Old 10-18-2007, 10:12 AM   #22366
abailey21's Avatar
Trader Rating: 36 (100%+)
Its a mixture of both, we have some older ones obviously purple, and some newer ones recently delivered which are the newer silver ones
Originally Posted by andrewdoherty View Post
just looking at all my options. The u3233 are the older purple alloy or the newer silver?? I was thiking they were the older purple ones.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-18-2007, 10:13 AM   #22367
Send a message via ICQ to MattW
Think it was a running change on the driveshaft bits - so part numbers will be the same.
We've been running the non keyed rings for quite some time. Shouldn't work at all, but it does, they defenetly make the diff run nicer for longer.
MattW is offline   Reply With Quote
Old 10-18-2007, 11:16 AM   #22368
POUNDITRACING's Avatar
Originally Posted by Randy Caster View Post
Thats why I offered to help you build your car Your diff would still feel new, lol.
I should be at the track on Sat, so we can take a few mins to rebuild your diff and show you what to do.
If you build my diff I might be able to finish something other than 3rd. For the past 2 months I've been third in every class I race in.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 10-18-2007, 01:12 PM   #22369
MMS1's Avatar
Send a message via AIM to MMS1
Wes thanks would like me to get gasket for golf car
MMS1 is offline   Reply With Quote
Old 10-18-2007, 01:22 PM   #22370
skypilot's Avatar
Trader Rating: 14 (100%+)
just use a kimbrough medium servo saver. THe one with 5 holes. PN 201 I believe.
That and I am still getting excesive wear where the outter pin rotates inside the alloy bowl.
get some tamiya anti-wear grease, the green sticky stuff, gober that stuff on all contact surfaces and moving areas. built/rebuilt my cvds with that and no issues in that area. just be sure to lock tight the grub screw and insert it before applying grease.
skypilot is offline   Reply With Quote
Old 10-18-2007, 01:25 PM   #22371
STLNLST's Avatar
Trader Rating: 19 (100%+)
jon kerr has been sort of quiet as of late. How's my old Schumacher homies doing?
STLNLST is offline   Reply With Quote
Old 10-18-2007, 02:33 PM   #22372
Kerr has been running off road 1/8 gas. What a gasshole. I've been trying to get him out for a couple of weeks but he's been going to Hawaii.
Old 10-18-2007, 03:35 PM   #22373
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Ill have to try that on one of my front CVD's. I only get wear int he front. I assume its the increased articulation over the rear CVD"s. I might have to wait and order new bones once the stock becomes all silver. I ahve had beter luck with the silver ones Thanks for all the help folks. Luvin my schui!!
Old 10-18-2007, 03:52 PM   #22374
MMS1's Avatar
Wes 8 dollars will pick it next week
Old 10-19-2007, 06:32 AM   #22375
redlion's Avatar
Default gasket
Ok cool.
Wes
redlion is offline   Reply With Quote
Old 10-19-2007, 07:19 AM   #22376
mutley001's Avatar
Need some help guys
Been running Custom's IIC setup and its been working great on a large flowing track, but for a small tight track at our local club its just too hard to drive fast on this type of circuit (were talking about sub 10 second laps)
Any suggestions about what changes to make first?
All help gratefully recieved
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 10-19-2007, 07:19 AM   #22377
abailey21's Avatar
What grease do you guys prefer rebuilding your diff with, the stock silicon diff lube or the black moly grease?
K.C.C.O.
Old 10-19-2007, 07:45 AM   #22378
Ian S's Avatar
You need to use the clear silicon grease on the main diff balls and the black moly grease on the thrust race. The 2 different greases do entirly different things so you really dont want to mix them up!
Team Schumacher UK
Ian S is offline   Reply With Quote
Old 10-19-2007, 07:58 AM   #22379
abailey21's Avatar
you know i kinda figured thats what i would hear, and thank you. i did use the not keyed diff rings and can really feel a difference even by hand
K.C.C.O.
Old 10-19-2007, 08:03 AM   #22380
Mr. McGoo's Avatar
i use the stock diff grease for the diff balls, and i like the associated black grease for the thrust....
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
