Old 10-16-2007, 12:39 PM   #22306
Trader Rating: 36 (100%+)
I want to double check something regarding rear toe...
2mm shim in the front
1mm shim in the rear
stock rear hubs
= how much toe?
.5mm shim in the rear
1deg alum rear hubs
= how much toe?
Nexus is offline   Reply With Quote
Old 10-16-2007, 12:41 PM   #22307
abailey21's Avatar
We've been running about 5.0-4.5 on out local track
Originally Posted by Customworksking View Post
has anyone ran the brushless 13.5 yet if so,how did u gear it?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-16-2007, 01:01 PM   #22308
Randy Caster's Avatar
Trader Rating: 46 (100%+)
stock rear hubs
= how much toe?
1deg alum rear hubs
= how much toe?
I've never measured the rear toe on the car, but if you want to know just sit the car up on the rear and use a camber guage to measure the toe.
Old 10-16-2007, 01:09 PM   #22309
Solara's Avatar
Trader Rating: 16 (100%+)
I am looking up all my cheat sheet(setup for 13.5 and CO27 on my Schumacher)......
Novak 13.5 with the stock sintered rotor (not 13mm)....final drive from 4.5-5.0.......I have tried the 4.5 1 time and gave me a thermal right after the race is finished....I do have the purple heatsink on it but no fan...much more fan on the GTB speedo though....
From the same race that NEXUS and I ran....I was running about 4.85....car is PLENTY fast already, just not enough rear toe and my car keep turning sharp on each turn and made it difficult to turn/drive.
For CO27...my final drives are 7.5-8.0.............a lot easier to drive cause it is slower and like Nexus said...car does slow down a lot when the throttle is off................but not on my 13.5. Almost need a phyical drag brake (like gas car) on the Schumacher.....
Old 10-16-2007, 01:21 PM   #22310
STLNLST's Avatar
Trader Rating: 19 (100%+)
change your drag brake profiles when using the 13.5. If you're using the regular GTB not the spread spektrum then the drag brakes should be pretty strong.
STLNLST is offline   Reply With Quote
Old 10-16-2007, 02:53 PM   #22311
yokemad's Avatar
Default rubber tyres
hi dudes
what is the difference between different rated rubber tyres???
as far as my knowlage it's temperature...
two weeks ago I've tried sorex 22 tyres on very low grip carpet and they gave me a bit more overall grip but If I use them med-high grip carpet where people usually use 24 or 27R tyres will it be an advantage or disadvantage due to temp. issues I know over heated tyres loose their grip...
all ideas welcome...
yokemad is offline   Reply With Quote
Old 10-16-2007, 03:13 PM   #22312
The rating does generally mean temp, every manufacturer seems to use different rating systems, so the easiest way to get around figuring it out is just run what everyone else runs. The lower #'s generally also mean a softer tire, so they will wear faster as well.
Old 10-16-2007, 03:40 PM   #22313
abailey21's Avatar
speaking of tires Caster, I have sent you some this afternoon
K.C.C.O.
Old 10-16-2007, 03:50 PM   #22314
Customworksking's Avatar
Trader Rating: 71 (100%+)
can U have some to! lol
Customworksking is offline   Reply With Quote
Old 10-16-2007, 04:51 PM   #22315
Did you guys find enough RP rims and inserts for me to use with them?
Old 10-16-2007, 05:33 PM   #22316
Trader Rating: 114 (100%+)
Ran the car today... 10.5.. wow, she was hooked up OK.. but I do not like the jaco Green tires. Even with Red springs in the front, the car was SUPER LOOSE.. going to try RP30s this Friday.
Chris Furman is offline   Reply With Quote
Old 10-16-2007, 05:57 PM   #22317
Big Features's Avatar
What setup are you running? Remember to sauce only half the front and all of the rear. Are you loose off power or on power?
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 10-16-2007, 06:13 PM   #22318
I am loose coming off power, either entering and/or thru corner. If I keep throttling it, it straightens back out, but I lost time already. I am using the "Kev" setup but with 60wt Front, 40wt Rear. Higher oil kept the car from bouncing around the long sweepers. Red Springs in front with White springs in Rear, stock sway bars.
Old 10-16-2007, 06:27 PM   #22319
Questions??
the grees r fine is the 10.5 like a 19t ? anyway dope full rears and 1/4 frt u have to much frt biet it will b the same on rps ..if the car is reacting to fast try 50 50wt oil ......my setup has a push but even on high bite i doped full frt and loose as heck....if anything go down in droop try 4 and 3mm
Old 10-16-2007, 06:38 PM   #22320
abailey21's Avatar
I had to send you the rev lites Randy, U2005 cause we only had one set of the RP's, we never booked the rims on as a product for some reason, i'm gonnna ask Robin and Shawn as to why we dont carry them?
K.C.C.O.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
