Old 10-17-2007, 11:34 AM   #22336
Send a message via AIM to adamliehr
Hey guys, I had a question about the diffs.
How long should these diffs go in stock without needing rebuilt? I have only been getting about 6 runs before they feel like crap in stock. Is this normal?
adamliehr is offline   Reply With Quote
Old 10-17-2007, 11:39 AM   #22337
abailey21's Avatar
Trader Rating: 36 (100%+)
RP Med
Originally Posted by Randy Caster View Post
What inserts did you find for me to mount?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-17-2007, 12:47 PM   #22338
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
no. i would get 6 months on them (no lie). if my setup crapped them out, i would loosen it, slip it over and over holding the spur and the opposite tire, and voila, it was cut back in. the beauty of ceramic balls. however, they should not be crapping out nearly that fast unless grip is pathetic or your setup is unbalanced.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-17-2007, 01:59 PM   #22339
POUNDITRACING's Avatar
I have the same prolbem. I have run a very loose track a couple of times but I've only had the car for about 2 months. It seemed like all the lube was gone.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 10-17-2007, 02:25 PM   #22340
Customworksking's Avatar
Trader Rating: 73 (100%+)
Smile dog bones
sup all,Has anyone tried to run tamiya 415 steel dogbones up frt ...I put them on just now if anyone needs to know what u need to do it.. they work perfect + u don't need the 1mm shim with the hex....
Customworksking is offline   Reply With Quote
Old 10-17-2007, 02:53 PM   #22341
Haha, okay. thanks.
Old 10-17-2007, 03:21 PM   #22342
Red face mi3
I was wondering how the car reacts to width........ do u want to run a rubber tire car 190 frt and rear or 185 frt/rear ....190frt 185 rear ect
Old 10-17-2007, 04:29 PM   #22343
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Thats why I offered to help you build your car Your diff would still feel new, lol.
I should be at the track on Sat, so we can take a few mins to rebuild your diff and show you what to do.
Old 10-17-2007, 04:35 PM   #22344
yokemad's Avatar
Hi guys
I won a PF Dodge stratus 3.0 Carpet Bodyshell at raffel
What are your thoughts about that body shell Does it worth to try or should I put it to ebay ???
Cheers
yokemad is offline   Reply With Quote
Old 10-17-2007, 04:41 PM   #22345
I have had a few issues with the diff also.
The first time it oly laster a few runs, when i pulled it apart it seems the moly grease had entered the diff gear section, and the combination of the 2 greases turned into a type of sludge.
2nd rebuild, polished the rings again btw the rings seem very soft. used less moly on the thrust, and it lasted longer however i still cant get the diff action to be as free as other cars i have owned, on the track it feels as it it affects accelearation when not going in a direct straight line.
It feels as if the internals are binding in the thrust and concave washer area.
Anyone have any tips?
Besercoe is offline   Reply With Quote
Old 10-17-2007, 04:42 PM   #22346
What did you do in relation to the spool outputs, wouldnt the slots be too narrow to use the tamiya pin cushions?
Old 10-17-2007, 04:53 PM   #22347
PW
PW's Avatar
Send a message via AIM to PW
Check the thrust washers; they are 2 different sizes as one has a slightly larger OD. Please refer to the manual for proper installment.
The Schumacher diff should last months as Seaball stated. If not; then something is assembled wrong or has the wrong tension.
Racer tip: Ditch the stock rings and switch to the non-locking rings U2408
PW is offline   Reply With Quote
Old 10-17-2007, 05:00 PM   #22348
Default mi3
I used the tamiya 415 1way L/W outdrives
Old 10-17-2007, 05:04 PM   #22349
Thumbs up pic
pic of 1 side
Old 10-17-2007, 05:54 PM   #22350
Big Features's Avatar
CALLING ALL TEAM DRIVERS, SUPPORT RACERS, AND PRIVATEERS!!!
Want to get a count of people going to the Halloween Classic, I'd like
to get a pit area together for us.
PM me if your going to attend and I'll talk to Jimmy Herrmann at the Gate
and reserve some spots.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
