:31 PM   #22387
Thumbs up car
b sure it's not teaked "i'm sure u did ",no bent pin's ...it may be reacting to fast solw it down with oil 50wt in all 4..take some droop out 4,3mm ,b sure your tires have not came loose "check side wall gule"....let me know what u try ...and as allways 1 thing at a time
Old 10-19-2007, 12:34 PM   #22388
Wink Foam Tire
where can I find a good stock/19t foam tire set up sheet or is the Kit Carpet Foam Set Up a good starting point....I just got my 2nd mi3
Old 10-19-2007, 12:37 PM   #22389
Try a thicker front sway bar, possibly a more progressive spring or heavier shock oil.
Old 10-19-2007, 12:38 PM   #22390
Just run whatever Goetz and McGoo ran at Vegas, their cars were dialed.
Old 10-19-2007, 12:46 PM   #22391
Default car
where can I find them please..thanks
Old 10-19-2007, 12:52 PM   #22392
Red face ooooooooops
found it on page 734 thanx
Old 10-19-2007, 12:58 PM   #22393
mutley001's Avatar
Thanks guys, will give it a try and let you know how it goes!
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 10-19-2007, 02:28 PM   #22394
yokemad's Avatar
Default 27T to 19T
Hi guys
is there a huge difference between 27t and 19T motors/racing...
I'm not sure If I can handle 19T super stock racing...
Any advice welcome...
thanx in advanced...
yokemad is offline   Reply With Quote
Old 10-19-2007, 02:30 PM   #22395
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I second that. Marc is runnig the same setup back here at home with just one or two small changes and is smoking fast. Not only that but I am fast when I drive his car. When I am faster with his car using his radio with just a lap or two to get used to it than I am with my car and radio that Ive had for months, I know the setup is dialed. Espcially since we run on low-medium bite carpet. It seems pretty universal.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
