Old 10-17-2007, 09:06 PM   #22351
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Customworksking View Post
pic of 1 side
I am guessing that would only work with a spool or one way??? Or could you use the 415 CVD's with a diff too?
Old 10-17-2007, 10:00 PM   #22352
Trader Rating: 36 (100%+)
Are you doing this because you have parts laying around or for a specific reason? Just wondering as I don't feel the stock pieces have any problems. Plus running a "no-blade" type of outdrive wears quick.
Nexus is offline   Reply With Quote
Old 10-17-2007, 10:02 PM   #22353
Customworksking's Avatar
Trader Rating: 71 (100%+)
Cool mi3
yes it will work with a diff as well .. if u want all u need to get it to work pm me ....I have a foam mi3 on the way so, if u feel it will need steel up frt as well i will do it to.......
Customworksking is offline   Reply With Quote
Old 10-17-2007, 10:09 PM   #22354
Cool
I have had my 415 from day 1 1st 415 then 415ms,415msx mre and the msxx
and soon 416...and i have the same Lw out drives from 3yrs ago in the pic i posted ZERO wear and no blades....the car need's steel bones..........they bend...
Old 10-18-2007, 04:38 AM   #22355
Skiddins's Avatar
Originally Posted by yokemad View Post
Hi guys
I won a PF Dodge stratus 3.0 Carpet Bodyshell at raffel
What are your thoughts about that body shell Does it worth to try or should I put it to ebay ???
Cheers
I used the Stratus 3.0 All Purpose at Carpetwars and it was superb.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-18-2007, 05:47 AM   #22356
yokemad's Avatar
Thanx Damian
It's PF and for Carpet worth to try
I've bought some of that new titanium screws they are very good quality with a reasonable price... I'm in trouble with that schumacher servo saver I didn't manage to put it together any help ??? SOS
yokemad is offline   Reply With Quote
Old 10-18-2007, 06:11 AM   #22357
just use a kimbrough medium servo saver. THe one with 5 holes. PN 201 I believe.
As for the dogbones I am hoping to try something else as I have bent both front CVD's pretty badly. This happenes collisions where you break an arm and the dog bone is taken with it and bent at the c-hub where it goes thorough. That and I am still getting excesive wear where the outter pin rotates inside the alloy bowl. The price of the schumacher parts has kept me from replacing it . . .48$$ or something I think!
Old 10-18-2007, 07:21 AM   #22358
Regional Moderator
Darkseid's Avatar
I would actually recommend the kimbrough medium without the predrilled holes. It lets you put the hole just where you want it(like closer to the edges than the predrilled holes...which lets you stay closer to the original Schumacher arm angle). And if you decide to cut some of the servo saver arm off for clearance concerns, you don't have to worry about the arm already having holes all through it.
Heres a link: http://www3.towerhobbies.com/cgi-bin...?&I=LXND48&P=7
TLR 22...Tamiya F104...
Old 10-18-2007, 07:21 AM   #22359
abailey21's Avatar
Why donít you just pick up a replacement set of bones, Part# U3233 for $18 you just fixed you cvd's instead of piecing together other kits?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-18-2007, 07:37 AM   #22360
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by PW View Post
Racer tip: Ditch the stock rings and switch to the non-locking rings U2408
racer tip? who did you get that from?
features - i'll be there, but i've got an assigned seat.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-18-2007, 07:55 AM   #22361
Send a message via AIM to smitty2802
whos this seabal guy.. i heard hes alittle... ah funny...
whats going on man.. havn't talked to ya for a while
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 10-18-2007, 08:00 AM   #22362
abailey21's Avatar
Tips and tricks we've been emailing out for a while now. Not sure if it was Randy or PW that figured it out, but we've been sharing that info for a while
K.C.C.O.
Old 10-18-2007, 09:03 AM   #22363
seaball's Avatar
-DC-
haha. i've got it pretty much all worked out now. 4th in vegas was a little better showing (my first weekend on my car) than when we last met up. christ, it's painful to recall. you coming up for the classic, chump? how ya' been?
who is this pw guy? the e-mail i got said to put sand in the silicone lube to help them wear in... "like wet sanding", he said...
Old 10-18-2007, 10:01 AM   #22364
ah i gotta miss it again man.. i'm sorry... right now i got a loaner 007 to run w/e i can but i'll have another mi3 to run rubber tires with b/c thats all i'll be running from now on.. i've been racing 8th scale gas buggies
-DC-
Old 10-18-2007, 10:01 AM   #22365
just looking at all my options. The u3233 are the older purple alloy or the newer silver?? I was thiking they were the older purple ones.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
