Old 10-07-2007, 12:04 PM   #22111
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by yokemad View Post
Is brushless faster than brushed motors???
IMO, generally speaking YES. But there are some guys who can tune/tweak (some methods illegal, some not) the hell outuva Stocker. Irregardless though, the 'meat' of of this debate highly depends on set-up & driving skills.....
The deal is this- the faster guys at any track is fast with either one.....BUT Brushless is the new GOTTA HAVE technology. I'm sold!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-07-2007, 12:28 PM   #22112
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I need to get the brushless stuff figured out.. keep going back to brushed motors everywhere I go.
Old 10-07-2007, 02:11 PM   #22113
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by abailey21 View Post
the minute I have them, you'll know. It should be next week????
hey Adam check your pm!!
Old 10-07-2007, 05:36 PM   #22114
yokemad's Avatar
Hi Mates
On Kev's setup It says 1.5mm Pivot block spacers At rear settings If I do that 2mm Does it gives me more rear end grip Or what kind of effect does it makes ?
I'm not racing on a high grip carpet ,It is medium Grip...
Also What are the rates of anti Roll bars comes with kit?
Many Thanx
yokemad is offline   Reply With Quote
Old 10-07-2007, 07:36 PM   #22115
at our club some guys were running 13.5 against brushed and they were much faster than brushed motors but I'm not sure If that's because of driver or Motor differences ?
This is a bit of a problem....the 13.5 with the BONDED rotor is pretty close to the brushed motor...the 13.5 with the SINTERED rotor is WAY faster than the brushed motor...In Australia ...in Brisbane where I race the 13.5 with bonded rotor is allowed to run against the brushed motors but the 13.5 with the sintered rotor is illegal...the 13.5 with the bonded rotor is the EX13.5...hope this helps
Barger is offline   Reply With Quote
Old 10-07-2007, 07:42 PM   #22116
STLNLST's Avatar
Trader Rating: 19 (100%+)
what's a brushed motor????? You're sponsored by Orion right......A few guys out this way have had a harder time getting use to their motors compared to Novak and LRP. I'll never go back to brushed again. I can't even run any 19 turn classes at big events anymore. I'm too spoiled by the brushless stuff.
STLNLST is offline   Reply With Quote
Old 10-07-2007, 09:10 PM   #22117
Customworksking's Avatar
Trader Rating: 71 (100%+)
Hi Mates
Many Thanx
u got it backwards run 1.5mm in the frt and 2.5mm in the rear ..U will need to keep a 1mm swing frt to rear....lower rollcenter more grip/high rollcenter less grip u will be fine @ 1.5mm frt and 2.5mm rear...sway bars 1.20,1.40 is gold and 1.60 black
Customworksking is offline   Reply With Quote
Old 10-07-2007, 10:27 PM   #22118
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I picked up a used Mi3 to run ruber tires and it came with a one-way. It does not have a pulley mounted on it however and when I quickly tried the pulley from my spool, the internal hole on the spool pulley was too small to fit on the oneway. It goes over the outdrives, but not the center section. Did I rush too fast and miss something or is there a seperate pulley for the one way?
Old 10-07-2007, 11:04 PM   #22119
The Orion BL stuff has a ton of power, I can drive a 4.5 pretty well, but I gotta get a throttle profile figured out for the 3.5. Brushed may be old technology, but I have no problem running it still I didnt take my V2 mod motor apart once at the IIC all through qualifying and the main and didnt lose any power.
Old 10-07-2007, 11:05 PM   #22120
There is a different pulley needed for the 1-way. You could ream out the hole in the spool pulley but you might risk having a slightly lopsided pulley that way.
Old 10-08-2007, 12:28 AM   #22121
all right . . .thanks for the info Randy. I think I'll ream out the spool pulley . . .I am thinking the 3 screw holes will keep everything lined up and running true regardless of any lopsidednes in the center hole. Now I just gotta make sure the three holes re the same spacing as on the spool. Thanks again.
Old 10-08-2007, 09:50 AM   #22122
Skiddins's Avatar
Originally Posted by Customworksking View Post
I missed something on the front the pivot block spacers all 4 fronts need to be 1.5mm ...sorry ..... the frt bulkheads r lower than the rear so, 1.5mm in the frt and 2.5mm in the rear ='s the same rollcenter frt to rear....
Didn't see the post further above
I have now changed the rear RC to 2.5mm
OK now?
'Customs' IIC Setup
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-08-2007, 12:20 PM   #22123
Trader Rating: 36 (100%+)
Default New style Schumacher Mi3 shirt.
It looks like this shirt may see production. I don't have specific details in regards to pricing but I'm trying to get an idea of how many people would be interested.
I'm looking at dye-sublimination instead of traditional silk screening. This in theory last longer and does not suffer the same "cracking" effects you find with silkscreened shirts. With dye-s the color is embedded into the fabric.
Anyway if you have any interested in buying one please PM/Email me so I can get an idea of quantity. Most likely I will only order a specific amount that have been prepaid. When I have more details I will post them.
Nexus is offline   Reply With Quote
Old 10-08-2007, 12:27 PM   #22124
Tim Kowal's Avatar
R/C Tech Charter Subscriber
You could also set up a store at Printfection, that way anyone can order it and you could make a commission each shirt, and not have to carry inventory.. The quality is great, I have had several different shirts printed there.
http://www.printfection.com/
Tim Kowal is offline   Reply With Quote
Old 10-08-2007, 12:30 PM   #22125
Regional Moderator
Darkseid's Avatar
Did my first shake down run on carpet with the Mi3 this weekend, and all I can say is WOW!
I stuck pretty much to the manual's carpet set up, with only a few changes. The car was just beautiful.
TLR 22...Tamiya F104...
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
