Old 10-05-2007, 06:29 PM   #22081
Customworksking's Avatar
Trader Rating: 71 (100%+)
Post yes
Originally Posted by Skiddins View Post
Can Custom please check I've done this right.
As I don't know your real name etc I've left some bits blank.
'Customs' IIC Setup
Please tell me if anything is wrong and I'll correct it.
Skiddins
U can add servo saver yes, 20% rebound on all shocks and u got it I also doped the tires 20min b4 race full rears 1/2 frt ...motor's co27 and orion 19t
both fdr 7.20..btw my name is Kevin Bottoms
Customworksking is offline   Reply With Quote
Old 10-05-2007, 07:15 PM   #22082
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by JayBee View Post
I like the Lunsfords stuff I have
The new stuff basically looks exactly like lunsford parts, but the pricing should be lower
Old 10-06-2007, 03:10 AM   #22083
Skiddins's Avatar
I bought I load of Lunsford Ti screws, byt the time they were shipped to the UK it certainly wasn't cheap.
A Week after I got them Schuey anounced their Ti screws and prices....would have waited if i'd known
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-06-2007, 03:20 AM   #22084
Skiddins's Avatar
OK, this should now be correct, all the origianl links work as I haven't changed the name of the file;
'Customs' IIC Setup
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-06-2007, 05:24 AM   #22085
yokemad's Avatar
many thanx to Kev and Damian...
when do we need and how you can measure the 20% rebound?
If your car is loose and oversteer what can you change first?
cheers
yokemad is offline   Reply With Quote
Old 10-06-2007, 06:13 AM   #22086
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Just add up full set of ceremic bearing,wow!it's smooth!
i had done some modification on the chassis,this to prevent small rock stuck between the rear diff and chassis that cause the rear belt to snap!I'm running lower diff setting.
James khoo is offline   Reply With Quote
Old 10-06-2007, 07:49 AM   #22087
Smile car
cheers
after i build them I guess/eyeball about 20% of 100% rebound ...so it will come out about 1/4 in ....there's many ways u can go about oversteer/loose
try the mazda 6 body, less dope on the frt..I found with this setup if u dope full frt's it will b loose ..if anything u will push a bit off power...
if the car reacts to fast for u go up in oil 50wt ..for me a car that reacts too fast is loose ....play with spring rates go up and down frt and rear... for me I like a small push that way u can run more dula rate 70 to 80% that way the car will rotate fast and not loose traction....the main thing is to try 1 thing @ a time......update me/us on how it works ..My local track is not open yet so I only have iic wheel time
Old 10-06-2007, 08:15 AM   #22088
yokemad's Avatar
I was using the setup that jimmy has sended long time ?ago it was ok but last week I go to another club to race, their carpet was a bit funny ,it was very low grip I normally use R27 tyres but only managed B final with r22s...
Old 10-06-2007, 09:25 AM   #22089
I'm not sure what setup jimmy had then.......this setup is up to date.. can U run 27frt 22 rears ? ....on low biet try less droop say 3 rear 4 frt on hudy guage ie:more up travle like 5mm in the rear and 4mm in frt..
Old 10-06-2007, 04:14 PM   #22090
Big Features's Avatar
New name, same great taste
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 10-06-2007, 05:50 PM   #22091
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Good thing that is only your opinion.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 10-06-2007, 06:16 PM   #22092
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Mr. McGoo View Post
ok, i fixed all of my mistakes on my previous setup and here is my complete Vegas setup...if you have any questions feel free to shoot me a PM....
After driving Marc's car back at our home track today with this set up on it (the only change he made was he was running 2* al rear hubs made for an xray) I can say with all authority that it is definitely not just a high bite big race set up. It was so easy to drive. Planted everywhere and plenty of steering.
Just for reference . . .
With Marc's old setup before Vegas Marc could turn an 11.6 FL with his 19t.
Today he made us all look like rookies putting everyone (he was the only one not running a 13.5ss) a lap down and running his handout CO27 from vegas. He bettered his own PB by about a lap, and hit a bunch of 11.9's and 12.0's even at the end of 5 minutes.
He might be a little modest, and a good friend for suggesting others had something to do with this setup, but make no doubt . . .That guy can wheel a car!
Old 10-06-2007, 06:20 PM   #22093
does schumacher have any plan to make and sell diff dust covers? itd be nice especially for aphsalt drivers. i dunno maybe our tracks over here are dustier than most but itd be nice
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 10-06-2007, 06:42 PM   #22094
Trader Rating: 36 (100%+)
Custom...you're from IL right? Just wondering if I remembered that right and what your local track is.
This is coming up if you are close or anyone else nearby. Schumacher is one of the sponsors.. http://allstarcarpetseries.com
* TeamHurricane.net
* Trackside
* His and Hers Hobbies
* Victory R/C Hobbies
* Parma International
* P-Dub Racing
* RCTech.net
* Hobbico
* Hyperform Racing
* Novak
* Schumacher
Nexus is offline   Reply With Quote
Old 10-06-2007, 07:23 PM   #22095
Exclamation oooooops
'Customs' IIC Setup
Skiddins
I missed something on the front the pivot block spacers all 4 fronts need to be 1.5mm ...sorry ..... the frt bulkheads r lower than the rear so, 1.5mm in the frt and 2.5mm in the rear ='s the same rollcenter frt to rear....
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
