Old 10-12-2007, 04:02 PM   #22216
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Actually we didn't switch to the HPI springs because of their stiffness, we switched because they are more progressive. The HPI springs have more coils in them than the Schuie springs do. Basically it will make the car less aggressive and easier to drive. I ran HPI silver and gold on my car, 1 step up from pink and blue.
Old 10-12-2007, 04:02 PM   #22217
abailey21's Avatar
Trader Rating: 36 (100%+)
You may want to contact Shawn about that
Originally Posted by Todd Putnam View Post
...Hey Schumacher Guys: Speaking of springs, if any of you have the old Schumacher Gray springs, (#U1923) that you'd like to sell, let me know...
Thanks!
Todd Putnam
Putnam Propulsion
518-452-0422
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-12-2007, 04:43 PM   #22218
PW
PW's Avatar
Send a message via AIM to PW
Hey watch it! Shawn has the last set and they where mine...LOL
PW is offline   Reply With Quote
Old 10-12-2007, 04:43 PM   #22219
AdrianM's Avatar
Thanks!
Todd Putnam
Putnam Propulsion
518-452-0422
Schu UK is out of stock and has discontinued them. We (Paul and I) asked Robin to make a run of 1000pcs for the Dirt oval market and he said no. I would call Shawn and have him lean on Robin some
Adrian Martinez
Old 10-12-2007, 04:45 PM   #22220
Big Features's Avatar
I personally use the Schumacher and Xray springs
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 10-12-2007, 06:06 PM   #22221
justin lessard's Avatar
Send a message via AIM to justin lessard
I use mostly xray and corally springs on carpet
justin lessard is offline   Reply With Quote
Old 10-12-2007, 06:09 PM   #22222
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
General Mi3 set up question . . .
I and others feel my foam car is rolling (side to side) too much. I have tried a couple ideas and haven't come across anything that has remedied the roll. I figured I'd throw it out to y'all just to hear your ideas. if you have a basic explanation as why a particular change would limit roll please feel free to include it.
I am running McGoo's vegas set up posted earlier with the following changes
DNA Body( not mohawk)
Stock Chassis (not the 2.5)
Next shorter track rod moved forward one position
Rear shocks moved out one hole on the tower
Stiff topdeck (not the carpet top deck)
2.5 * camber (not 2.2*)
I tried every possible tire size between 58 mm and 54 mm. My car is actually traction rolling with all but the smallest of small tires that actually push because the outter edge is worn to the plastic on the pro 53's. I am thinking my problem has something to do with execution in one of the more ambigious areas of set up such as diff tension, shock rebound or the likes. Don't be shy though, I ain't afraid to learn!
Old 10-12-2007, 06:34 PM   #22223
I assume your running magenta all the way around? if so,how much of the front tire are you saucing?..the more flexible topdeck and chassis isnt helping the traction rolling issue either...are you using the carpet shock towers?...I would inspect the edges(sidewall) of the tires,make sure they are nice and round,also make sure the caster blocks are not on backwards,excessive droop can also cause traction roll,you want about 1-2.5mm uptravel in the front and 2-4mm uptravel in the rear,never much more,shock oil is 50wt up front correct?..with around 50-80% rebound
Old 10-12-2007, 07:59 PM   #22224
Thank you. Good points. Keep em coming guys.
Old 10-12-2007, 10:02 PM   #22225
JayBee's Avatar
Trader Rating: 31 (100%+)
Quickie ???- Does anyone run a DNA1 on the rug?? What about @ the iiC?? I rather enjoy my MI3 (with an slightly altered Chris G. setup) using the DNA1. Has just a hint of push but really nimble behaving....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-13-2007, 05:59 AM   #22226
Mr. McGoo's Avatar
Jaybee,
I think most stock and 19T guys were running the mohawk. I saw a few DNA's out there, but the consesus seemed to be the Parma.
From my experience the DNA has more downforce and can keep the car stuck a bit more (that's why you will see more DNA's in mod). The Mohawk seemed to free up the rear end for me. I have played with both and I keep coming back to the Mohawk. I am gonna try out the DNA today to see how it compares....
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 10-13-2007, 06:01 AM   #22227
abailey21's Avatar
Were both leaning on Robin pretty hard on the springs, as for your "last set" Paul, we found about 3 more pairs around the shop
K.C.C.O.
Old 10-13-2007, 06:09 AM   #22228
yokemad's Avatar
You know that east coast half painted mazda speed6 bodies are they like protoform speed6 If not is there anybody here tried them on carpet?
any feedback is welcome...
yokemad is offline   Reply With Quote
Old 10-13-2007, 07:32 AM   #22229
Originally Posted by Mr. McGoo View Post
Jaybee,
I usually run a DNA1 on carpet with a Parma Alfa wing. That alows the car to "free up" alittle. The DNA1 just has more steering.
Mike Kling
Old 10-13-2007, 07:44 AM   #22230
JayBee's Avatar
Thanks for the feedback
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
