Old 10-16-2007, 06:42 PM   #22321
Big Features's Avatar
I would take 1mm of Droop out of the rear and lower the rear roll-center by .5
That should give you more "off power" grip.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 10-16-2007, 07:27 PM   #22322
Customworksking's Avatar
Trader Rating: 71 (100%+)
i found when running low bite less works ......it's worth a try
Customworksking is offline   Reply With Quote
Old 10-16-2007, 08:23 PM   #22323
Trader Rating: 15 (100%+)
Default setup
I ran jimmys setup and found it to be way to loose in med bite track.Also the rps are smaller than the jacos so you have to change the droop.The changes i made were going back to the standard hole on the steering block ,1mm less droop in the rear and stood the rear shocks up one hole.
AARON YOUNG is offline   Reply With Quote
Old 10-16-2007, 09:39 PM   #22324
JayBee's Avatar
Trader Rating: 31 (100%+)
Schumacher MI3 is definitely the truth. With the help of team drivers Brett Sisley (DIALED) & Ritchie Reynolds (skypilot), our cars are definitely on the 'FAST' side of the tracks..........
Go Schumacher!!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-17-2007, 03:43 AM   #22325
yokemad's Avatar
Agree with you AAron Standing rear shocks 1 hole up and front shocks one hole in makes car much better...I normally set droop like 5.5mm front ,4.5mm rear
yokemad is offline   Reply With Quote
Old 10-17-2007, 04:16 AM   #22326
The Shrew's Avatar
Can anyone explain what difference it makes having the steering plate in the different positions please ?
The Shrew is offline   Reply With Quote
Old 10-17-2007, 04:51 AM   #22327
Skiddins's Avatar
Originally Posted by Nexus View Post
I want to double check something regarding rear toe...
2mm shim in the front
1mm shim in the rear
stock rear hubs
= how much toe?
.5mm shim in the rear
1deg alum rear hubs
= how much toe?
Well;
0mm shim in the rear
1deg alum rear hubs = about 3deg
I believe this will be the same as your first example
It said somewhere that each 0.5mm shim added 0.6deg of toe, but I'm not so sure.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-17-2007, 06:46 AM   #22328
Trader Rating: 36 (100%+)
Originally Posted by Skiddins View Post
Well;
Skiddins
If your example is correct then...
stock rear hubs
= how much toe = 3deg
1deg alum rear hubs
= how much toe = 3.6deg'ish? :P?
I'll just use my camber gauge and hold the car upright to get an idea of degrees.
Thanks for the input.
Nexus is offline   Reply With Quote
Old 10-17-2007, 09:21 AM   #22329
MagicMarker's Avatar
I believe the rear of the car without shims is 4mm. So if you start adding shims or hubs with specific degree in them you can alter your toe.
2mm in front of rear bulkhead would give you 2mm toe.
Marker
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 10-17-2007, 09:46 AM   #22330
POUNDITRACING's Avatar
Need help.
What is the name for the parts that you change to set the acramen? It goes on top of the stearing rack. Does anyone have a part #?
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 10-17-2007, 09:55 AM   #22331
Pound -
Track rod set - U3135
Chris
ckearns is offline   Reply With Quote
Old 10-17-2007, 10:51 AM   #22332
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by abailey21 View Post
I had to send you the rev lites Randy, U2005 cause we only had one set of the RP's, we never booked the rims on as a product for some reason, i'm gonnna ask Robin and Shawn as to why we dont carry them?
What inserts did you find for me to mount?
Old 10-17-2007, 11:05 AM   #22333
Originally Posted by ckearns View Post
Pound -
Chris
thanks.
Whitch one dose everyone use???????
Old 10-17-2007, 11:16 AM   #22334
Skiddins's Avatar
Originally Posted by POUNDITRACING View Post
thanks.
Seems to be the medium or short length, with the holes the same width as the kit item.
I position the steering post so that the arms are dead straight with eachother when looking from above.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-17-2007, 11:27 AM   #22335
thanks.
For BCR I use the medium width longest one. The shorter ones will mellow the car out too much for that track.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
