Old 10-04-2007, 05:10 AM   #22036
MagicMarker's Avatar
Originally Posted by POUNDITRACING View Post
Did you have to cut anything? Different stearing rack?
I didnt have to cut anything on the battery or car. I did however cut two small pieces of lexan to fix into the battery slots to similate a six cell pack and secure the pack on to the car. The Peak/Orion 4800 in flat on the bottom and thats why we did this mod. The battery can still be removed by pushing up on the bottom side when there is no tape on the car. When placing the lexan pieces on the bottom make sure everything is lined up on top of the side - meaning that the battery doesn't rub against the belt, the -/+ poles dont rub against the chassis, and the pinion doesnt hit the battery case. Then turn the car over and place the lexan peices with servo tape through the battery slot holes unto the pack. I didnt cut the lexan pieces perfect and actually left alittle play so I could get the pack out of the car with ease. I also used shrink wrap on the plugs so I dont have to worry about that bulkheads.
Yes I did use a different steering track rod - it's the one that is the same as the standard but middle in length and I moved it up one hole from the back to give it clearance.
All this info was given to me by a guy at our track that has ran lipos forever and got me to switch over for practice and club racing - so thanks to Andrew Doherty.
I hope this helps and I will try to answer anything else you might have about it or come up with some type of solution for ya.
L8R Marker
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 10-04-2007, 05:22 AM   #22037
dawgmeat's Avatar
Originally Posted by Customworksking View Post
front...
1way
.5 toe in
screw block spacers 1mm frt and rear
wishbone klips 2mm frt 2mm rear
link washers 3mm..ie 1 2mm and 1 1mm
ride heigth 5.5mm
droop 2mm uptravle over ride heigth..or 5 on hudy guage
roll-bar 1.40...gold in coloer
caster block 4deg
camber 1.5 to 2 keep checking all 4 tires because they change
link washer 1mm
horizonal pin
Pivot blocks spacers 1.5mm
shocks..3hole I ran 30wt 40wt and 50wt and found 40 the best
spring...AE blue
2nd hole in on shock tower outside hole on a arm
from frt to back 3rd hole on center track rod plate
med/short plate
rear settings:
drive heigth low frt and rear ie:diff/1way set to low
toe: i ran 2 and 2.5 try both
screw block spacers front 2.5 rear 1mm
quik klips 2mmfrt 2mm rear
link washer horizontal 2.5mm
ride height 5.5mm
droop 3mm uptravle or 4 on hudy
roll bar 1.40 gold
camber 1.5 deg
link washer 3mm
inboard pin horizonal
pivot blocks spacers 1.5 on all 4
shocks 40wt 3hole
Silver AE spring
3rd hole in on shock tower
2nd hole in from outside on a arm
short camber link
motor orion19t and co27 116 spur 29 final drive 7.20
dope full rears 1/2 frt 70 to 80% dual rate
let me know if I missed anything ..this is a good setup for med to high bite
I tried both stiff and kit top deck ...I felt very happy with this set-up
Mazda speed 6 body......
How did you finish at the race
dawgmeat is offline   Reply With Quote
Old 10-04-2007, 05:49 AM   #22038
Regional Moderator
Darkseid's Avatar
Originally Posted by abailey21 View Post
thats the one, it is red though, not gray hope thats ok
No problem with me. For as long as I've been running Schu stuff off and on, its about time I picked something like this up.
I'll add it on the next time I make an order at my local shop.
TLR 22...Tamiya F104...
Old 10-04-2007, 05:54 AM   #22039
Originally Posted by Nexus View Post
2. Running a spool...if the back end is a bit loose midcorner then on power what would you change. I realize you don't have the full setup but just wondering what some of you might do.
Thanks in advance.
Have you tried a Diff up front while run on the carpet?
Old 10-04-2007, 06:12 AM   #22040
DIALED's Avatar
Trader Rating: 91 (100%+)
Nexus--
I would say your rear end is a little soft--and/or the front is a little stiff.
Could be spring, damping, swaybar, shock angle or a combo therof.
Also, track width could be an issue (ie too wide front and/or too narrow rear)
Droop might be an issue, does it do it more/less throughout the run?
...Course, it could also be a c-link/and or roll-center issue...
Starting simple, though, could you just have too much front/too little rear bite?
DIALED is offline   Reply With Quote
Old 10-04-2007, 08:39 AM   #22041
Trader Rating: 37 (100%+)
A diff is OK in my opinion with carpet/rubber tires or really rubber tires in general. I prefer the spool on carpet and asphalt. It's always faster but a little harder to drive and setup the car.
Also running a spool or oneway can break more if you hit hard. If I want to play it safe I would use a diff. But when I want to really see how much I can get out of the car I run the spool.
Nexus is offline   Reply With Quote
Old 10-04-2007, 09:29 AM   #22042
Hey Goetz,
Didn't you post before your explainations of some setups...
Like explaining anti-dive, anti-squat, camber links, etc? I thought I read a post like that from you before in this thread but I couldn't find it.
p.s. Think Obey Schumacher :P
Old 10-04-2007, 10:20 AM   #22043
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Just an FYI, I tried both spool and 1-ways at the IIC, my laptimes averaged about 3/10ths faster with the 1-way. Even in mod there was nowhere on that track that I needed to use the brakes, the spool just felt like it bound the car up a bit too much in the corners.
Old 10-04-2007, 10:28 AM   #22044
Static_racing's Avatar
Your not going to get as much steering with a diff. I only run a diff with foam tires. On asphalt I like a spool and on carpet I run a one-way. One-ways were deffinately the ticket at the IIC.
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 10-04-2007, 11:40 AM   #22045
interesting.
I will have to try it. Right now I like the spool and don't ever use brakes either. But some of my problems are on really tight turns and/or 180s which could be due to running a spool.
Old 10-04-2007, 11:48 AM   #22046
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Haven't been to the Birds in a few years is the grip there comparable to IIC if so I guess stock rubber will be a oneway affair.
Rod
ClemsonTigers
Team C Racing
TC10
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 10-04-2007, 12:13 PM   #22047
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Hey Goetz,
yes. it was all a lie.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-04-2007, 12:49 PM   #22048
Customworksking's Avatar
Trader Rating: 73 (100%+)
made the c main in both stk and 19 I fed up in stock and doped full frt's made the car loose so,I took some dual rate out and didn't go re set it in 19 so I had a push by the time I did turn it up it was too late...my 1st time out with the car and no wheel time for 6 months didn't help but all in all the car is good,never felt this way about any other car...looking for a 2nd now to tell the truth.. the set-up i posted is 1 of the best u gonna get for mid to high bite....all u need to do is drive
Customworksking is offline   Reply With Quote
Old 10-04-2007, 12:58 PM   #22049
Send a message via AIM to adamliehr
Randy,
Did you get my e-mail? My e-mail hasn't been working right so I was just checking.
adamliehr is offline   Reply With Quote
Old 10-04-2007, 02:58 PM   #22050
Skiddins's Avatar
Hi, trying to put your setup onto a PDF, what does the 'Short camber link' mean?
Which top deck did you settle on?
Tyre Warmers?
Additive?
Can't think of anything else at the moment
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
